Old 04-09-2009, 07:16 PM   #1
stoneage
Member#: 104084
2004 Forester xt
Mountain Red/full sti 6mt
Default 6mt swap.......HELP
I am doing a 6mt swap into my 04 forester xt. It's almost done except for one thing. First here is a parts list.
05 sti 6mt
R180 rear end
Wrx auto drive shaft
04 sti axles (all 4)
04 5x100 sti rear hubs
07 sti rack and pinion
neetronics dccd controller
I bought everything but the dccd controller from an un-named NASIOC member that supplies swap parts. He promised that I could use my Subaru 4/2 pot set up. I told him I had heard conflicting stories on whether the rear calipers would work but he assured me he had done it before. So after waiting for 3 months for all the parts to show up (was told I would have a week wait) the install began.
Everything was going smoothly until it was time to bolt up the breaks. First my 2 pot rotors wouldn't fit. I called up the shop the parts came from and was told it was because I had the H-6 upgrade and not 06-07 WRX rotors. So I drove 3 hours one way to get the WRX rotors. When I got back to the shop I found out I had purchased the same rotors I already had. So I order 04 sti rotors. They fit over the parking break, but the Subaru 2 pot calipers don't fit (rotors too thick).
So a couple of questions......
1. Does anyone have the sti hubs and Subaru 4/2 pot set up, if so which rotor is required.
2. Or did I get snowed when I ordered parts.
3. If so, I am going to have to go with brembos on the rear. Does anyone know if 16.5 rims will clear the brembos in the rear. I know they will not in the front.
Any thoughts would be greatly appreciated!!
stoneage is offline   Reply With Quote
Old 04-09-2009, 08:01 PM   #2
stoneage
Member#: 104084
2004 Forester xt
anyone.......Plzz
Old 04-09-2009, 08:51 PM   #3
MasterKwan
Member#: 98961
2003 WRX
Love to answer your question but, don't know the answer. I think this would be better in the brake section though.
Old 04-09-2009, 11:41 PM   #4
gto7419
Member#: 44256
2002 WRX Wagon
youre going to have a hard time finding the correct rear rotor to go along with the rear RED 2 pots...
I would honestly sell those rear calipers and buy a set of rear brembos - makes things a LOT easier... I highly doubt you will get 16" rims to fit over the rear brembos...
So, looks like you need rear brembos and a new set of rims...
gto7419 is offline   Reply With Quote
Old 04-10-2009, 12:18 AM   #5
RallyColtTurbo
Member#: 16819
2002 MBP WRX, '98 OB
Three Gen 1 Legacy Turbos
I *believe* there was a year or two of (non-USDM) STIs in the GC/GF series that had the larger R180 parking brake, but still used the FHI 2 pots.
I would start by browsing Disk Brake Australia's website. Then move on to the UK and Aussie WRX boards.
Just ideas.....
RallyColtTurbo is offline   Reply With Quote
Old 04-10-2009, 12:26 AM   #6
RallyColtTurbo
Member#: 16819
http://forums.nasioc.com/forums/showthread.php?t=330246
That thread seems to indicate you need:
STi Two Pot Brake Rotor (Need 2 For New Install) 26710FA130 1 -> 178.90
Or
DBA part for reference, 656 : http://www.dba.com.au/view_product.p...series_id=4806
Further reading indicates you might need the backing plates to mount the FHI 2-pot calipers.
26655FA020 & 26655FA030 for R180
Old 04-10-2009, 07:00 AM   #7
RSmatt
Member#: 8039
94 v2 STi RA - RHD
You can use the STi backing plate with the 2 pot. You will need the V6 2 pot rotors in order to clear the ebrake assembly on the STi hubs.
RSmatt is online now   Reply With Quote
6mt swap - help me choose an approach! mowgli29 Transmission (AT/MT) & Driveline 11 02-21-2010 08:11 AM
Horribly bad noise after JDM 6mt swap. Serious help needed. Geek Guy Transmission (AT/MT) & Driveline 6 02-20-2007 05:07 PM
Legacy LSD R160 Diff on 6MT swap on 2004 RS HELP! dawoniyi Transmission (AT/MT) & Driveline 8 02-21-2006 01:50 PM
6MT swap help mazdamike Transmission (AT/MT) & Driveline 4 01-27-2006 08:10 PM
Did a 6MT swap with R180 and Brembos, got no brakes.... HELP Bumble Bee 03 Brakes, Steering & Suspension 3 05-14-2005 12:13 PM
Message Board Statistics All times are GMT -4. The time now is 05:04 PM.
