Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-16-2002, 04:04 PM   #1
suberboy
Member#: 1531
2008 GRB
Red
Question Will the WRX turbo back fit on a GC8 motor swap?
I am about to do a motor swap and am wondering if a WRX turbo back exhaust system will fit on my '93 Impreza?
Thanks!
suberboy is offline   Reply With Quote
Old 04-16-2002, 04:11 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Well, I can tell you right off that the middle muffler mount location is off a few inches, but it should still work. Not sure about the trans. crossmember fitment, though.
Old 04-16-2002, 04:27 PM   #3
suberboy
Member#: 1531
2008 GRB
Red
So you have tried some exchanging already. If you don't mind me asking what is your set up right now?
By the way do you mean the hanger is off by a few inches or the way the pipe bends?
I will be swapping to a turbo cross member so that might help.....
If it is just the hangers that are not in the right place it would be an easy swap
I just need a WRX to pull the exhaust off of so I can do a little comparison testing.
Old 04-16-2002, 04:35 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Well, I've seen tailpipe sections put onto RS's, not sure about the midpipe, but it looks the same to me. The DP should be ok, but I'm not sure... the body line might be different under there.
My current setup? Stock other then a clutch & flywheel. Previously Ludespeed stg. II/III turbo'd... had a bit of an engine management problem, not to mention a few others (unrelated to the kit).
Old 04-16-2002, 04:41 PM   #5
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
The WRX Turbo back exhaust will fit, I have it on my car. I'm also using the WRX midpipe.
The entire section does fit, though due to the Legacy uppipe that I am currently using, the downpipe sags a little causing the exhaust to hang just a bit (maybe an inch or two) lower than stock. The nice thing about this type of setup is that it costs nothing! I paid $120 for my turbo-back exhaust.
Oh, and you will need to have an O2 sensor welded in. Mine is right before the cat in the downpipe, no CEL either.
I'm also using the turbo crossmember.
Graham
Graham is offline   Reply With Quote
Old 04-16-2002, 05:39 PM   #6
suberboy
Member#: 1531
2008 GRB
Red
Thanks Complex and Graham.
Graham,
That is an awesome deal for a turbo back. Did you have to have any of the hangers moved or did it fit right on? Also what year is your car and did you do a motor swap or a turbo kit?
Thanks again.
Old 04-16-2002, 08:53 PM   #7
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
I did a turbo kit on my MY01 RS. As far as having to change the hangers and what not, I think you do, but a fabrication shop put it in for me so I can't be sure. Oh, also, I have a 2.5" Stromung axle back muffler that had to have a flange rotated to accomodate the WRX rear section.
Graham
Old 04-16-2002, 11:37 PM   #8
RimRockaz
Member#: 2947
2000 GC6 ej20 swap
fast n furious pt III
Suberboy,
I am using full wrx exhaust system on my hybrid right now. I don't think the hangers were changed.
Cal
RimRockaz is offline   Reply With Quote
Old 04-17-2002, 03:35 AM   #9
suberboy
Member#: 1531
2008 GRB
Red
Cal,
What car did your EJ20 come out of? I am wondering because I am getting a Japanese version and want to know if the stock location of the turbo conflicts with the steering asemblie at all? Maybe that is a dumb question but I was thinking the turbo might be, imagine you are sitting in the car, on the left side instead of the right side.... Hmmmmmm, just trying to keep the surprises to a minimum when I get the motor.
Thanks
Old 04-17-2002, 10:30 PM   #10
adamsrs
Member#: 3768
I have a lEgacy Turbo setup in my car (same as WRX) and i am running a GDA PDE downpipe (www.pde-usa.com, or www.spimotorsports.com) and an HKS Carbon Ti Catback from a GDA too! I dont have it in my car, but I wil let you know if it fits tomorrow!
adamsrs
adamsrs is offline   Reply With Quote
Old 04-18-2002, 12:27 AM   #11
suberboy
Member#: 1531
2008 GRB
Red
Thanks Adam. Please do let me know if it fits.
Thanks
Old 04-18-2002, 03:16 PM   #12
RimRockaz
Member#: 2947
2000 GC6 ej20 swap
suberboy,
my motor is USDM 2002 wrx motor. IIRC, the JDM ej20 turbo is located at the right side as well. with JDM motor, you need to re-route the steering assembly from right to left. man, thats going to be a lot of work! wow.. good luck man.. but once you are finished, you car will fly! JDM motors are just that much faster! NICE!
good luck,
Cal
Old 04-19-2002, 10:29 PM   #13
adamsrs
Member#: 3768
Just installed my PDE downpipe on my GC8. FITS like a glove!
adamsrs
Old 04-20-2002, 11:23 AM   #14
suberboy
Member#: 1531
2008 GRB
Red
Thanks for all the input everyone. Sounds like there won't be any problems using the WRX exhaust. Now do any of you know how much different the exhaust off an'01 Japanese STi is compared to our WRX's exhaust? I'm wondering if the pipe diameter is any bigger, and if it has the same number of cat's or? There is an '01 STi turbo back exhaust for sale for a decent price and I'm trying to figure out if it is worth as much as they are asking....
Will a WRX cat-back fit my 1999 GC8 slidell Normally Aspirated Powertrain 6 12-22-2005 11:21 PM
What Models of Subaur's will the WRX OEM Wheels Fit on? Sports Wagon Tire & Wheel 3 06-12-2005 09:21 PM
will a wrx wagon susp fit on a 98 out back sport? David Glasscock Brakes, Steering & Suspension 5 09-11-2003 06:24 PM
Will the WRX intake manifold fit on the ej25 heads? Impreza Rider Normally Aspirated with bolt-on Forced Induction Powertrain 25 01-20-2002 12:33 AM
will the mrt turbo headers fit on my01 rs? akcel Normally Aspirated with bolt-on Forced Induction Powertrain 16 11-04-2001 08:57 AM
