04-12-2009, 05:53 AM | #1 |
Member#: 207726
GC Radiator In a GD?
Anyone know if the GD fans and mounting points would work with a GC radiator? Reason I ask because when one switches to a thicker core the top hose gets closer to the Alt pulley even after trimming it. The GC radiator hose doesn't exit/enter in the middle like the GD does.
Plus it looks alot cleaner!
04-14-2009, 05:11 AM | #2 |
Member#: 207726
to the top!
04-14-2009, 10:02 AM | #3 |
Member#: 15822
Vehicle:1999 WRB GM6 2.34 LR destroker |
the mounting upper points are different but it's not hard to make two new holes
06-20-2011, 03:20 PM | #4 |
Member#: 203438
Vehicle:2002 WRX PSM |
Bumping for an answer. I've searched and found no conclusive answer. I'm looking to put a GC radiator in my 2002 WRX.
Are the brackets the only thing that will require modification? Will my stock fans fit? I know the upper hose is different...but what about the lower hose; can I use the stock lower hose? |
06-20-2011, 04:17 PM | #5 |
Member#: 159682
NESIC
Vehicle:1995 WRX 2015 F150 |
You could if you wanted to. You'd need to drill new holes in the upper core support, trim the lower hose a bit, use the gc upper brackets, gc upper hose, overflow and fans. Your fan motors and blades would fit actually, but the fan housings are different.
06-20-2011, 05:33 PM | #6 | |
Member#: 203438
Would it be possible to modify my fan housings to fit the new rad? or is it totally necessary to get the GC housings? I will probably be making my own upper brackets, so I'm not shy of a few modifications to the fan housings. |
06-20-2011, 06:42 PM | #7 |
Member#: 159682
NESIC
Maybe, but they are different.
06-20-2011, 09:33 PM | #8 |
Member#: 1305
AKIC
Vehicle:2000 Impreza |
I'm still running a GC radiator with my GD into GC swap but have the GD motors and fans swapped into my fan housings like 69subaru360 describes. Fan housing mounting is different. I'm sure somebody could make it work with enough modification, but it was easier for me to just swap the motors since I had all the parts.
06-21-2011, 10:26 AM | #9 |
Member#: 3190
Vehicle:2004 Impreza TS and the Suxass racing mobile! |
I have a fuidyne radiator in my GC with stock wrx fans. Trimmed the upper radiator hose and no clearance issues whatsoever.
Eby, This is on your old 94 L. It has treated me well! Still got the 99? jake |
06-21-2011, 08:53 PM | #10 |
Member#: 1305
AKIC
Nice, I was curious what happened to that chassis.
Now I have a 2000 L and did a full 04 STI swap. |
06-21-2011, 09:23 PM | #11 |
Member#: 3190
Clear your inbox! It is full.
jake |
06-21-2011, 09:42 PM | #12 |
Member#: 1305
AKIC
Clear
04-29-2012, 11:58 AM | #13 |
Member#: 153412
Vehicle:1998 Impreza wrxRS Black |
Can anyone help me out?
I'm doing the opposite, using a gd rad in my ej205 swapped gc? |
04-29-2012, 05:02 PM | #14 |
Member#: 3190
Thats what I have. A fluidyne and fans meant for a GD. The only thing I did is used the GD upper mounts and drilled new holes in the core support to use them. It was also neccesary to trim the upper and lower radiator hoses to fit.
jake |
04-29-2012, 08:23 PM | #15 | |
Member#: 153412
Can u use a bolt after u drill it? |
04-29-2012, 09:31 PM | #16 |
Member#: 3190
I put a nut on the bottom of the new holes.
04-29-2012, 10:01 PM | #17 |
Member#: 153412
Will a bolt w/ a nut that's not welded on work?
04-30-2012, 12:59 PM | #18 |
Member#: 159682
NESIC
04-30-2012, 02:09 PM | #19 | |
Member#: 153412
That's wonderfull, my ac is gone, so that'll make it easier |
gd radiator in a gc? | cavakilla | Subaru Conversions | 3 | 04-29-2012 03:08 PM |
GC rear seats in a GD? | erich | Interior & Exterior Modification | 6 | 06-11-2009 06:44 PM |
How to: Mishimoto Radiator into a GD STi | Mishimoto | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 06-08-2009 11:06 AM |
GC radiator cover in blue or yellow | M E R C U R Y | Private 'Wanted' Classifieds | 8 | 09-10-2004 11:47 PM |
?Mystery u-pipe in front of radiator of LHD GD imprezas? JDM experts... help | satrya | Newbies & FAQs | 1 | 04-12-2004 10:58 AM |
