South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 04-12-2009, 12:51 AM   #1
pimpininaz
Member#: 88362
2007 WRX Limited
SATIN WHITE PEARL
Default all you Gurus! turbo upgrade help/question
so its time to make the bump from the stock turbo, ive been researching the best bang for the buck route here and am leaning towards a 20g. right now the car sits with a 3" TBE, intake, ap2.
its an 07 wrx, my question to the gurus is what supporting mods will i need for a 20g? i'd go e85 but in flagstaff thats not feasible
i was thinking FMIC, upgraded injectors just not sure how big..... so to all you suny gurus..... WTF do i need lol?
pimpininaz is offline   Reply With Quote
Old 04-12-2009, 01:25 AM   #2
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
I would say some 700/750cc injectors and just about any fmic would be fine. You could probably get away with a little smaller, but I wouldn't. A good tune is key. There are a few "tuners" in SWIC, then there are a few tuners. I would recommend Mark (brocksdad) as a tuner if you can get to the valley
For injectors and FMIC send a PM to Evil Performance. He is good people and takes good care of the locals
v8eaterWRX is offline   Reply With Quote
Old 04-12-2009, 03:02 AM   #3
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
Whats you power goal? What is your plan with or how do you use the car?
If your going to stick with it as a daliy driver then 20g and fmic is a little laggy. Maybe a 18 and a STi or APS type tmic is better. STi tmic are quoted to be good for 400 hp. Up north you dont have the heat like down in the valley. So I'd stick with the tmic and enjoy the quick spool.
I would look into a true ball bearing turbo like a 1820
or something like a 18g, vf43
A bigger then wrx tmic and a water spray kit. OEM Sti or APS TMIC with the cusco water spray controler works killer.
You should be able to keep your blue injectors and just run a wally 255 pump
Bigger then those turbos then bump to some dtwks 740's That way you have room to grow later.
06STi is offline   Reply With Quote
Old 04-12-2009, 03:32 AM   #4
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Wirelessly posted (LG Voyager: Mozilla/4.1 (compatible; MSIE 6.0; ) 400x240 LGE VX10000)
^^ I'm pretty sure the VF43 and the 18g are not ball bearing turbos...
Old 04-12-2009, 03:35 AM   #5
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
Ah... I thought the 43 was at least. But they are still great turbos to be had.
fixed..
Old 04-12-2009, 11:50 AM   #6
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
The stock 565 injectors will not be good for any turbo above a VF39/43/48. You will need at least 750s or my suggestion is to get 850s.
blkscooby is offline   Reply With Quote
Old 04-12-2009, 12:04 PM   #7
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
I ran a pe1820 on stock 06-07 wrx injectors with 75-80% idc still made 310 whp and 335 wtq
Could I have made more? I tried a set of pe 850's and gained nothing but less money in my wallet, I ended up going down to the 740's enjoying the power and gas mileage. I'm getting 275 miles per tank on the freeway and about 255-260 in town.
My 740's might be working well because I have aftermarket fuel rails. Which have more fuel loaded to the injectors open point.
I would install the pump, fpr and tune / log, Then if the idc's run 90-95% then upgrade.
Old 04-12-2009, 02:14 PM   #8
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
Stock wrx injectors on a 20g........
Dude you NEVER cease to amaze me.......
Old 04-12-2009, 02:20 PM   #9
ChandlerWRX06
Member#: 184206
2013 X1 sDrive 28i
gray
850cc on a 20G. . . you'll actually be able to enough a huge jump in power
ChandlerWRX06 is offline   Reply With Quote
Old 04-12-2009, 03:19 PM   #10
fullerswrx
Member#: 104405
2005 Legacy GT
Teh WhItEnEsS
im getting ready to do the 20g myself. im gonna run deats 740's, walbro 255, and definitely ext wastegate i have a front mount though. then again its going on my leggy.
fullerswrx is offline   Reply With Quote
Old 04-12-2009, 03:28 PM   #11
2TG8V
Member#: 67335
2015 wrx
My old set-up 20g with Nismo 740 's
2TG8V is offline   Reply With Quote
Old 04-12-2009, 05:08 PM   #12
Evil Imports
Member#: 14732
+ 13 B8
you are joking?? i hope so
Evil Imports is offline   Reply With Quote
Old 04-12-2009, 05:14 PM   #13
kpluiten
Member#: 120273
06 WRBWRXWGN
I think he means for e85, Jay. Also, did you dig up a vf39 for me? Thanks.
Old 04-12-2009, 05:37 PM   #14
Evil Imports
Member#: 14732
+ 13 B8
well since the OP says its not feasible for him to go E85, why would anyone be talking about it
Ken, we can talk about a VF39
Old 04-12-2009, 05:48 PM   #15
kpluiten
Member#: 120273
06 WRBWRXWGN
Oh, I missed that. Reading > me.
Old 04-12-2009, 06:12 PM   #16
blkscooby
Member#: 44422
2009 G8 GT
Well, maybe out here where it is warmer but back in MA I would not recommend anyone do that. Its amazing how much more air you can pull when is <0F!
Old 04-12-2009, 06:23 PM   #17
EviL Performance
Vendor
Member#: 116912
04 STI
PurpLe
Back in NJ there was no problems with running pinks/06wrx injectors with a VF39/30/34
EviL Performance is offline   Reply With Quote
Old 04-12-2009, 07:29 PM   #18
ChandlerWRX06
Member#: 184206
2013 X1 sDrive 28i
gray
considering the sti has no problems with the vf39 and factory injectors. . . sure bigger might be get you some better results in the cold, but eh.
Old 04-12-2009, 07:29 PM   #19
NAZSTI
Member#: 164516
2004 STI
pimpininaz...I suggest talking with a “Real Tuner” and tell him the goals you would like to achieve.
NAZSTI is offline   Reply With Quote
Old 04-12-2009, 07:31 PM   #20
ChandlerWRX06
Member#: 184206
2013 X1 sDrive 28i
gray
yea dont talk to a Reel tuner though. . .
unless you like fishing.
Old 04-12-2009, 07:48 PM   #21
NAZSTI
Member#: 164516
2004 STI
"yea".......ummm,yeah.
Old 04-13-2009, 01:07 AM   #22
pimpininaz
Member#: 88362
2007 WRX Limited
SATIN WHITE PEARL
thanks for all the help guys! can any of the "real tuners" tune on an AP? i had travis tune my old wrx and dyno comp tuned this beasty already.
do the reel tuners use spinner baits?
Old 04-13-2009, 01:24 AM   #23
kpluiten
Member#: 120273
06 WRBWRXWGN
Sell the AP for 500 bucks and get an open source tune from Mark (Brocksdad) for 200 bucks. From what I've heard, and the last two cars I rode in that he tuned, he does good work. I'm serious, sell the AP, go see Mark @ Mark Jones Tuning.
Old 04-13-2009, 03:02 AM   #24
brocksdad
Member#: 107352
Not Respectable
I would use at least 750's with a 20g. That should give you plenty of fuel. If you were to need a little more, you can always get an aftermarket pressure regulator or crush the stock one.
brocksdad is offline   Reply With Quote
ECU question [for all you gurus] kellie00 Texas Impreza Club Forum -- TXIC 3 04-17-2006 09:49 PM
TURBO VENDORS / COMPANY Listings - All Venders offering Turbo Upgrades for WRX's Hotrodguru Private 'Wanted' Classifieds 1 12-18-2003 08:23 AM
Turbo Vendors / Company Listings - All Vendors offering Turbo Upgrades for WRX's Hotrodguru Texas Impreza Club Forum -- TXIC 4 12-17-2003 03:32 PM
