Old 04-10-2009, 10:35 PM   #1
cooleys04
Member#: 145027
2004 WRX FP Green
MFactory/2Tone/built 205
Default OEM head gasket vs. Aftermarket
I've done some research and can't find any decent information on what difference (if any) exists between the factory hg and aftermarket hg's as far as ability to hold boost. I'm building an ej20 with 8.5:1 cp pistons, eagle rods, acl, etc. My plans are to eventually run a turbo comparable to a fp red @ 20-25psi. I'm going to be buying an OEM full gasket set and am wondering whether I really need to buy a set of cometics when I'll already have a set of OEM hg's. Any input?
cooleys04 is offline   Reply With Quote
Old 04-10-2009, 10:54 PM   #2
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
I prefer to run the subaru head gskts whenever possible unless I need a thicker gskt then I will use a cometic and its usually with a sleeved and o-ringed set-up.I have personally seen the stock hd gskts hold 35 psi no problem but that was with ARP studs of course.
john 1badSTI is offline   Reply With Quote
Old 04-12-2009, 12:42 PM   #3
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
^ agreed. I have cometics but that was only to bump down compression
Fongers is offline   Reply With Quote
Old 04-12-2009, 01:39 PM   #4
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Stock headgaskets with ARP studs work better in 99% of the Subaru applications out there.
wrxwhat is offline   Reply With Quote
Old 04-12-2009, 11:52 PM   #5
cooleys04
Member#: 145027
2004 WRX FP Green
Awesome, thats what I was hoping to hear. Thanks guys.
Tuning shops still recommend OEM head gaskets. Max Umbarger Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 33 06-22-2009 02:55 AM
subaru updated 4 layer head gasket vs. all others madmax718 Service & Maintenance 2 01-06-2009 07:03 PM
Socal: Brand New STI oem head gasket set methaddict Engine/Power/Exhaust 2 10-11-2008 04:51 PM
Brand New STI 100mm oem head gasket set methaddict SCIC Private Classifieds 1 10-11-2008 04:50 PM
Old head gaskets vs new 4 layer ones White2.5GT Normally Aspirated Powertrain 10 03-25-2004 07:54 AM
