Old 04-10-2009, 11:17 AM   #1
smash
Member#: 134604
2007 OBP WRX
WRX Girl!!
Default Shop forgot to put coolant in my car after 30k mile service..
So, I took my car to a reputable and affordable shop in my local area, because I could not afford the $500+ my dealer wanted to do the 30k mile service.
I get the car back, everything seems fine. I happen to look at the temperature gauge after about 20 minutes of driving it home (roughly ~15 miles) and see the temp gauge is maxed out. I immediately pull over and call the shop.
They have a mechanic come out and meet me and fill it with coolant and run it through a couple times to get the air out or whatever.
Car seems fine today- but I'm very worried. There was almost no coolant in the car when I drove it, the mechanic admitted they forgot to put coolant back in it after they'd drained it because they were waiting on the brake pads i'd ordered to get there so they could replace them.
My question is this - what damages could feasibly now result from this blatant oversight on the auto shop's part? Would they be apparent right away or could problems take a few months to surface?
I am planning on calling the shop this afternoon and ask that they at the very least inspect my engine for damage. I would like to ask that they put something in writing to the effect that they neglected to put coolant in the car and would cover any related damages in the near future, but I realize this may be wishful thinking and the shop might outright refuse to do that. Any advice here? I'm really frustrated right now..
smash is offline   Reply With Quote
Old 04-10-2009, 11:32 AM   #2
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
15 miles with no coolant is bad, I would be worried about piston skirt damage, you might not see headgasket issues, listen for any odd tapping noises. you might want another shop to look at it, at a minimum, get an oil analysis.
crampfan is offline   Reply With Quote
Old 04-10-2009, 01:30 PM   #3
smash
Member#: 134604
2007 OBP WRX
WRX Girl!!
Thanks for the heads up. I haven't heard any strange noises, and *fingers crossed* everything still seems okay..
I talked to the shop this morning and they agreed to give me a letter in writing stating they will cover any damages related to their negligence for the next 6 months.
If, for any reason something major does happen, I would of course have the work done at an official Subaru shop (like a dealer) and send the bill to the shop that caused the damage- if they try to get out of it, I'd imagine I have a relatively simple case against them given the statement they wrote me essentially owning up to the negligence.
Old 04-10-2009, 01:40 PM   #4
leecea
Member#: 37359
2003 WRX
I'm impressed.
I overheated an engine once and the result was that it started leaking coolant because of block distortion (IIRC).
leecea is offline   Reply With Quote
Old 04-10-2009, 02:05 PM   #5
smash
Member#: 134604
2007 OBP WRX
WRX Girl!!
Ugh, wow that sucks.
Yea I was very impressed too.. but this shop does have a very good reputation locally for being honest, so I was glad I didn't have to fight them on anything. I probably shouldn't speak too much until I actually have the letter in hand though lol! But I did speak with the owner and he sounded genuine about his intent, so, let's hope it all works out..
Old 04-10-2009, 06:54 PM   #6
danmezz
Member#: 126339
2003 WRX Wagon
I'd venture a guess that it's probably fine, especially since you caught it right away. With a flush and fill or even drain and fill, there's still a little bit of water in the system.
In the past I've had a vehicle overheat so much that the engine stalled. That's a bad scenario and can do lots of damage. No permanent damage was done, but it was a 1960's Chevy engine built like a tank. Since you noticed it before the engine stalled and stopped right away, it's probably fine.
No harm in working with the shop though just to be safe in case something did happen. It's not something you'd want to do every day though. Now running without oil and that's an entirely different story...
danmezz is offline   Reply With Quote
Old 04-11-2009, 11:55 PM   #7
wizzle-stick
Member#: 160534
2002 impreza rs
i sense someones about to suddenly have "block issues"
wizzle-stick is offline   Reply With Quote
Old 04-11-2009, 11:58 PM   #8
DerrickRH
Member#: 75078
2000 Legacy GT
Black Granite Pearl
Wow, what a mistake
DerrickRH is offline   Reply With Quote
Old 04-12-2009, 11:03 AM   #9
Ekeenan86
Member#: 155493
1999 Legacy Outback
I would make sure you don't pay for that flush; at the very least they should credit you for that and hopefully all the work you had done.
Ekeenan86 is offline   Reply With Quote
Old 04-12-2009, 01:15 PM   #10
rick-l
Member#: 33868
2003 wrx
srp
I wouldn't compare my experiences with a Chevy to this. How can you compare a cast iron cylinder head to an aluminum dual overhead cam head? I have heard these engines are very susceptible to damage from overheating.
rick-l is offline   Reply With Quote
Old 04-12-2009, 08:39 PM   #11
danmezz
Member#: 126339
2003 WRX Wagon
^^^ yes, I am very aware they are different engines. That's why I mentioned it.
