Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 04-16-2002, 04:39 PM   #1
phucvtec
Member#: 16261
2000 Impreza 2.5RS
Blue Ridge Pearl
Post Quick CEL question
Ok, quick CEL question: If I have a CEL associated with the wide band O2 sensor (2nd O2 sensor in line) reading irregularly, will this cause my vehicle's ECU to run in open loop mode (preprogrammed fuel maping)? If so, what can be done.
This syptom is a result of purchasing a Random high flow cat from Cobb Tuning, which I was forwarned about, so Im not complaining, just trying to understand my vehicle better. Perhaps someone else here has had the same problem and has dealt with it some how. An inline resistor perhaps? Thanks!
phucvtec is offline   Reply With Quote
Old 04-16-2002, 05:25 PM   #2
jeffg
Member#: 2958
2001 WRX (GC8)
I have had this same CEL light for quite a while, and I am pretty sure the car does not run in open loop preprogrammed mode.
does anyone know for sure?
jeff
jeffg is offline   Reply With Quote
Old 04-16-2002, 05:48 PM   #3
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
I can almost guarantee you have a P0420 Catalyst Inefficiency Code. If so, adding some kind of a resister between ECU and rear O2 would help. The car doesn't run in open loop. Someone was selling that here a while ago.
tmat3 is offline   Reply With Quote
Old 04-17-2002, 03:07 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
sounds like you have an O2 sensor slow response code...no it doesn't run open loop for that...it will however decrease your performance slightly...wrap the section of the pipe between the flange and the cat...it'll fix it.
jeremy
Old 04-17-2002, 01:39 PM   #5
spiralsmurf
Member#: 16085
2005 STi
i got this code on sunday coming back from san francisco after getting my exhuast installed. i got it cleared and its been fine so far.
spiralsmurf is offline   Reply With Quote
Quick CEL question, any help appreciated compa Engine Management & Tuning 4 06-13-2004 02:45 AM
Quick CEL question mike270 Normally Aspirated Powertrain 7 01-25-2004 09:54 AM
quick cel question riceburner22 Newbies & FAQs 1 08-18-2003 03:52 PM
Quick CEL question code P0133 speedracer47 Normally Aspirated Powertrain 0 01-28-2003 03:57 PM
quick CEL question WRX_Aaron Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-13-2002 12:13 AM
