Old 04-10-2009, 11:22 PM   #1
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Default STi factory head gasket specs?
I am curious on what the factory STi headgaskets measure at in the bore? I know factory bore size is 99.5mm but I am more interested in if these will work with a 102mm bore? I know they arent made for them and I know of many 100mm setups with them so is there enough room to squeeze over the 102mm.. Thanks..
I know cometic sells thier gaskets to fit but I have heard better experiences with the factory gaskets...
Sinister redlines is offline   Reply With Quote
Old 04-10-2009, 11:41 PM   #2
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
I think the bore on stock sti gskts is 101mm.you will need to run cometics if you have a 102mm bore.
john 1badSTI is offline   Reply With Quote
Old 04-11-2009, 12:08 AM   #3
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
So my question is, will the .5mm overhang be an issue in the bore? As long as the comp ring is on the sleeves? .5mm = about .020"
Old 04-11-2009, 11:39 AM   #4
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I'm pretty sure the stock headgaskets are more like 100mm, but then again I have not seen one of those for such a long time. Pick one up from the dealer and measure it.
Why don't you want to run Cometic's which you can custom order with any bore size and thickness? I have a set of 102mm / 0.051" sitting in my garage right now which I was going to use if I bored to 101.5mm for some custom pistons I have. No issues with Cometic's with me.
A small overhang as you describe I think is fine, a bigger overhang is just asking for failure
mick_the_ginge is offline   Reply With Quote
Old 04-11-2009, 01:16 PM   #5
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
you really do not want any of the gskt to hang into the bore because itwill cause a hot spot which will promote detonation.
Old 04-11-2009, 01:25 PM   #6
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Ya, you probably dont remember but you tuned this car about 2 years ago LOL. Anyway I have the BC 2.71L with the 102mm bore and I will probably just get the cometics like you have and probably that thickness too. Where is a good place to get them? Tim will be tunning the car as he did my gt35 tune last time.
04 sti oem head gaskets 2.5rsTurbo Engine/Power/Exhaust 3 04-29-2010 10:09 AM
Socal: Brand New STI oem head gasket set methaddict Engine/Power/Exhaust 2 10-11-2008 04:51 PM
STI 07 head gasket part number PLEASE DJIMPREZA Private 'Wanted' Classifieds 3 02-13-2008 12:29 PM
(ebay)05 STI Factory Head unit. 6 disc changer. 3 months old! Davenow Private 'For Sale' Classifieds 3 08-18-2005 10:27 AM
STi Factory Head Unit Specifications Frank Zuccarini Car Audio, Video & Security 5 05-21-2004 05:34 PM
