Old 04-11-2009, 11:30 AM   #1
EJRex
Member#: 119024
2004 Impreza WRX
San Remo Red
Default Performance EJ20 Build - Project 205
Well after some debate whether to install the 2.5 or go a different route, I came across a hell of a deal on some STi and EJ205 parts.
I've always liked being the underdog/outcast, so I'm staying 2.0 for the time being. I've pushed the stock EJ205 to it's virtual limits, so now I'm going to see what the 205 can do when it's built.
This isn't a typical move for most, and info about the 205's potential when built isn't easy to find, so I'm going to build one.
First off, got a used 205 short block for 50 bucks. 30K miles, broke an oil ring, but never damaged the walls.. the cross-hatching is still visible, so the walls can just be honed/de-glazed and all's well.
Next I scored a set of used complete heads w/shimless buckets for 200 bucks. 27K miles, the owner had spun a rod bearing.
Then I got a deal on a set of slightly used STi cams for 150 bucks, from a wrecked 06 (these are hollow but in excellent shape).
So all that for 400 bucks.
Now for the goodies.. CP forged pistons, 8.5:1, with rings, wrist pins & locks, 500 bucks.
Cosworth Rod and Main Bearings, 170.
Full engine gasket set, 230.. Head bolts, 95.. Timing belt, 115.
No pics yet, but installing STi rods ($100 pull-offs) water pump (87 bucks) and oil pump (102) as well. I'm able to reuse my tensioner and crank pulley, and all accessories.
I won't be reusing the A/C system though.. I'll be removing all those components for weight reduction and less rotational mass.
Ok so add it up and you get 1799. Machine work will run approx 200, so we'll say 2000 for a complete, well built EJ205. I'll still be using the ported 20G, but may install the GT3076R kit I saved for the 2.5.
The labor will be done by me, so that's more I can save. I'll keep this thread posted with more stuff as I go... let's see what this little engine will do.
EJRex is offline   Reply With Quote
Old 04-11-2009, 12:24 PM   #2
stay_cold
Member#: 187425
2007 VF39'd EWG'd
DPS tuned street machine
Subscribed. I'm working on a similar project I wanna see your results
stay_cold is offline   Reply With Quote
Old 04-12-2009, 12:30 PM   #3
EJRex
Member#: 119024
2004 Impreza WRX
San Remo Red
Some more photos of the build. WRX heads with STi cams. 3 angle valve job, resurfaced, slight port and bowl work, new valve guides, stem seals, locks and retainers.
AVCS holes in STi cams must be filled in/welded shut for use in non-AVCS EJ205 heads.
STi rods and CP pistons fitted, ringed, and ready to install.
Cylinders honed, standard bore.
Cosworth rod and mains installed.
Everything is going well, the heads and block are assembled and ready to install. Gotta set up a time to swap engines- should be by next weekend.. then a tune and back to the track for some drastically improved times, hopefully.
Will post more pics as I go.
Old 04-12-2009, 02:21 PM   #4
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Subscribing. Looks like a sweet build - may be following in very similar footsteps soon.
zeropsi is offline   Reply With Quote
Old 04-12-2009, 03:23 PM   #5
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
Nice build! What crank did you go with?
jay
illmatic is offline   Reply With Quote
Old 04-12-2009, 07:15 PM   #6
EJRex
Member#: 119024
2004 Impreza WRX
San Remo Red
^ Well I'm not exactly sure.. it's a 2.0 crank, but is forged and has chamfered oil holes.. I assumed it's a 205 crank, but someone else said it was a 207.. but the engine is together now so I can't really go back and check it out..
Old 04-12-2009, 10:20 PM   #7
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Either should be strong enough for quite a bit of HP, the difference, I suppose, would be to what RPM you can spin them and still have effective oiling.
CKxx is offline   Reply With Quote
Old 04-12-2009, 10:32 PM   #8
charliew
Member#: 125304
That looks like moly wheelbearing grease you used for assembly lube. Surely not.
charliew is offline   Reply With Quote
Old 04-13-2009, 12:17 PM   #9
b00stedPin0y
Member#: 70977
2004 STI
Very interesting thread, subscribed. Will be doing a similar build, very interested in how your will turn out.
b00stedPin0y is offline   Reply With Quote
Old 04-13-2009, 12:33 PM   #10
GDB FAN
Member#: 105814
+1
cant wait to see it finished.
