Welcome to the North American Subaru Impreza Owners Club Wednesday August 5, 2015
Old 04-10-2009, 12:48 AM   #1
urabus555
Member#: 102091
1994 1.8l Impreza L
Open Class Build w/110hp
Default '94 Impreza Rally Car Build - by Marv
Originally Posted by ButtDyno View Post
I'm moving my build thread from Project Cars to Motorsports. If enough people start one, there would be a better case for having a separate forum.
^^^ http://forums.nasioc.com/forums/show....php?t=1737776
Thought for the day: I thought open class cars needed lots of horsepower...
urabus555 is offline   Reply With Quote
Old 04-10-2009, 12:51 AM   #2
urabus555
Member#: 102091
1994 1.8l Impreza L
Default Current State:
This is how the car looks as of March 31st... ERROR... (that was 2009)
EDIT: March 2010
Old 04-10-2009, 12:57 AM   #3
urabus555
Member#: 102091
1994 1.8l Impreza L
Default January 11th
January 11th was the first time since July that I had time to work on one of my cars.
Here's what the car looked like at the end of the day...
Old 04-10-2009, 01:03 AM   #4
urabus555
Member#: 102091
1994 1.8l Impreza L
Default January 13th and 14th
On January 13th and 14th I got started on the interior...
Old 04-10-2009, 01:07 AM   #5
urabus555
Member#: 102091
1994 1.8l Impreza L
Default January 15th
Well, on January 15th it was -25 degrees C. I left the garage door open a crack and took the oppertunity to remove some of the tar sheeting inside the car. It took about 2 hours. Using an assortment of small hamers and a paint scraper, I got about 90% of it. I left the rest for later.
My feet went numb after 20 minutes!
Old 04-10-2009, 01:22 AM   #6
mug23
Member#: 97841
2005 STI Race Ready
OBP/Orange
Nice build. Love to see the end product soon. If I can get my lazy butt off, I can post my build as well.
mug23 is offline   Reply With Quote
Old 04-10-2009, 08:50 AM   #7
randy zimmer
Member#: 4560
93 buy my rally
build manual
Shameful as it may be, I'd like to plug my GC build book here...
randy zimmer is offline   Reply With Quote
Old 04-10-2009, 08:53 AM   #8
IcemanSS454
Member#: 51710
2004 Cobb Stg 2 WRX
San Remo Red
Can't wait to see some updates.
IcemanSS454 is offline   Reply With Quote
Old 04-10-2009, 11:14 AM   #9
Storm
Member#: 5218
96L Most Over-
Developed Beater
I don't think it's shameful......and might be a genuine timesaver for the builder!
Jay
Old 04-10-2009, 12:05 PM   #10
urabus555
Member#: 102091
1994 1.8l Impreza L
Jay
Randy,
If I may... Your GC Build Manual is full of excellent ideas. It has allready saved me MANY headaches and has paid for itself many times.
I should note for anybody reading the thread that Randy's manual will show you how to build a GC for rally in a much quicker and less expensive way than I am building mine.
Old 04-10-2009, 12:08 PM   #11
urabus555
Member#: 102091
1994 1.8l Impreza L
Default January 17th and 18th
I made some random progress in the few hours I had over the weekend. The biggest acomplishment was removing the dash and preparing to remove the engine...
Note: I label every single wire connector (on both sides of the connestion). I like to describe the physical location of the connection as well as the circut the connector is part of. I've found that the time I spend labeling is recovered threefold when I reassemble the car.
Old 04-10-2009, 12:20 PM   #12
Safe Drives
Member#: 75146
1998 Impreza Wagon
Now... If I just had that GC cage kit available for you...
Soon...
+1 for Randys book. I learned everything the hard way with my rally car. =)
Best regards,
Charles Buren
Safe Drives LLC
www.safedrives.com
Safe Drives is offline   Reply With Quote
Old 04-10-2009, 12:24 PM   #13
urabus555
Member#: 102091
1994 1.8l Impreza L
Default Reserved...
I have a couple things to share here once I finds some pictures...
Old 04-10-2009, 12:27 PM   #14
urabus555
Member#: 102091
1994 1.8l Impreza L
Default January 20th
I was tired and I had a long day at work. But, I wanted to see the engine out of the car...
