Old 04-11-2009, 01:14 PM   #1
mc2
Member#: 59992
1997 Legacy L EJ22
Default Can I reuse intake manifold gaskets?
mc2 is offline   Reply With Quote
Old 04-11-2009, 01:22 PM   #2
anthonywrx
Member#: 60276
2012 Chevy Malibu LT
03 WRX/STi hybrid sold :(
the few bucks for new gaskets is worth the headache down the road...just my opinion
anthonywrx is offline   Reply With Quote
Old 04-11-2009, 01:22 PM   #3
ruckus racing
Member#: 196844
1997 Impreza L
flat black/green
yes, if when removed, they are not torn or delaminated (layers splitting)
ruckus racing is offline   Reply With Quote
Old 04-11-2009, 01:45 PM   #4
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
reusing gaskets is a bad idea. They have been crushed once and formed to the unique shape and surface of the mating parts. once they have been *un-sealed* they dont have any more thickness to be re crushed and seal. thick metal gaskets may let you get away with a couple re uses but a paper gasket is a one time use. They are so cheap that there is no reason not to use a new one, anyway. IF you absolutely have to re use a paper gasket its a good idea to seal it with a fuel system thread and gasket lubricant like EZ-turn seal lube. Since there will be fuel in the intake chage as it passes that gasket, a fuel resistant compound is ideal. I put this stuff on all paper gaskets and metal/metal threads. it increases the gaskets life and pressure holding and allows the gasket to be removed later without tedious scaping and on threads it prevents galling and helps seal. A high temp RTV could work, too. But it tends to shrink over time so a leak may be likely down the road.
Old 04-12-2009, 06:37 AM   #5
mc2
Member#: 59992
1997 Legacy L EJ22
Thanks, i wanted to get it back together today and the dealership isnt open which is why.
Guess i'll just wait
Should I apply gasket sealant on intake manifold gasket? gopsu Newbies & FAQs 0 07-30-2009 11:54 PM
Reuse intake mani gaskets? Mactizen Newbies & FAQs 3 04-27-2007 10:13 PM
Intake manifold Gaskets? 2000vfr800 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-18-2002 01:21 PM
TB/intake manifold gaskets or seals? danci1973 Normally Aspirated Powertrain 1 09-29-2002 08:22 AM
Intake manifold gasket whoring around? Puckaveli Normally Aspirated Powertrain 5 07-09-2002 02:54 PM
