Old 04-10-2009, 04:50 AM   #1
00boostedRS
Member#: 115317
1992 Legacy SS
Default EJ22T question
Is it true that by just adding a set of EJ20H or EJ20G heads to a stock EJ22T( and all the nessesary wiring ) you can add HP just because the stock heads off the 22T flow so poorly?
00boostedRS is offline   Reply With Quote
Old 04-10-2009, 08:15 AM   #2
RallyColtTurbo
Member#: 16819
Yes, but you need an intake manifold also. Few other small details, but nothing major. Compression ratio goes down, but those that have done it say the minor tradeoff is worth it.
RallyColtTurbo is offline   Reply With Quote
Old 04-10-2009, 10:47 AM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
You could also use the 96-99 EJ25 dohc heads they are just about the same as the EJ20G and EJ20H heads and may be easier to come by for you.
Old 04-10-2009, 11:22 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
May be easier to come by, but not everyone has the ability to convert them over for oil and cooling. Just something to consider as a part of the equation.
Also, the Ej20H manifold allows for the conversion over to an under manifold inlet and straight in turbo. This means a td04 or any other late model turbo that would be an upgrade for the Ej22T becomes a bolt on option during the head conversion.
Old 04-12-2009, 02:38 AM   #5
00boostedRS
Member#: 115317
1992 Legacy SS
Yeah Ive heard about the DOHC outback heads working good. Would the compression ratio be about the same on those as the 20G or 20H's? Is there a plug you can just remove from the 96-99 DOHC heads and add a tap for oil or is it a lot more complex then that? I was thinking of just getting at JDM TD05 with the elbow in the inlet so it would be a direct bolt on for my inlet piping. Would I have to use the intake manifold off the 96-99's or with the use of that year head or do I have other options?
Old 04-12-2009, 02:40 AM   #6
00boostedRS
Member#: 115317
1992 Legacy SS
Also question about the Twin turbo trannys. How strong are they? Im aiming for the 300 to 350 WHP mark and I just wanted to know if that tranny could handle it or not
Old 04-12-2009, 03:53 AM   #7
RallyColtTurbo
Member#: 16819
Same strength as any other turbo 5-speed from those years. Nothing special.
Old 04-12-2009, 08:57 AM   #8
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Are the 96-99 heads and the ej20g heads made from the same general casting?
Isn't the Ej20h and Ej20g longblock identical, with a different intake manifold? I read that on RS25.
sorry for the hijack.
JDMFLCL is offline   Reply With Quote
Old 04-12-2009, 11:33 PM   #9
00boostedRS
Member#: 115317
1992 Legacy SS
Ah I kinda wondered if they were about the same as the WRX trannys. Do the Auto trannys on the Leg SS's weight more than the manuals?
Old 04-12-2009, 11:49 PM   #10
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
AUTO trannies are HEAVY.
Old 04-13-2009, 11:35 PM   #11
00boostedRS
Member#: 115317
1992 Legacy SS
Yeah thats what I thought, they look real bulky compared to the manuals. Any idea how much lighter they are that the auto's?
Old 04-14-2009, 11:26 AM   #12
adbramsay
Member#: 152345
2000 R34 GTS-T sedan
the ej20r had the ra spec gears in the box
adbramsay is offline   Reply With Quote
Old 04-15-2009, 02:41 AM   #13
00boostedRS
Member#: 115317
1992 Legacy SS
oh really so does that mean a 97 legacy twin turbo tranny would have the RA spec gears?
Old 04-15-2009, 02:56 AM   #14
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Probably, I am using that gear set with a 400/400 setup and it hasnt failed....fingers crossed.
Old 04-15-2009, 03:55 PM   #15
00boostedRS
Member#: 115317
1992 Legacy SS
whats a 400/400 set up mean?
Old 04-15-2009, 04:09 PM   #16
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
400 hp and 400 tq
gto7419 is offline   Reply With Quote
Old 04-15-2009, 09:52 PM   #17
00boostedRS
Member#: 115317
1992 Legacy SS
ah I see
ej22t question pilfflip Legacy Forum 6 01-26-2004 07:57 PM
EJ22T Question SubaruImpreza_power Pre-2002 Factory Turbo Powertrain 2 01-10-2004 05:20 AM
EJ22T questions SPESHAL Normally Aspirated with bolt-on Forced Induction Powertrain 1 06-23-2002 01:50 PM
ISR turbo oil supply and EJ22t Questions... Rovah Normally Aspirated with bolt-on Forced Induction Powertrain 11 12-05-2001 08:03 PM
EJ20 and EJ22T questions XJGPN Normally Aspirated Powertrain 1 12-11-2000 03:33 PM