I think I need to replace the rear main seal
Old 04-10-2009, 12:29 PM   #15
urabus555
Member#: 102091
1994 1.8l Impreza L
Default January 21st
This was a big day for me. I only had an hour or so and I spent most of the time sweeping and cleaning up the mess left from pulling the engine. The most rewarding part was getting the car up on jackstands. Until this time I'd done everything with the car on it's wheels. Once the car was off the ground it was there until bare...
Old 04-15-2009, 11:08 AM   #16
urabus555
Member#: 102091
1994 1.8l Impreza L
Default January 22nd
I got the FWD transmission out of the car. I got the rest of the wiring out from the dash area and cleaned out the engine bay a bit...
Old 04-15-2009, 11:12 AM   #17
urabus555
Member#: 102091
1994 1.8l Impreza L
Default January 23rd-25th
I spent all the free time I had removing the suspension and gas tank. Only four fasteners gave me trouble on this 15 year old shell: two seat mounting bolts (rusted in the transmission tunnel so I drilled them out), One gas tank mounting strap bolt (heat, penetrating oil, drill and broken extractors and I got it out), and the last one was a front sub-frame mounting nut (see grinder in picture below )...
Old 04-15-2009, 11:16 AM   #18
urabus555
Member#: 102091
1994 1.8l Impreza L
Default January 28th
I had an hour and a bit so I fought with the winshield. I removed it with and Olfa knife using the black blades - What a mess I made! But, the windshield came out and I only broke it in three places
I also got all the fuel and brake hardlines out of the car.
Old 04-15-2009, 11:30 AM   #19
randy zimmer
Member#: 4560
93 buy my rally
build manual
On my '93 FWD chassis, the rear trans mount uses holes closer to the front than the 4WD and the part with the red arrow gets in the way of the 4WD exhaust hanger.
It is a LOT easier to chop out with the transmission out.
Ask me how I know...
But make sure you don't need it!
Old 04-15-2009, 12:16 PM   #20
urabus555
Member#: 102091
1994 1.8l Impreza L
Default Thanks!
Hey Randy,
My AWD Trans. cross-member will still bolt in just fine with the missing chunk removed...
Did I get the right one?
Old 04-15-2009, 12:59 PM   #21
randy zimmer
Member#: 4560
93 buy my rally
build manual
Check this mount.
I think it will hit the bracket unless it's removed.
Old 04-15-2009, 01:01 PM   #22
Safe Drives
Member#: 75146
1998 Impreza Wagon
Dang, rust sucks... Old Imprezas don't look like this in Oregon.
Old 04-15-2009, 02:16 PM   #23
urabus555
Member#: 102091
1994 1.8l Impreza L
Default Lol!
Not in Onatario either!
This shell HAD its fair share of rust. I've spent alot of time "cutting and pasting" to get it to where it is now... I'll get to those pictures later.
Old 04-15-2009, 02:25 PM   #24
urabus555
Member#: 102091
1994 1.8l Impreza L
Check this mount.
Ooo... I'll have to triple check!
My trans mount goes in like this (well, sort of). But, it is a mount from an early 90's legacy turbo - I just assumed it would be the same...
Old 04-15-2009, 10:21 PM   #25
FtW_STi
Member#: 117016
2006 STi
Obsidian Black
Nice work, looking good!
I must say, it was a little trippy when I saw your Buddha frog - I have the exact same one sitting on top of my fridge.
FtW_STi is offline   Reply With Quote
Rally car build by TAD Motorsport in Chicago RallyKid Private Vehicle 'For Sale' Classifieds 0 11-26-2007 04:34 PM
Pictorial how-to: Building an Impreza rally car 8Complex Mid West Subaru Owners Club Forum -- MWSOC 11 10-13-2005 10:57 AM
FYI FS: lots of stock WRX parts left over from rally car build MJons Private 'For Sale' Classifieds 4 01-17-2005 04:09 PM
98 Impreza Rally Car. 15,150. must sell by Jan 31st.. Rallyspec North West Impreza Club Forum -- NWIC 51 02-25-2004 06:04 PM
98 Impreza Rally Car. 15,150USD. Musts ell by months end. Rallyspec Private Vehicle 'For Sale' Classifieds 0 01-13-2004 08:16 PM
