Old 04-10-2009, 10:08 AM   #1
smileyou
Member#: 152045
2003 PIA wrx
wrb..future ppg/fggreen
Default Destroked 2.5's
Curious how many are running this setup and how reliable it is. If you are can you elaborate on the setup please.
smileyou is offline   Reply With Quote
Old 04-10-2009, 10:51 AM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I know none of my betatesters DD their cars but by design, the longrod will have less wear and tear on the motor...bearings, rings, cylinder wall, piston skirt, etc...
I think Turbo mike is the only destroked setup running around daily and he has 10k on his homebuilt off the shelf motor; IIRC. He's at like 6.x:1 compression ratio that I know of because of the use of off the shelf parts.
Old 04-10-2009, 10:40 PM   #3
Epic Motorsports
Member#: 198925
2.35 destroke is very nice setup. You'll see alot more of it soon.
Epic Motorsports is offline   Reply With Quote
Old 04-11-2009, 11:33 AM   #4
Homemade WRX
Member#: 33782
96 bastard child
yes you will
Old 04-13-2009, 12:53 AM   #5
charliew
Member#: 125304
6:1 is that maybe not a interferance motor?
charliew is offline   Reply With Quote
Old 04-13-2009, 12:58 AM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
That would be the next best setup. Or say any +2mm rod setup?
FuJi K is offline   Reply With Quote
Old 04-13-2009, 10:33 AM   #7
Homemade WRX
Member#: 33782
96 bastard child
no joke...but realistically still depends on the cams.
Old 04-13-2009, 11:07 AM   #8
smileyou
Member#: 152045
2003 PIA wrx
Im thinking of using turbo mikes setup
ej205 heads
ej205 rods
ej207 crank
ej257 shortblock
Anyone else have any experience with this setup. Im thinking of throwing some cp forged pistons and maybe some aftermarket ej205 rods in with acl race bearings and cams. Can anyone elaborate if this setup will be better to use all stock off the shelf parts or aftermarket parts. Can anyone elaborate...Homemade?
Old 04-13-2009, 11:36 AM   #9
Homemade WRX
Member#: 33782
96 bastard child
I've already pointed out the downsides of running all stock parts for this setup.
If you are going with off the shelf, at least get +2mm rods. It will at least get the quench height in the right area and help bring up compression ratio.
Decided to jog some quick numbers to show you what happens without doing +2 rods...using the same values for everything but making the later, simply, 2mm below deck (factory rod and STi piston)
you go from a 8.3:1 to 7.1:1
on a 100mm bore, -16.1CC, 57cc head (JE's published values for the STi heads), 75mm stroke, .040" HG @ 100mm.
These were done with disregard to actual deck height and compression height, where results will typically be even lower compression than tested as most all aftermarket piston manufacturers cut pistons short to be sure stay below deck to reduce user error. You'll find that in the fine print.
So realworld would be more like 8.1:1 and 6.95:1.
Now even with +2mm rods take into consideration the the pistons designed use for combustion chambers (read up on the hybrid 2.5L issues). Though compression ratio debate won't be of concern for this application. Spool up should be similar to an EJ22 with +2mm rods and STi pistons with minimal rod length increase...about 1.77:1
Old 04-13-2009, 12:19 PM   #10
smileyou
Member#: 152045
2003 PIA wrx
Would this be a decent motor to run with the +2mm rods?
Old 04-13-2009, 01:02 PM   #11
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Default Down Stroked 2.3
Im running a Downstroked 2.3 liter that Mike and I made. You definetly dont want to use stock rods or pistons. Also you need to take into consideration that whatever you might see for tuning subarus doesnt apply to this motor. All the timing is different so you should see someone that can tune it. But overall its the most reliable motor I've ever driven (in a subaru) We are limited to 30 PSI on a GT35r .82a/r because of fuel injector limitations. It runs like a corrola on the highway when cruising and just torque steers in every gear to revlimit. Highly reccomend the motor, but highly reccomend you let someone build it that has experience with it. Also if balanced right you are able to cruise down the road at any rpm over 1200... If you feel like driving to work at 5000rpm the motor doesnt care... 6th gear at 40mph... doesnt car. i dont know if that appeals to anyone but me... with the exhaust i have and open gate its always good to have someway to be quiet.
Bamofo is offline   Reply With Quote
Old 04-13-2009, 01:39 PM   #12
smileyou
Member#: 152045
2003 PIA wrx
Can you please elaborate on your setups componets/builder and power?
Old 04-13-2009, 03:03 PM   #13
Bamofo
Member#: 159743
07 STI Limited
I built it with Mike
EJ207 Crank
Weisco Pistons 100mm
Eagle Rods
Cosworth #1 Bearings
04 STI Heads
Inconnel Valves Intake and Exhaust
BC Springs
BC Cams 272
08 STI Oil Pump Shimmed
07 EJ25 Block
Thats the block at least.
