Old 04-11-2009, 06:46 PM   #1
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
Question p0440 only when tank is 1/2 full or less
this very odd and frustrating. It will pop out this code just about everytime I drive the car ONLY when there is less than 1/2 tank of gas.
The return line looks fine.
Anyone ever heard of this before?
cjfike is offline   Reply With Quote
Old 04-11-2009, 06:56 PM   #2
V8Slayer
Member#: 111565
1999 Legacy 2.5GT
2007 Legacy GT Spec-B
i would start by checking your gas cap, make sure it is on tight.
V8Slayer is offline   Reply With Quote
Old 04-11-2009, 07:09 PM   #3
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
It has been going on for 3 weeks now, I suppose I could replace the cap. I fill the car up once a week, and this week I have kept it above 1/2 full.
Old 04-11-2009, 08:56 PM   #4
massdrewski
Member#: 146681
Symptoms
You likely won't notice any drivability problems.
Causes
A code P0440 could mean one or more of the following has happened:
* The gas cap is not installed or working properly
* The purge solenoid has failed
* The canister is plugged and not working properly
Possible Solutions
With a P0440 OBD-II trouble code
, diagnosis can be tricky at times. Here are some things to try:
* Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
* Inspect the EVAP system for cuts/holes in tubes/hoses
* Inspect for damaged or disconnected hoses around the Evap purge solenoid
* Check and/or replace the sensor
* Check and/or replace the purge valve
* Have a professional use a smoke machine to detect leaks
massdrewski is offline   Reply With Quote
Old 04-11-2009, 09:01 PM   #5
massdrewski
Member#: 146681
Here is a basic diagram to give you an Idea. It will only show you how the system is set up. it might look a big different.
http://glasairproject.com/GlasairI/s...EG(H4)EVAP.gif
Old 04-12-2009, 01:23 AM   #6
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
It's not the gas cap. It doesn't come back umtil the tank is less than 1/2 full.
Thanks i will try the other stuff.
Old 04-12-2009, 06:41 AM   #7
mc2
Member#: 59992
1997 Legacy L EJ22
The EVAP system runs tests under certain criteria only.
I don't know them off the top of my head right now, but some criteria would include:
Fuel temp, Fuel level, driving speed, duration of trip, etc.
This is probably why it only comes on when the tank is at a certain level.
Are you just resetting the code each time with a OBDII reader?
mc2 is offline   Reply With Quote
Old 04-30-2009, 07:46 AM   #8
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
Default Update!
Now that the outdoor temp is up, no more codes. The car has run through 2 tanks of gas error free. I have an OBDII reader and find nothing.
Maybe the fuel temp sensor.
Old 04-30-2009, 02:35 PM   #9
massdrewski
Member#: 146681
Or you could do what I used to tell my customers when I sold Subarus "the best way to get rid of the problem is to buy a new car"
Old 04-30-2009, 02:44 PM   #10
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
or half empty, depending on how you look at it.
XanRules is offline   Reply With Quote
Old 04-30-2009, 07:48 PM   #11
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
Har dee har har. So glad you got your degrees at Donkey School.
Clutch slipping, only when car is not completely warmed up? SeriousInquiry Transmission (AT/MT) & Driveline 0 10-01-2009 07:08 PM
slipping clutch pack only when tranny is cold subygirl Transmission (AT/MT) & Driveline 13 12-05-2005 03:30 PM
"whining" in speakers/only when HU is off. Help! yakker Car Audio, Video & Security 3 06-10-2004 12:22 AM
hesitation only when engine is cold mofugga Normally Aspirated Powertrain 8 03-21-2004 12:21 PM
Squeaking sounds only when clutch is engaged... jey Legacy Forum 12 09-25-2003 07:32 PM
