Old 04-16-2002, 04:35 PM   #1
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Default SOHC heads on a phase 1 block q's
OK... So I'm about to get my greasy paws on a phase II complete engine for my turbo project. I currently have a DOHC phase I engine in my RS. My project specs call for a phase II block and my DOHC heads that are currently on my car, so I want to swap the heads so my DOHC heads are free to work with. Will I have any issues running the SOHC heads on a completely otherwise phase 1 setup? Any computer problems? And do the SOHC heads have 1 or 2 exhaust ports? Will I have to source a '99 or greater exhaust header?
Thanks!
Chuck is offline   Reply With Quote
Old 04-16-2002, 05:47 PM   #2
8Complex
Member#: 922
04 FXT
Red
I think the exhaust manifolds are different and I know that the intake manifold is different and won't clear if swapping to SOHC from DOHC.
Old 04-17-2002, 09:27 AM   #3
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
I had NO problems using my 97GT headers on my new SOHC engine . . . You will be fine. As for the heads, 8Complex is right. You cannot use the DOHC intake manifold/throttle body with the SOHC heads and vice versa. Everything else, however (block to ANY set of heads), lines up fine.
In a word, yes. If you're gonna use the DOHC ecu with the newer SOHC heads . . . you will NEED TO SOURCE other parts!!!
Search for a thread under my username for Project Frankensubie and you'll see what I mean.
Jason
2.5GT is offline   Reply With Quote
Old 04-17-2002, 01:33 PM   #4
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Cool... I took a look at your Frankensubie thread and have some questions...
The TPS... how do they differ? Is there a possibility of a little rewiring to get the SOHC TPS to work with my DOHC ECU? This would relieve any other issues regarding the TB.
The Cam Angle Sensor... perhaps seeing this one makes it easier to understand. Which part are the teeth that the CAS reads on? Are they part of the cam sprocket, or on another random pulley that the belt rides along?
Thanks!
I see that you're from College Park.... I'm down there every other weekend visiting my gf at school.
Old 04-17-2002, 10:37 PM   #5
bobjr94
Member#: 6176
85 Brat,95 Impreza
05 Baja- Blue,Red& Purple
the cam and crank sensors are the same on all subaru motors, sohc or dohc, that will be no problem...you can swap the throttle body between the 2 intakes, giving your same tps as before...the idle air valve is different though, on the dohc its in the manifold, on the new sohc int in the throttle body...
bobjr94 is offline   Reply With Quote
Old 04-18-2002, 02:14 PM   #6
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
I was under the assumption that the crank/cam sensors were in fact different between the model years. Something like 2-tooth vs. 7-tooth designs. I swapped them out, just to be sure. As for the thottle bodies . . . I know FOR A FACT that my DOHC throttle body DOES NOT bolt onto the SOHC intake manifold.
Jason
Old 04-18-2002, 02:57 PM   #7
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Ack... I think it'll just be easier to find someone who wants to trade a set of brand new SOHC heads for a new or slightly used set of DOHC heads.
I'll have to set that up when I get my engine into my greasy hands.
Thanks all!
EJ22 phase 2 heads on phase 1 block WoodsWagon Built Motor Discussion 5 11-07-2011 05:54 PM
Phase II SOHC heads on EJ257 markf4e Built Motor Discussion 13 11-18-2009 08:28 PM
2.5rs sohc heads on a ej205 block. midnight2.5rs-t Subaru Conversions 2 03-09-2008 09:07 PM
Who has put 2.5l DOHC heads with a phase II block? linsavy Legacy Forum 17 05-31-2007 01:02 AM
Run phase 1 dual port 2.2 heads on a phase 2 single port 2.2 block? wagonovsky Subaru Conversions 12 03-01-2006 10:27 AM
Message Board Statistics All times are GMT -4. The time now is 04:43 PM.
