Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 04-12-2009, 12:59 PM   #1
Harsesis
Member#: 141785
Default 2.0 to 2.5l block swap questions
I have an 04 wrx that has developed a rod knock. I am looking at putting in the 2.5l sti block in it's place, and looking for tip and tricks for the swap.
Current mods on the 2.0l are vf39, sti intercooler, aem cold air intake, turbo back exaust, pinky injectors, cobb accessport stage 3 map. Will my current map work swapping to the 2.5L sti block. It appears that my compression will be raised to around 8.8, from stock. I don't know/feel that this will be an issue since I am only putting 17-17.5psi of boost with the current map.
Which headgaskets need to be used? The stock 2.0L or the stock sti headgaskets?
Any help would be appreaciated.
BTW vehicle currently has right at 100k on the set-up(stock modded set-up)
BTW I work at a subaru dealer and want to stick to stock parts for the swap due to warranty and ease of getting parts.
Thanks
Joe
Harsesis is offline   Reply With Quote
Old 04-12-2009, 01:09 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
d0000000000d
this whole thing is covered here somewhere
find it and read it
Old 04-12-2009, 01:17 PM   #3
WRXINTX
Member#: 96712
Thanks
Joe
If you work at a dealership, you should probably already know that Subaru will not warranty a 2.5L shortblock when installed into the place where a 2.0L was.
Use stock STI 2.5L head gaskets and all other stock 2.0L parts will bolt on to the 2.5L engine.
And no, your current tune will not be anywhere close for a hybrid swap engine block.
WRXINTX is offline   Reply With Quote
Old 04-12-2009, 03:10 PM   #4
DemonPossessedNinja
Member#: 116610
2005 wrx vf-34
psm
stock sti headgaskets will have high compression.
most shops recommend using a thicker headgasket like cometic
DemonPossessedNinja is offline   Reply With Quote
Old 04-12-2009, 07:10 PM   #5
Harsesis
Member#: 141785
I work at a dealership and know what I can and can not get/have warranted as I have been working on Subarus for 20 years. I just haven't been through the hybrid swap yet and was looking for answers not a pissing war.
I have searched and found several different answers on the headgaskets ranging from the stock 2.0 to the 257 to the original 2.5L cometic style gaskets. I was looking to see if this has been setteled to date. Also as far as the mapping goes I was wondering if the stage 3 would be ok.
Old 04-12-2009, 07:33 PM   #6
eurynome
Member#: 180160
2006 wrx
obsidian black
if you worked for subaru for 20 years why dont you already know all the answers
eurynome is offline   Reply With Quote
Old 04-12-2009, 07:36 PM   #7
Harsesis
Member#: 141785
Maybe you missed this part
Old 04-12-2009, 08:23 PM   #8
98foreza
Member#: 200552
98 forester
Dont you think it would be much more easy to just answer the questions asked? Unless you have a car of your own we don't get many chances to figure out all these hybrid motor questions at the dealership. This is the whole reason for this section of the forum.
98foreza is offline   Reply With Quote
Old 04-13-2009, 10:54 AM   #9
DerickRyoung
Member#: 178050
02 hybrid-wrx
psm
ppl w/ comments like this need to hit up a teen chat room ?
DerickRyoung is offline   Reply With Quote
Old 04-13-2009, 12:09 PM   #10
98foreza
Member#: 200552
98 forester
Amen to that
Old 04-13-2009, 11:54 PM   #11
B-Kerr
Member#: 14841
2002 Impreza WRX
WRB, VF22, Cusco, Unichip
Honesly eurynome, don't be a prick. I am putting looking at putting a Legacy GT 2.5 in my wrx and I have owned a salvage yard for many years... I would like to know the answer too, and I don't know everything about the swap. Obviously you don't either or you would have been nice enough to help.
Demon... know the cheapest place to find a cometic?
Does anyone know off the top of their head the difference in compression between a stock STI and a cometic?
B-Kerr is offline   Reply With Quote
Old 04-13-2009, 11:57 PM   #12
B-Kerr
Member#: 14841
2002 Impreza WRX
Also, now that I look at it... where does the STI get the extra 50hp over the Legacy GT? Same block and heads according to my interchange...
Old 04-14-2009, 05:54 PM   #13
98foreza
Member#: 200552
98 forester
The lagacy is the exact same setup other than the tuning. I believe this where
you lose the extra power. It will come to life with a tuner
Old 04-14-2009, 05:55 PM   #14
98foreza
Member#: 200552
98 forester
So I guess no one is going to set us straight o this head gasket fiasco?
Old 04-19-2009, 02:59 AM   #15
zzooozz
Member#: 195733
I'm going through this same issue right now with my 03 rex. And the answer on the head gasket is a 1.5mm gasket. And you will need a new tune. From what I've been told, the torque will be higher. The price isn't that much more either.
zzooozz is offline   Reply With Quote
Old 04-21-2009, 03:13 AM   #16
keithdsny
Member#: 83757
2002 02 wagon hybrid
WR blue pearl
I'm interested in this too!!... I did the 2.0 heads on a stock ej257 block with stock STi gaskets and would love to know the Compression Ratio as well. This will help pe to decide what turbo to put in.
keithdsny is offline   Reply With Quote
Old 04-21-2009, 04:14 AM   #17
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Whoa so much mis-information and information all wrapped together!
