Old 04-11-2009, 10:51 AM   #1
vokalize770
Member#: 160735
02 WRX wagon, WRB
XPT Stg 2 w/GMBCS
Default High Mileage suspension - how can I make it feel younger?
My car has 131k mi on the clock and my suspension is stock except for swift wagon springs, which I really like a lot. Great handling and great looks. At first they were also a great ride, but recently my car's suspension has been feeling and sounding a bit clunky and loose. I had a blown CV joint before and the clunking does not sound like that. I plan on updrading struts to DSpecs or AGX's but I am curious how much this will help ride quality over bumpy roads. What other suspension components should I replace/upgrade to stiffen things up a little and make the ride a bit smoother so it doesnt sound like the car is going to fall apart over some bumps?
vokalize770 is offline   Reply With Quote
Old 04-11-2009, 01:12 PM   #2
jay3737
Member#: 100057
'12 Regal GS
'93 MR2, '11 Foz
with that many miles, the oem dampers have to be shot. replacing them (as you are planning to do) will make a big difference.
also, i would recommend that you start examining various bushings and replacing/upgrading them as necessary...if they are 7 or 8 years old that have to be worn out also...
good luck!
jay3737 is offline   Reply With Quote
Old 04-11-2009, 01:54 PM   #3
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
new aftermarket bushings will make big improvements over new stock bushings, so they should be much better than your old work out ones. cheaper than OEM replacements in most cases, too.
How Can I Make My Low Beams Stay on With the High Beams? subarumafia700 Interior & Exterior Modification 3 09-24-2009 02:54 PM
how long can you make it through?(emo warriors) Handsdown Off-Topic 29 01-23-2006 11:03 AM
Versus said my car is the least JDM looking Subaru, how can I make it look more JDM? JDM addict Member's Car Gallery 130 09-16-2005 08:08 PM
How can I make my wagon handle like if it were on rails? MikalsWRX Newbies & FAQs 10 04-27-2004 11:59 AM
How far can you make it in a "McJob"? 4x4GGG Off-Topic 10 08-21-2003 04:08 PM
