Old 04-11-2009, 08:30 PM   #1
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Default Engine Build Spreadsheet attached - PLEASE LOOK
I created a spreadsheet for those who want to track everything to do with your engine build.
Here is a link for it, I really need someone to have a look at it and let me know if it works the way you would like it to work.
Thanks.
Password is "1234"
Excel 2007 or newer version below:
http://www.teamscream.net/Scooby Log...rksheet-L.xlsx
Excel 2003 or newer version below.
http://www.teamscream.net/Scooby Log...rksheet-Lx.xls
Basically you input all of your measured data into the YELLOW cells in the sheet, and the sheet will use this information to calculate your compression ratio and a few other things for you.
These are all measurements that you would be taking anyway if you are building an engine, so this way you can enter that data in this sheet and have a permanent record of that build, And you don't have to do a bunch of math to figure out your compression ratio.
I have one small change I want to make.....see post #8 for the details.
Team Scream is online now   Reply With Quote
Old 04-12-2009, 06:07 PM   #2
Team Scream
Member#: 121532
2006 FXT/STi 6MT
Default Created one Let me know what you think.
Ooops double post really,.
Old 04-13-2009, 11:04 PM   #3
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
This looks like it would be really useful. I don't know how it works.
XanRules is offline   Reply With Quote
Old 04-13-2009, 11:08 PM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
This is what you would call "BLUE PRINTING." .....I think.
FuJi K is offline   Reply With Quote
Old 04-13-2009, 11:09 PM   #5
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Oh man. My engine build is mostly me buying parts, laying them out, bouncing ideas off people, and hoping everyone else knows what I'm talking about.
Old 04-13-2009, 11:45 PM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I'm gathering my parts as we speak. I have a '05 Legacy NA upper manifold coming in this Wednesday to go over '06 WRX TGVs. JDM 12mm oil pump sits next to my pillow. I'll be picking it up from the Dealer this Thursday morning before taking one of the ported STi head to get flow tested. Should be an awesome morning!!! I'm excited to see how horrible I did on my port job with that head.
Old 04-13-2009, 11:51 PM   #7
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Here's my insane project.
http://forums.nasioc.com/forums/show....php?t=1707369
Twin Turbo 2.5L.
Old 04-13-2009, 11:55 PM   #8
Team Scream
Member#: 121532
2006 FXT/STi 6MT
I am still working on making it a little better, with instructions for example
Anyway, you fill in all of the information in the yellow areas.
The spreadsheet will do the calculations for compression ratio, and if I am correct in my formulas it uses everything to give you true static compression ratio with one exception, and that is it does not account for the volume between the top ring and the top lip of the piston.
I am going to add that cell so that the volume there will be calculated.
For now, it uses the top lip of the piston as the reference.....if that makes any sense.
The other items that are not used in calculations, are just part of the build sheet, and there so you can document the build completely.
If I missed anything, please chime in and let me know.
Also, the numbers that are already in some of the yellow cells is just data I input as an example.
Delete it all before you start your sheet.
DO NOT DELETE any of the numbers which are NOT in the yellow cells.....
I have not figured out how to lock those cells so the formulas wont get deleted.
****EDIT**** just figured out how to lock specific cells, got it done, download the newest version and toss the older one to keep you out of trouble.
Old 04-14-2009, 01:56 PM   #9
Team Scream
Member#: 121532
2006 FXT/STi 6MT
Ok I updated the sheet quite a bit.
I added a formula that calculates the valve stem to guide clearance and cleaned up a few other areas.
I really need a builder to look this thing over and tell me if it will work for them.
Thanks.
Link is in the first post.
Old 04-14-2009, 02:49 PM   #10
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Pretty cool Dauv. This would help us, a novice like me in understanding all of the important specifications that go into controlling the tolerances of an engine. Even if you're not the actual builder this gives us a guide instead of trusting that the machinist knows everything about a subaru motor. Still as a consumer you still have to be diligent and research the manufacturer's recommended clearances and go over it with your machinist. These recommended clearances will also be in a range. There are different effects of having tighter or looser clearances which should be determined by the your goals of your build and the predominant use of your car.
methaddict is offline   Reply With Quote
Old 04-14-2009, 07:23 PM   #11
SlickRick51586
Member#: 66735
2004 WRX
for the total displacement formula you have
=C62+D62+E62+H62
should it not be:
=C62+D62+E62+F62
I'm running open office so it could be an issue on my side.
