Old 04-11-2009, 07:19 PM   #1
gossin
Member#: 190451
Default aftermarket clutches... Anyone?
Im trying to find some aftermarket clutches for my car, the search engine sucks and i cant find anything online. Everything is for the wrx or the STI. Can anyone help me out a little bit?
gossin is offline   Reply With Quote
Old 04-11-2009, 08:54 PM   #2
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
why would you want an aftermarket clutch? Stock ones are more than good enough..
PS: fill your profile...
Old 04-11-2009, 11:11 PM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Clutchnet.com can custom make a dual diaphram pressure plate good for 550 torque when used with a 6 puck. I like it, although it is a bit harsh on the flywheel....
Old 04-11-2009, 11:35 PM   #4
Bluefoton
Member#: 141373
2008 2.5i-hatch -
^ yeah, well with your 18wheeler torque....
Old 04-12-2009, 01:09 AM   #5
rougeben83
Member#: 115154
2005 Outback XT
White on grey
its called the transmission forum for a reason.
And the most I would go on an n/a subaru is an ACT street or Exedy stage 1 clutch. yes, even modded ones.
rougeben83 is online now   Reply With Quote
Old 04-12-2009, 10:02 AM   #6
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
...even on an SVX with a 5-speed swap? I'm looking at their Stage 2 pieces for torque handling.
LetItSnow is offline   Reply With Quote
Old 04-12-2009, 10:10 AM   #7
stilover01
Member#: 207516
2008 chevy s10
dark green..
Talking
haha good point.
stilover01 is offline   Reply With Quote
Old 04-12-2009, 10:56 AM   #8
whopkins5
Member#: 177933
2006 Impreza Wrx
Crystal Grey Metallic
Default spec clutches
all wrx clutches work perfectly with 2.5 na subarus. I have a 2.5i as a daily and put a SPEC stage 2 clutch and flywheel in it. It has been about a year and no problems at all.
whopkins5 is offline   Reply With Quote
Old 04-12-2009, 11:16 AM   #9
rougeben83
Member#: 115154
2005 Outback XT
White on grey
My 274ft/lbs at the wheels is being held down fine by my ACT street clutch
only on the newer models do some share the same pull-type transmission. Most of the older n/a's use a push-type so the clutches are not interchangeable.
Old 04-12-2009, 12:12 PM   #10
LetItSnow
Member#: 38222
'10 &'12 Foresters
So we're clear: I'm not trying to contradict you. How long have those ft/lbs been held down fine, fwiw?
The torque capacity rating I've read for the Stage 1 clutches from Exedy and ACT is soundly below my 250ish (crank) ft/lbs, which is what raised my question. The Stage 2 gear looks to hold enough by the numbers.
My wallet surely prefers the Stage 1 merchandise, but I do drive the thing hard and autocross it, and changing a clutch isn't quite like changing an air filter.
Old 04-12-2009, 02:45 PM   #11
rougeben83
Member#: 115154
2005 Outback XT
White on grey
A little over a year now, with about 7k miles with that power level, with a couple of autox and rallyx events thrown in. I had about another 8k miles and a few more events on the clutch before that but I was still relatively stock.
But clutch selection not only has to be about the power capacity, it also has to do with how you will be driving the car. If you're going to be launching pretty aggressively on a regular basis, you'll need the more aggressive clutch, at the expense of some civility in day to day use.
I'm pretty easy on the clutch to begin with, and I usually roll into the boost on my starts at events, plus I would rather have the clutch slip than something more expensive in the drivetrain break, so I chose stick with the clutch I have now.
Old 04-12-2009, 05:04 PM   #12
VIsubi
Member#: 187834
06 2.5i impreza
Red
if its just the clutch or material clutch wheel a wrx but if its the pressure plate and what not a wrx's is totally different and yeah ACT sells one even a stage 2 if your going force induction then go with a stage 2 its when you get to double clutch's that your right foot maybe get a work out lol but you'll be fine with a stage 1 or 2 yes the stock is an EXEDY but can wear quickly with power or even power with slippage...
VIsubi is offline   Reply With Quote
Anyone near Doylestown w/ Aftermarket clutch? bredto Tri-State Area Forum 0 10-11-2006 02:46 PM
Clutch Shudder on aftermarket clutch/flywheel. firedog25 Transmission (AT/MT) & Driveline 9 02-07-2005 02:09 AM
Thinking about aftermarket clutches now that clutch is slipping kgb Transmission (AT/MT) & Driveline 10 02-14-2003 07:44 AM
Whats a good aftermarket clutch that isn't too stiff on the clutch pedal edkwon Transmission (AT/MT) & Driveline 6 09-09-2002 11:15 PM
Opinions on Aftermarket Clutch & Flywheel EddyRS Normally Aspirated Powertrain 2 06-13-2001 09:33 PM