GDB FAN is offline   Reply With Quote
Old 04-13-2009, 02:32 PM   #11
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
for closing off the AVCS holes, an 10-32 tap, set screws and some lock-tite get the job done in a non-permanent (if you so choose) fashion
Also no worries of putting heat into the camshaft.
Old 04-13-2009, 05:51 PM   #12
EJRex
Member#: 119024
2004 Impreza WRX
San Remo Red
LOL noooooooo
It's assembly lube.. graphite I think.
Old 04-13-2009, 05:55 PM   #13
EJRex
Member#: 119024
2004 Impreza WRX
San Remo Red
Good info.. I have heard of plugged holes leaking after a while though.. dunno if that was user error or the pressure is too great for those tiny plugs..
I didn't want to take a chance so I welded them. The MIG didn't heat up the cams much at all- took less than a minute to cool fully, and the holes are permanently closed (more for my peace of mind).
Old 04-13-2009, 06:36 PM   #14
Homemade WRX
Member#: 33782
96 bastard child
if you afriad of leaking lock-tite also makes another compound (can't recall its name/ Part#) that does well with liquid sealing for applications such as this.
Same stuff Darton sends out with their sleeves.
Old 04-16-2009, 06:29 PM   #15
EJRex
Member#: 119024
2004 Impreza WRX
San Remo Red
OK - finally got eveything together, torqued and taped, and ready for install this coming weekend. Some more pics for ya.
CP pistons installed.
Driver side head and valvecover installed. Installing cam seals.
AVCS holes MIG welded shut, and finished smooth. Very easy and quick job, and easy to smooth down with a small air sanding disc.
Finished longblock, ready for install. Oil and water pump will be installed when swapping accessories over.
Gonna try to install the enigine over the weekend, but we'll see how that goes. Will post some more pics later.
Old 04-16-2009, 09:44 PM   #16
LRZ03WRX
Member#: 182377
Very nice! I am excited to see how she runs. I have been undecided about doing a ej205 build, but this has peaked my interest. The STI rods bolt right it, no problems?
LRZ03WRX is offline   Reply With Quote
Old 04-16-2009, 09:48 PM   #17
kelley05
Member#: 174596
2005 WRX
I have a very similar short block set up. The STI rods do indeed bolt right in with no issues. Im using stock STI rods in my ej205 short block. There a really good upgrade without the expense of aftermarket rods.
kelley05 is offline   Reply With Quote
Old 04-21-2009, 01:52 AM   #18
b00stedPin0y
Member#: 70977
2004 STI
Any updates on the build? really eager to see any progress.
Old 04-21-2009, 02:35 AM   #19
EJRex
Member#: 119024
2004 Impreza WRX
San Remo Red
Had to postpone the install.. had some serious storms pass through this past weekend.. knocked out power for a while and made a mess of things around town, so I've gotta clean up a little bit and then I can get back to it.
I'll keep the thread posted as i go
Old 04-21-2009, 03:23 PM   #20
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Subscribed to this one as well.
CoolRex is offline   Reply With Quote
Old 04-22-2009, 03:04 AM   #21
EJRex
Member#: 119024
2004 Impreza WRX
San Remo Red
^ haha.. quit stalking me you psycho
Old 04-22-2009, 08:23 AM   #22
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Haha
Old 04-22-2009, 02:04 PM   #23
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Should be fun, what turbo?
slowmike is offline   Reply With Quote
Old 04-22-2009, 02:05 PM   #24
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
As he already posted....tdo6 20g
Old 04-23-2009, 11:11 AM   #25
khellen9
Member#: 66784
2004 PSM WRX
18g & EWG'd
Subscribed, I'd like to see how this turns out.
khellen9 is offline   Reply With Quote
closed deck ej20 build problem illgod Built Motor Discussion 9 11-02-2007 05:42 PM
EJ20 build Scooby Rex Built Motor Discussion 3 07-26-2006 02:38 PM
NJ Legacy EJ20 Wagon Project Finished RUBEN Tri-State Area Forum 11 04-11-2006 05:47 AM
EJ20 build up WRX Ver.7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-15-2002 09:46 AM
1995 Impreza EJ20 Rally project snwbrder206 Vancouver Impreza Club Forum -- VIC 4 12-09-2001 06:13 AM
