Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-10-2009, 02:00 PM   #1
gappvembe
Member#: 206412
2005 Baja
Question Newer Baja owner here, I have some questions....
http://s145.photobucket.com/albums/r...mbe/New%20Car/
It looks a little bit different now, as I put quite a few KISS stickers on it.
Whenever I open the driver's side front door, the lights show that both front doors are open. I had a Car starter installed, I'm not sure if that had anything to do with it. All the other doors work singularly. Is this common?
My serpentine belt makes a loud squeak/squeal when I start the car most of the time... 75%. But it drives fine and doesn't make the sound when I'm driving. I took it into the dealership (actually a ford dealership because that is how I got it [long story] and it was still under warranty per say) and they couldn't get it to reproduce the sound. Anyone have this problem or a fix for it?
My last question is how is the BAJA speaker upgrade? Worth it, or any speakers better for the money... or better and cheaper?
Thanks.
I love my Baja.
All I get are compliments.
gappvembe is offline   Reply With Quote
Old 04-10-2009, 02:35 PM   #2
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
The door issue is not common to my knowledge, the squealing most likely is a combination of a 1. loose or worn belt, 2. battery may need to be replaced and is causing the alternator to work a little hard right after you start the car. As for the speaker upgrade, I did it to mine (tweeters and sub) and I was happy with it. I'm sure there are better speakers out there though.
Buck
Buck Rogers is offline   Reply With Quote
Old 04-10-2009, 04:40 PM   #3
Alpha Wolf
Member#: 140505
2005 Baja Turbo
Pearl Blue
Cool
Thanks.
I love my Baja.
Ours has never had an issue of it showing both front doors open. It sounds like someone must have tapped a line on that system to install something if this issue started about the same time you had the car starter installed.
If the belt squeals when you start it then you either need a new belt or the idler pulley is worn or loose.. Check the pulley that maintains the tension is tight and does not wobble. If it is okay then the belt may have stretched so far it cannot compensate for it. If so, install a new belt. Easy to do yourself.
Alpha Wolf is offline   Reply With Quote
Old 04-10-2009, 07:55 PM   #4
BajaGuy68
Member#: 127720
2015 WRX
Lightning Red
I agree, the door issue is not common. Whoever installed the car starter may have crossed a wire or two. The squealing maybe a worn serpentine belt, bearing in the tensioner, or the alternator.
I installed my own speakers because the "factory upgrade speakers" suck! I used Pioneer 3-Way 180watt speakers and they cost me around $100 for all four of them (I kept the factory tweeters) and then another $100 for a subwoofer. My Baja now Rocks!
BajaGuy68 is offline   Reply With Quote
Old 04-10-2009, 09:16 PM   #5
seaview
Member#: 201074
2003 Baja
You didn't say how many miles are on it but you need to replace that belt at 100000 miles which I did with mine as it was at that when I bought it a few months ago. I love mine too and it looks just like yours.........Haven't had the light problem. Don't know about my speakers but have an aftermarket radio in there...........No complaints with mine at all.............Pete L.
seaview is offline   Reply With Quote
Old 04-10-2009, 10:11 PM   #6
YBajaSteve
Member#: 184040
. 03' Baja- Sold
83' Datsun 280ZX
just did a complete speaker overhaul and i would highly suggest NOT getting the "baja speaker upgrade" You can easily spend the same (or less) amount of money on nice aftermarket speakers and get A LOT better sound quality. Have you ever had a car that had nice factory speakers, but after awhile, replaced them and just was wowed by how cheap they looked when you took them out, and had the new speakers completely destroy the stock ones in sound quality? that's how it would be to put "premium" baja speakers in, they're still not as good as aftermarket. I think anyone who's done any car audio would agree with me.
YBajaSteve is offline   Reply With Quote
Old 04-11-2009, 09:40 AM   #7
jeromes
Member#: 192299
2011 Forester XT
Default Speaker Upgrade
I just purchased a set of four Kicker DS600 speakers for my Baja from Crutchfield. very easy to get door panels off and the speakers fit in fine.
Belt sounds like it needs replacing. Have a forester that appeared to be having power steering pump problems when cold but it turned out to be loose belt, (that was the first time I have ever seen that one).
jeromes is offline   Reply With Quote
Old 04-11-2009, 10:05 AM   #8
BajaGuy68
Member#: 127720
2015 WRX
Lightning Red
If you do upgrade your speakers- be careful of the depth. You don't want problems,after the install, with rolling the window down!
Crutchfield is an excellent place to buy them from.......unless you have a friend that owns a stereo shop!
Old 04-11-2009, 10:37 AM   #9
gappvembe
Member#: 206412
2005 Baja
Thanks to everyone who repsonded about the speakers. It'll be a while before I do it anyway.
A new CD player is going in today, so I can plug my iPod directly in.
I figured it was something from the car starter. Seemingly no other problems so its fine by me.
Car has 83,000 miles.
I'll closely inspect the belt and Idler pulley and tensioner. From what I remember, the belt is really tight.
Is there a part number or brand belt that anyone recomends?
Old 04-11-2009, 11:03 AM   #10
machinegreen
Member#: 100818
2005 Baja Sport
Dark Blue Pearl
About the speakers i have 4way Xplods Work great about a hundred bucks need to buy spade ends for the back wires though.
machinegreen is offline   Reply With Quote
Old 04-11-2009, 08:33 PM   #11
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
I have the same amount of miles..I just had to replay my belt for the squeeks....
holland_patrick is offline   Reply With Quote
Old 04-14-2009, 07:13 AM   #12
gappvembe
Member#: 206412
2005 Baja
Sounds like you had the same problems as me huh, well cool, I'll get on that as soon as I can. Thanks to you and everyone who suggested it.
Old 04-14-2009, 01:04 PM   #13
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Either a new belt is needed or the existing needs to be tightened.
Samirr76 is offline   Reply With Quote
Old 04-14-2009, 04:22 PM   #14
holland_patrick
Member#: 72014
05 Baja gone
just replace both of them..
Old 04-14-2009, 11:35 PM   #15
FUBARU_baja
Member#: 208623
is this a common problem with bajas at or around the 100k limit?
I'll be getting a baja pretty soon too, its an 04 turbo w/ 108k..... so im just wondering... they say recently serviced at 100k in the ad, so im assuming the belt was replaced and all, we'll see this weekend...
good luck gettin it fixed.
FUBARU_baja is offline   Reply With Quote
Old 04-15-2009, 10:43 AM   #16
Alpha Wolf
Member#: 140505
2005 Baja Turbo
Pearl Blue
Cool
If it was replaced they should have the work order saying it was. Demand to see the work order for the 100k service. It is a rather large service and not just an oil change. If they just did an oil change, have them knock off a bunch as you will now have to pay for the belts, tranny fluid changes etc.
Ours has over 100k and is still running like new.
Old 04-17-2009, 07:44 AM   #17
gappvembe
Member#: 206412
2005 Baja
I had a chance to check out the belt the other day, and I must say the belts look really good and tight. Now it makes me wonder, if that's not it, what could it be.
have some questions regarding maintenance nrclptcnsmniak Newbies & FAQs 7 06-04-2010 03:09 PM
Potential Subaru Impreza Owner---Have some questions though. ECULogical Newbies & FAQs 7 04-07-2010 03:46 PM
Pond Owners, I have some questions!! FkVtech Off-Topic 20 12-11-2009 11:07 AM
Soon to be owner of WRX, have some questions blackmaxx96 General Community 8 07-07-2005 03:49 PM
New here, have some questions about mods ScoobaLude Newbies & FAQs 10 10-01-2002 02:52 PM