Old 04-13-2009, 01:12 PM   #12
rick-l
Member#: 33868
2003 wrx
srp
Then what is the basis for this statement
It certaintly can't be the ~100 threads about head gasket failures on this forum can it?
Also your private shop may not have done this. I think it is to prevent head gaskert leaks.
12. To prevent cooling system leaks, always add Genuine Subaru Cooling System Conditioner (Part
no. SOA635071) whenever the coolant is replaced.
Old 04-14-2009, 02:13 PM   #13
smash
Member#: 134604
2007 OBP WRX
WRX Girl!!
I had actually asked several people about the requirement for Subaru Genuine Coolant and the resounding response was "it's not required" so just regular coolant was used... I hope that's okay
Certainly the next service needed I will be sure to use the Subaru coolant, I didn't think it was that big of a deal
PS 1 week later and still running strong!! Good sign I hope :0
The shop did refund me the cost of the coolant flush, and I have letter in hand stating they forgot to add coolant and will cover any damages that may occur in the next 6 months.
Old 04-14-2009, 02:41 PM   #14
rick-l
Member#: 33868
2003 wrx
srp
I can only go by what I read here Coolant System FAQ and here https://www.subaru.com/my-subaru/mai...edule2007.html
It only cost like $4
Old 04-14-2009, 03:31 PM   #15
smash
Member#: 134604
2007 OBP WRX
WRX Girl!!
Yeah, I'm getting paranoid now. I don't know if they used a conditioner when the coolant was re-filled.. probably not.
Should I take it to the dealer and have them do another flush using the Subaru coolant and conditioner? Or am I freaking out for no reason..
Old 04-14-2009, 05:43 PM   #16
rick-l
Member#: 33868
2003 wrx
srp
I take it you have the shop's phone number ????
How hard is it to dump a bottle of that in there?
Old 04-14-2009, 06:12 PM   #17
smash
Member#: 134604
2007 OBP WRX
WRX Girl!!
Yeah, but me calling them and asking if they did it and them actually doing it are two different things. Who knows if they actually did it or not, even if they claim they did?
I just read somewhere that Subaru can choose not to honor warranty claims if you do not have Subaru Genuine Coolant and Conditioner present in your system. Think I'm just gonna call the dealer tomorrow and have them correct this.
Old 04-14-2009, 11:13 PM   #18
leecea
Member#: 37359
2003 WRX
The Coolant Conditioner thing is odd, since it is reportedly just re-badged RadWeld. We used that stuff to jury rig old cars and save the money to really fix them. Oh well.
Old 04-15-2009, 10:48 AM   #19
peteys02bugeye
Member#: 162951
02 WRX
Well I am not a mechanic but I personally would reflush the coolant and change the oil (send the old oil out to be checked) because the high temps probably were not kind to it.....but thats just my .02
peteys02bugeye is offline   Reply With Quote
Old 04-16-2009, 01:15 PM   #20
smash
Member#: 134604
2007 OBP WRX
WRX Girl!!
thanks for the input everyone.
the shop agreed to backflush the old stuff out and put in the Subaru Genuine Coolant + Conditioner that I picked up yesterday. yay!!
Dealer said I'd be fine as far as warranty goes as long as I have my receipts and the receipt from the shop showing the Subaru stuff was used.
Old 04-16-2009, 10:48 PM   #21
BAMC1S
Member#: 194051
2005 STi
thats why i do my own work on my STi
BAMC1S is offline   Reply With Quote
Old 04-17-2009, 11:04 AM   #22
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
^^Me too. No matter how good a mechanic is, they always seem to be rushing around and its very easy for them to forget stuff. Always check your car when you pick it up to make sure everything on the invoice was actually done.
I've done that in an 84 Subie and it survived.
Mike Wevrick is offline   Reply With Quote
I needed help to put gas in my car this morning. coop119 Off-Topic 30 11-20-2008 11:36 AM
Where to find these seats, and how to put them in my car cucamelsmd15 Interior & Exterior Modification 2 01-28-2008 07:43 PM
I Poured too Much Coolant in My Car sub25rs Service & Maintenance 9 01-31-2007 03:15 PM
Gas atendant put regular in my car njskatchmo Newbies & FAQs 33 12-20-2005 05:04 AM
Can I put this in my car? ImpreziveRS Normally Aspirated Powertrain 14 02-09-2002 09:34 PM
