Old 04-12-2009, 12:14 AM   #1
legacydreamz
Member#: 92423
2007 Honda CRV
and dolphins and s**t
Default 2.2l n/a with wrx manifold? fitment issue...
i tried to bolt on my wrx manifold, but the coolant hose and thermostat cover/coolant elbow were obstructing the manifold...
do i need the wrx coolant elbow and hose or am i doing it wrong somehow?
legacydreamz is offline   Reply With Quote
Old 04-12-2009, 12:18 AM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
need the turbo waterpump\
Old 04-12-2009, 12:31 AM   #3
legacydreamz
Member#: 92423
2007 Honda CRV
ishtty but my pump is leaking slowly so it need to get done along with my cam seals and crank seal while i have the timing belt off so whatever.
do i need the coolant outlet too or will my stock one bolt up?
Old 04-12-2009, 12:42 AM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I "think" the stock one bolts up.... But not 100%
Old 04-12-2009, 01:37 PM   #5
master c
Member#: 168226
stock coolant elbow will bolt but it will be facing the complete opposite way you want
you need a turbo water pump with the METAL elbow - while you are in there you should get a gimmik cooler thermostat. your stock lower radiator hose does not need to be modified to run the turbo water pump either so its a win win. after you get the water pump swapped the manifold should work perfectly. you will also need to cap off 2 of the nipples on the water pump because the turbo version has nipples for an oil cooler that uses coolant, which im guessing you dont have so they will need to be capped
master c is offline   Reply With Quote
Old 04-13-2009, 12:08 AM   #6
legacydreamz
Member#: 92423
2007 Honda CRV
could i use those nipples for the turbo coolant feed/drain?
Old 04-13-2009, 12:15 AM   #7
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Thats what they are there for.
2.2L exhaust interchangeable with 2.5L exhaust parts? dcarr1971 Normally Aspirated Powertrain 5 03-16-2011 02:45 PM
1998 impreza L 2.2l turbo *now with fmic*!!!!! turbo'98L Private Vehicle 'For Sale' Classifieds 53 08-22-2007 09:22 PM
lowered Legacy w/ Wrx wheels fitment issues? Trin_Starr Legacy Forum 13 12-07-2005 06:13 PM
WRX Manifold Fitment SCOOBER Normally Aspirated with bolt-on Forced Induction Powertrain 28 02-02-2004 12:29 AM
did the 2.2L ever come with a keyless entry system? SubaruImpreza_power Newbies & FAQs 5 04-11-2003 10:31 PM
