#1 |
Member#: 60042
Vehicle:2004 WRX STI Rotated T67 ALLABOUTSPEED |
Ok.. well i called Wiseco looking for Ring gap for 100mm wisecos. Told them this was on a modified Subaru. Aprx. 500whp. They gave me .003 piston to wall clearance which i believe is correct. However they told me that the top ring gap is .020-.022' and the 2nd at .016-.18".
Well my engine builder has now filed them specs that the Tech department at Wiseco told me.. however one of the guys at my engine shop said the 2nd is always larger then the first. What are shops running these Wisecos at?? Im going to be pretty upset with wiseco if they told me wrong and I have to purchase a new set and than pay for my builder to refile them. I even double checked with the wiseco guy... guess i should get names next time.
#2 | |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
Look at what you typed, what you're asking, and what they told you.
You typed: Quote:
Jay |
#3 |
Member#: 60042
#4 |
Member#: 60042
Here guy's. Did a few hours of researching. This is from Wiseco
Ring Gap Table Instructions 1) Cylinder bore size must be in inches. If measuring millimeters, divide bore by 25.4. 2) Multiply your bore size by the “x Bore” column for your application. Min. Gap Per Inch of Bore Top Ring 2nd Ring Oil Ring Rail ______________________________Top Ring____ 2nd Ring_____ Oil Ring Rail Application____________________Bore x ........ Bore x .........Min. Gap High-Perf. Street/Strip ............... .0040” ......... .0050” ........... .015” Street-Moderate Turbo/Nitrous .. .0050” ......... .0055” ........... .015” Late Model Stock ....................... .0050” ......... .0053” ........... .015” Circle Track/Drag Race ............. .0055”.......... .0057” ........... .015” Nitrous Race Only ...................... .0070” .......... .0073” ........... .015” Blown Race Only ....................... .0060” ......... .0063” ........... .015” NOTE: The chart above is a general end gaps guideline. Each ring should be fi tted to the particular cylinder in which they are to be installed. The gap on the 2nd ring should always be larger than the top ring end gap, this will help reduce top ring fl utter. http://www.wiseco.com/Catalogs/Sport...ccessories.pdf Above is the link. Scroll to the end of page.. gives you great info Last edited by Hayaboosted; 04-10-2009 at 09:01 PM. |
#5 |
Member#: 60042
Well from what my calculations are.. Wiseco Told me in the reverse order.. This is how it should be
Wisecos Hi Performance. Street/Strip setup Would be: Top Ring @ .016"-.018" & 2nd ring @ .020"-.022" Now basically to salvage my entire ring set I would be using their Street-Moderate Turbo setup. Which calculations say are: Top Ring @ .020" - .022" & 2nd Ring @ .022"-.024" Do you think its safe to use the Street-Moderate Turbo Setup from the Chart in the previous post? Here is my current Setup EJ257 100mm Bore Wiseco Pistons Manley Rods Balanced Blue Printed ARP Head Studs BC Valve spring & Retainers BC 280 Cam ACL Main & Rod Bearings Cosworth Oil Pump Forced Performance Green turbo Possible moving to GT35-40 End of year Will be planning on tuning on Meth and race fuel |
#6 |
Citizen Mick
Member#: 27646
NWIC
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
I do 22 thou top, 18 thou second (build boost between the two)
Cosworth does 15 thou top, 20-22 thou second I've done 26/26 thou before as well (medium blowby with that setup) |
#7 |
Member#: 60042
So wiseco was right?
#8 |
Member#: 205916
South East
Vehicle:2003 Subaru WRX in the 10's and the bends |
The second ring is always larger than the top. What ever charge gets past the first ring needs to get past the second to avoid flutter. Most manufactures have moved into putting accumulator grooves between the two rings to add some volume to avoid flutter.
What raises some real questions is how tight can we go from the spec that has been used for years that had cast iron blocks in mind. If you disassemble a new stock subi short you will find the rings butted. Clearly the bore grows away from the piston as the engine takes on heat. For those of you that have machined on a EJ block you have seen just how dynamic they are. In the end you want them as tight as they can be without butting and/or trapping gas between the two. Jay Meagher |
#9 |
Member#: 60042
so no one knows anything.. weird..
#10 |
Member#: 205916
South East
#11 |
Member#: 60042
Really did you read the entire thread? I know the order and placement of my rings. I now need to know if the ring gap of
Top Ring @ .020" - .022" & 2nd Ring @ .022"-.024" Would be an ok setup. Or should I be calling Wiseco to send me some new rings on them? Your post mentions nothing about spec.. Clarify? Last edited by Hayaboosted; 04-13-2009 at 08:59 PM. |
#12 |
Member#: 170836
Vehicle:2004 sti wrb |
hello Hayaboosted !am doing wiseco piston to but i need to know the ring gap to ! tanks
#13 |
Member#: 205916
South East
Sorry I was trying to shead some light on the subject.
Your numbers of .020/.022 top ring and .022/.024 is fine. As long as the second is bigger than the first. Jay Meagher |
#14 |
Member#: 85036
Vehicle:2013 PBP sti ltd 05 LGT 35r 30psi..busted |
ive done 18 on top and 20 on 2nd for all my builds. Compression is consistently 170psi on all builds, no cylinder scoring either, no/minimal blowby. This is with 100mm wisecos, hybrid setup, stock sti headgasket.
DK |
#15 |
Member#: 60042
Ok guys ur not reading the thread. The rings have already been filed in the wrong order because wise co screwed up.
#16 |
Member#: 159743
Vehicle:07 STI Limited TurboMike Tuned 2.35 |
we do .018 on the top and .020 on the bottom for whiny people that dont like burning any oil due to blow by. and .020 on top .022 on bottom for normal people
#17 |
Member#: 60042
. As said before the rings have already been filed making that not possible.
#18 |
Member#: 60042
#19 |
Member#: 205916
South East
If you don't want to buy a new ringset which is ($85) then you will need to go .022" on the top and .024" for the second.
#20 |
Member#: 182227
NWIC
Vehicle:2000 MPS Built RS 1991 Leggy Turbo EJ22t |
Just have your builder re-gap the second rings to .024 and you should be good to go. Probably burn some oil as mentioned above.
#21 |
Member#: 60042
I think im going to try and go 20 and 22
#22 |
Member#: 205916
South East
| Thread Tools | |
| Display Modes | |
| Need a flange welded. please help with specs | bluesoob02 | General Community | 4 | 02-03-2010 08:06 PM |
| Need help ASAP with smoking engine problem! PLEASE HELP! | DJS_02_WRX | Newbies & FAQs | 14 | 10-10-2009 09:59 AM |
| Hybrid engine builders please come... | rs_two_five | Normally Aspirated with bolt-on Forced Induction Powertrain | 36 | 06-29-2006 12:33 AM |
| Engine Builders, please help me out! | tmarcel | Factory 2.5L Turbo Powertrain | 82 | 10-28-2005 10:58 AM |
| Engineers/Architects, please help. I need you to figure out some angles for me | Eric SS | Off-Topic | 43 | 05-17-2004 05:11 PM |
