Old 04-09-2009, 10:56 PM   #1
builtgt35rsti
Member#: 181462
2005 WRX STI
Default GT35r problem/ boost problem
I have been having this problem for awhile, Car would not build boost when hooked up straight to the WGA, but when I threw a MBC in the line, it builds boost, but slowly. What could be the problem, when I have the intake off the car the turbo is spinning, but when I drive it, I dont hear it spool. main mods are fully built motor, ported & polished heads, bigger valves, TGV delete, perrin gt35r kit.
builtgt35rsti is offline   Reply With Quote
Old 04-10-2009, 01:00 PM   #2
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
Loose intercooler piping?
Le Saboteur is offline   Reply With Quote
Old 04-10-2009, 01:27 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
draw through or blow through MAF? Is it going rich under boost? Do you hear any exhaust leaks? What wastegate?
Old 04-10-2009, 03:54 PM   #4
builtgt35rsti
Member#: 181462
2005 WRX STI
blow-thru maf, not rich under boost, no exhaust leaks, tial 44 WGA
Old 04-10-2009, 05:59 PM   #5
Member#: 51961
2005 STi
2012 WRX
Have you checked for intercooler/bov leaks? Since you're running a blow through setup, any leaks pre-maf won't affect the AFR
Old 05-11-2009, 08:01 PM   #6
srt2stiguy05
Member#: 195183
2005 STi
ever find out the issue?
srt2stiguy05 is offline   Reply With Quote
Old 05-11-2009, 09:27 PM   #7
builtgt35rsti
Member#: 181462
2005 WRX STI
yea, it was mostly the tune, I got a tune from phil @ element and it was pretty much fine
gt35r oil return problems zeenon53 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 11-05-2009 01:02 PM
04 STi 9.8 @ 143 GT35R All Boost!!! Speed Proven Power Bragging 250 03-27-2009 10:51 AM
GT35R idle/fuel problems Black Metal Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-15-2008 10:36 AM
Another Stupid question: (Perrin gt35r install/boost controller) BritneySpears Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-18-2006 07:37 PM
Help with boost upgrade - high boost problem alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-06-2001 06:15 AM
