Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 04-10-2009, 03:27 PM   #1
ChuiSTi
Member#: 61212
2005 STi
CGM
Default Blouch 2.5R
Hey guys, just got tuned by Jon at HB Speed yesterday
Mod List (power)
- Cobb Legacy Intake (68mm i believe?)
- Cobb cold air box
- Perrin Afta Maf Hose
- Perrin 2.4" inlet
- Prodrive BCS
- NGK 1 step colder plugs
- Walboro 255 Fuel Pump
- PE 850 Side Feeds
- Helix catted downpipe
- Borla Hush full 3" exhaust
- Grimmspeed TGV Deletes
- Grimmspeed 3mm phenolic spacers
- Grimmspeed PnP header with Hiflow crosspipe
- APS TMIC
- Blouch 2.5r 8cm2
366.1 ft/lb and 377.5hp on 100 oct (~22psi)
Lower line is 91 oct (~20psi)
ChuiSTi is offline   Reply With Quote
Old 04-10-2009, 03:34 PM   #2
jutes85
Member#: 127232
E92 M3
98' Foz
Nice numbers/curves. Great to see that the power doesn't fall off at higher rpm's, something that I hate with the VF39. What psi were you tuned to?
jutes85 is offline   Reply With Quote
Old 04-10-2009, 03:38 PM   #3
ChuiSTi
Member#: 61212
2005 STi
CGM
I think it was 22psi and 20 psi. i love the torque and the tgv deletes made throttle response so much better
Old 04-10-2009, 05:09 PM   #4
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
that thing spools nice.
godforbid67 is offline   Reply With Quote
Old 04-10-2009, 05:24 PM   #5
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
really nice setup!
IMPORTIMAGE is offline   Reply With Quote
Old 04-10-2009, 05:36 PM   #6
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
looks like a great combination of parts you got going on there.
Most STI's I see loose anywhere from 40-100 hp from 6K to 7K rpms.
Your car only looses about 10-15, that makes for a great top end.
Illusive is offline   Reply With Quote
Old 04-10-2009, 07:24 PM   #7
ChuiSTi
Member#: 61212
2005 STi
CGM
I was just driving around today, it is the perfect street setup, gobs of passing power and torque, at exactly the rpms i need, (05 sti 6-speed).
Old 04-11-2009, 06:46 AM   #8
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
Nasty! Good to see more blouch 2.5 users. I need to get my car finished and dyno'd or taken to the track to back the underrated blouch 2.5.
k04sti is offline   Reply With Quote
Old 04-11-2009, 03:09 PM   #9
snowmanwrx
Member#: 176026
would love to see how the DOM 2.5R perform on a 2.5wrx....... DOM 2.5R should have a better respone and faster spool than a TD05-20G right??
snowmanwrx is offline   Reply With Quote
Old 04-11-2009, 03:14 PM   #10
godforbid67
Member#: 137168
06 Built SGM WRX
hmmm would def say a 20g would outspool this guy. espescially with a td05.
Old 04-11-2009, 03:25 PM   #11
snowmanwrx
Member#: 176026
really? but the DOM 2.5R is a ball bearing turbo while the TD05-20 isnt.
Old 04-11-2009, 03:32 PM   #12
godforbid67
Member#: 137168
06 Built SGM WRX
yeah that is true, but still a 20g has a smaller wheel and that tiny hotside. it would be close either way, probably not even too noticable.
Old 04-11-2009, 03:36 PM   #13
jason miller
Member#: 158313
2003 WRX
I agree. My bet is that a 2.5L motor would spool either turbo so well that any difference would minimal. But a td05 20g should still be a little quicker.
jason miller is offline   Reply With Quote
Old 04-11-2009, 03:43 PM   #14
ChuiSTi
Member#: 61212
2005 STi
CGM
it should spool slower than the td05 20g, although it spools a bit faster than the atp 3071 due to the housings
Old 04-11-2009, 04:00 PM   #15
snowmanwrx
Member#: 176026
any difference if the TD05-20G come with a 8cm????
Old 04-11-2009, 04:49 PM   #16
jason miller
Member#: 158313
2003 WRX
From what I've read, the 8cm spools just as quickly as a 7cm housing on the 2.5L motors. The 7cm should probably be avoided. Common opinion of people I trust is that the 7cm is just too small to handle the volume of gas produced by an ej255/7.
Old 04-11-2009, 05:59 PM   #17
ChuiSTi
Member#: 61212
2005 STi
CGM
Yeah definitely, considering that the 2.0 liter EVO comes stock with a 10cm2 housing too.
I think a TD06-20g 8cm2 makes just as power with the same spool as the dom 2.5r. If i had to do it over again i'd still get the dom 2.5r for the ballbearing badassness lol
Old 04-11-2009, 06:30 PM   #18
jason miller
Member#: 158313
2003 WRX
ChuiSTi, I'm envious of your setup. That 2.5r has a 47 lb/min compressor wheel as opposed to the 40 lb/min rating of an 18g, so I wouldn't worry about any kind of buyer's remorse.
Old 04-11-2009, 06:43 PM   #19
jutes85
Member#: 127232
E92 M3
98' Foz
Is your coolant feed line rubbing slightly against the corner of the APS TMIC? I couldn't get the pass tmic bolt on due to the line.
Old 04-11-2009, 07:33 PM   #20
ChuiSTi
Member#: 61212
2005 STi
CGM
haha thanks jason!
jutes,
i used some thick metal washers from home depot (2-3 of them) between the tmic and the passenger side mount, elevated the passenger side about 1/4-1/2 inch and it doesn't rub on the coolant line anymore
Old 04-11-2009, 07:57 PM   #21
crand002
Member#: 129765
2006 EVO
439whp/412wtq (MD)
What did you add since the Harman tune?
crand002 is offline   Reply With Quote
Old 04-11-2009, 09:42 PM   #22
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
What headers are you running?
Fierysun is offline   Reply With Quote
Old 04-11-2009, 10:01 PM   #23
ChuiSTi
Member#: 61212
2005 STi
CGM
I added grimmspeed TGV deletes, grimmspeed phenolic spacers, and grimmspeed PnP coated stock header with hi-flow crosspipe
Old 04-12-2009, 03:36 PM   #24
k04sti
Member#: 171773
04 wrx sti
Yea, mine is too. I couldn't get the left bolt on the tmic due to it rubbing on the coolant. I have spearco tmic and the blouch 2.5
Old 04-12-2009, 04:12 PM   #25
jutes85
Member#: 127232
E92 M3
98' Foz
Ahh well. Mine is rubbing against the clamp, not the line so it doesn't really matter.
I'm interested to see the differences in spool with an EWG when I get mine tooned in a months time.
Blouch 2.5R turbo sutter2k Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 355 07-06-2010 01:07 AM
Blouch 2.5R Polka Pickle - Recently Inspected by Blouch dennyt4 Engine/Power/Exhaust 1 04-04-2009 06:20 PM
FS: (MA) - Blouch 2.5R Polka Pickle - Recently Inspected by Blouch atc5 Engine/Power/Exhaust 2 03-28-2009 01:22 PM
2002 WRX wagon 2.5L hybrid w/ Blouch 2.5R turbo triguy Proven Power Bragging 12 10-18-2008 04:09 PM
Blouch 2.5R Boost Logs (compare your 20g please) muffnbluff Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-07-2007 07:34 PM
