Old 04-12-2009, 05:46 AM   #1
INFMIS
Member#: 174494
Default oil pressure reading, help
Hey i have a new built motor, was priming the oil pump the other day by disconnecting injectors and coils and no spark plugs just cranking the engine over. i was holding 80psi oil pressure.
Is this what it should be?
Thanks
INFMIS is offline   Reply With Quote
Old 04-12-2009, 11:07 AM   #2
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Sure I guess... wait what are you trying to accomplish here man?
Fongers is offline   Reply With Quote
Old 04-12-2009, 11:12 AM   #3
novacivic
Member#: 117980
2005 sti
wr blue
sounds right for a cold engine during cranking
novacivic is offline   Reply With Quote
Old 04-12-2009, 11:26 AM   #4
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
yeah my freshly built motor with a shimmed pump holds 80 while cranking. 100 idling cold and about 35 idling warm. When its warm its at 90-100 at anything over 2k rpms.
turboL is offline   Reply With Quote
Oil pressure reading, help INFMIS Impreza Forum 0 04-12-2009 05:45 AM
oil pressure readings/gauge choice help..... 1QUICKMF Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 11-06-2004 09:41 PM
Oil pressure readings on 2.2L n/a ? blkwag Normally Aspirated Powertrain 0 09-27-2002 01:41 PM
Oil Pressure readings and other problems! SpooledRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-11-2002 11:34 PM
getting oil temp from oil pressure reading? initialWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-05-2001 05:18 AM