SlickRick51586 is offline   Reply With Quote
Old 04-14-2009, 11:43 PM   #12
Team Scream
Member#: 121532
2006 FXT/STi 6MT
=C62+D62+E62+H62
should it not be:
=C62+D62+E62+F62
You are absolutely correct!
missed that one.
IT is fixed now, just re-download it and you will be good.
Old 04-15-2009, 03:25 AM   #13
howfast?
Member#: 102027
BugI Tsx retro lamps
for sale not listed pm me
Subaru Stars
Nice Dauv that build sheet is sick! I can't wait till I get to start filling it in
howfast? is offline   Reply With Quote
Old 04-15-2009, 06:02 AM   #14
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
which spread sheet?
xlsx extension?
Old 04-15-2009, 11:45 AM   #15
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
very cool! i am definitely going to use this.
what is the password so i can unprotect it and make some chances my self?
kevinh211 is offline   Reply With Quote
Old 04-15-2009, 02:31 PM   #16
bucket7788
Member#: 124263
2004 WRX Wagon
RomRaider + UTEC Tuned
Originally Posted by jaxscuby View Post
which spread sheet?
xlsx extension?
I'm wondering the same thing. Excel won't open it for me.
Buck
bucket7788 is offline   Reply With Quote
Old 04-15-2009, 02:37 PM   #17
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
xlsx is Office 2007 and above
mick_the_ginge is offline   Reply With Quote
Old 04-15-2009, 02:49 PM   #18
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yeah, I had to use my laptop to open it up...my desktop is still 03 format.
It looks pretty good to me but I didn't spend a lot of time poking with it. I'll have to do that later.
I must say, the one I made isn't nearly as 'pretty' with colors and all the borders. Gives me ideas that I've been needing to do. I need to make mine more 'professional' and print friendly.
Thanks for the motivation
Old 04-15-2009, 02:57 PM   #19
~snowman~
Member#: 207011
Thanks Team Scream!
~snowman~ is offline   Reply With Quote
Old 04-15-2009, 03:05 PM   #20
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
I got it open with Office 2003, but their was some update through windows i had to do to read the newier file types.
Old 04-15-2009, 05:27 PM   #21
Team Scream
Member#: 121532
2006 FXT/STi 6MT
Sorry guys, as soon as I have a minute I will save it as an Office 2003 file as well so those that are on earlier versions can play with it.
I am at work right now and do not have Office on this particular machine.
I should have thought of that.....
Old 04-15-2009, 08:59 PM   #22
Team Scream
Member#: 121532
2006 FXT/STi 6MT
Ok there are now 2 versions.
The first one is for Office 2007 or newer users
The 2nd one is for Office 2003 or newer users.
Both in the first post.
Old 04-16-2009, 12:15 AM   #23
bucket7788
Member#: 124263
2004 WRX Wagon
Thanks! I guess I should pry my wallet open for a newer version of Office.
Old 04-16-2009, 01:47 AM   #24
Team Scream
Member#: 121532
2006 FXT/STi 6MT
Or just download OpenOffice for free and run with it...!
Works like a charm for those that can live without Office.
Old 04-16-2009, 01:06 PM   #25
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Nice sheet.
CoolRex is offline   Reply With Quote
Engine build questions? Engine Builders help!! awdeclipseguy Built Motor Discussion 7 01-03-2010 03:54 AM
Looking for information on engine build CUNNINGHAM Normally Aspirated with bolt-on Forced Induction Powertrain 1 06-09-2002 04:19 PM
anyone have one of those dyno or engine build up software kits? funscooby Motorsports 0 01-17-2002 01:44 AM
SomeTorque specifications needed for engine build. DJIMPREZA Technical Forum Archive 2 09-20-2000 11:51 AM
Tech Section Update - SOHC Engine Build Trey Technical Forum Archive 27 07-04-2000 12:26 AM