Old 04-13-2009, 03:16 PM   #14
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
how does it spool that 35? also where did you set the rev limit?
love the review btw, makes me wanna get one
Hyper is offline   Reply With Quote
Old 04-13-2009, 03:19 PM   #15
Bamofo
Member#: 159743
07 STI Limited
Rev limit is currently at 9000. we were goign to turn it up to 10k but theres really no need at all. Its fully balanced to do 10k but the only time that would happen is at the track..
GT35R spools at 4200rpm with no AVCS. Stupid speed density is messing up the stock ECU.
Just a note that i do drive 120miles a day. So if your wondering about reliable.
Old 04-13-2009, 03:45 PM   #16
Turbo_Mike
Member#: 130276
2004 STi
Rootbeer
I drive mine from mass to NY, NJ, NH and anywhere else to the track and back all the time as well.
Tony's is the more high budget model, mine's a bit more on a budget since I didnt even know if it would run when I built it.
The main differences:
Tony has an EJ207 crank, I have EJ205
Tony is using STi heads, I'm using 2.0 WRX heads.
Tony is using cosworth bearings, I'm using ACL.
Tony has inconel valves, mine are stock.
Otherwise the 2 motors are identical. I was running 32 psi daily with the 35R on it on pump gas. Ran best of 11.41 in the quarter, no problem hitting rev limiter in any gear. I set it at 8250 and powershifted at 8200.
Initially I broke the motor in with a VF34, and it felt and performed very similair to a 2.0L, just with more torque. Made 284hp at the wheels at 17psi, standard hybrid numbers. The motor doesnt really wake up until about 27 psi because of the super low compression, so the only way I'd reccomend using this setup is if you plan to have a turbo that can provide efficient boost at that high of pressure. I sold my 35R to tony, and a bigger turbo is in the works so we can see the true performance capability of this engine.
Turbo_Mike is offline   Reply With Quote
Old 04-13-2009, 04:48 PM   #17
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
interesting, so if i want something that is going to rev 8.5-9k in similar set up, what heads would you recommend and also bearings, and how are you de-stroking the block, and also what compression would you recommend.
Alaskan EJ20 is offline   Reply With Quote
Old 04-13-2009, 05:18 PM   #18
devil doc
Member#: 107279
06 vf39 wrx
black
How much better is the oiling in the ej207 crank than other ej2xx cranks
devil doc is offline   Reply With Quote
Old 04-13-2009, 05:33 PM   #19
Homemade WRX
Member#: 33782
96 bastard child
as posted many times before, especially in the crank shaft thread stickied at the top of the forum under 'good threads' or something along those lines...also those interested in this read the other link "official long rod" thread.
the new EJ205 crank is the same dimension/design wise but just isn't nitrided...see my pics and comparison
Old 04-13-2009, 05:58 PM   #20
devil doc
Member#: 107279
06 vf39 wrx
black
Hey micah r u planning on basing ur rotating asemblies around the ej207 crank or a billet 75mm crank?
Old 04-13-2009, 06:32 PM   #21
Homemade WRX
Member#: 33782
96 bastard child
they're based on the new factory 205 cranks because they are much cheaper, quicker and easier to source than an 207 crank...billet's are optional for all builds.
Old 04-13-2009, 07:01 PM   #22
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
Would this work with a EJ2501 instead of the EJ2507? I have an extra block is why I ask.
hustleshark206 is offline   Reply With Quote
Old 04-13-2009, 07:07 PM   #23
Homemade WRX
Member#: 33782
96 bastard child
yup...any 2.5L block
Old 04-13-2009, 10:45 PM   #24
SlickRick51586
Member#: 66735
2004 WRX
plus running the stock rod length compared to longer dosen't reap one of the benefits to its full extent, as the longer rods help you to apply the force at a more perpendicular angle to the crank. force (perpendicular to radius) * radius = torque
SlickRick51586 is offline   Reply With Quote
Old 04-13-2009, 10:54 PM   #25
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
EJ207 Crank
Eagle Rods
04 STI Heads
BC Springs
BC Cams 272
07 EJ25 Block
That's with stock WRX/STi rod length?
I need opinions on a sleeved and destroked 2.5 shvrdavid Built Motor Discussion 9 12-02-2008 12:08 AM
Can you side gap spark plugs on the 2.5's? spshultz Normally Aspirated Powertrain 4 07-07-2001 01:40 AM
Do any 2.5's have a rear LSD? jeffg Normally Aspirated Powertrain 5 12-15-2000 02:42 PM
2000 2.5's are not aloud in touring Donnie Mid West Subaru Owners Club Forum -- MWSOC 26 06-22-2000 07:38 AM
How much air do our 2.5's take in per 1RPM? 8Complex Technical Forum Archive 14 06-08-2000 12:31 AM