Lets get everyone on the same page here, they hybrid swap (basic) is either a ej257/ej255 dropped into a wrx (2.0) power train, retaining the wrx's heads ect. There have been swaps done with using different blocks (22t, ej251) which you can find good write up's on rs25.com. Ok now that being said on to some minor flaming, and not to be a dick but some is due.
Search people, everyone says it but honestly **** like this is why. Everything you could possibly want to know is documented on this swap, all you have to do is dig a bit for it, honestly EVERYTHING is documented.
Now that being said find a compression calculator to adjust your cr back closer to stock level's if you arn't going to tune it yourself or take it to a tuner... just an fyi, don't expect the block to last without a proper tune my man, when you add .5l of displacement you ecu can't learn around it, some people have run without tune's however if it was my 2k sb there is no way in hell i'd ever ever ever run without a tune.. but thats me.
So, to answer some of your questions,
Head Gaskets are based off of bore, being a mechanic this seems like a no brainer to me, but i won't tell you how to fix subaru's and you won't tell me how to do my job! , Everything else will bolt right up, imo drop in a 12mil pump and shim it!
1. RESEARCH!@
1.5 Drop in the SB
2. Get a tune
3. Enjoy
And i plan on doing something similar to what fujik did, this kid has done more homework than i probably ever will, i'm impressed!
http://www.rs25.com/forums/showthrea...ght=2.5+hybrid
907Bum is offline   Reply With Quote
Old 04-22-2009, 02:45 PM   #18
B-Kerr
Member#: 14841
2002 Impreza WRX
907Bum: We appreciate any and all input. However, as you said, there is always a wealth of information and MIS-information available. This why we ask questions. We know that a 2.5 gasket is needed... the questions is Cometic (a/m) vs STI (stock). For DSMs, I have heard of Cometics slipping is head is not prepared absolutely to a certain mil. And C/R is an issue of course.
There is plenty of info on NASIOC, but some of it is out-of-date. For example, I bought my car new in 02. I am running a VF22 and a Unichip! This is an antiquated set-up today, but you can still find info on it. A person would be crazy to go this route today if they stumbled upon the post... but it could happen. Regardless, I am happy with my 330 engine hp! An STI gasket was probably the best bet for this swap 2 years ago - is it now? Are better things out there?
As for the research, I search until my eyes hurt, but I do not always find what I need - even on here. Sometimes its easier to ask; that's why we are here - to help one another modify and destroy perfectly good means of transportation! I still have not found a definite on which axles to use in my 05 LGT tranny to 02 WRX swap and I have search for a week! Guess what I did today - I posted and asked for input.
I don't think anyone with a brain would modify any car without a tune, but it never hurts to say it as you did (and I definitely agree). Which is a entirely different ??? What tune to use... ECUtek? Utec? AEM? Unichip (doubt it)? Hydra? ROM Raider (which I am currently looking into...)? You can research til you go crazy. Sometimes however, you can contact a real person, not just an old post, that is running a set-up and get realtime answers.
1. Everyone should know to search; but we get overwhelmed.
2. Old questions get, yes, OLD.
3. Old information may be bad information.
4. TUNE YOUR ENGINE!
5. Let's all helps each other out - have to beat the DSMs!
Old 04-24-2009, 01:54 PM   #19
xrturbo
Member#: 86298
98 LGT Wagon
Full WRX driveline & dash
I recently contacted cometic about the headgasket question for a 255 hybrid I will be putting together and they told me they have a big bore 2.0 gasket with multiple thickness options.
xrturbo is offline   Reply With Quote
Old 04-24-2009, 08:16 PM   #20
98foreza
Member#: 200552
98 forester
Hey! useful information thank you
Old 04-24-2009, 11:32 PM   #21
xrturbo
Member#: 86298
98 LGT Wagon
Here is a copy from their response:
Actually you would need to run the EJ20 head gasket with a larger bore in it. It would be our part number: H1633SP2XXXS. The XXX indicates the thickness, so for a .040" thick gasket, the part number would be H1633SP2040S.
Old 04-25-2009, 10:01 AM   #22
B-Kerr
Member#: 14841
2002 Impreza WRX
Very cool to know! Hmmm, so keep a smaller turbo and go thinner gasket, or go bigger turbo and thicker gasket I suppose.
Old 04-30-2009, 08:48 PM   #23
Harsesis
Member#: 141785
Ok swap performed using the ej25dohc headgaskets(95-early99). After being intouch with Cobb and then being refered to Cobb Tuning of Plano TX. The answer to the question is yes the vf39 stage 3 tune would be adequate to drive on. Yes it will need to be tuned, but it can be driven on this map. The recommended to put 1000-1500 miles on it before taking it there for the tune.
Old 05-01-2009, 08:37 AM   #24
xrturbo
Member#: 86298
98 LGT Wagon
Sweet!! How does it run? What did you do for the dual/single breather issue? Catch can? Keep us posted on how it works!!
2.0 to 2.5 swap questions own3db Subaru Conversions 15 06-06-2009 12:38 AM
2.0 to 2.5L with blown 2.0 ecu????? AUTO DjKlown UTEC 1 11-20-2008 07:58 PM
2.0 to 2.5 block swap SLO_02WRX Subaru Conversions 2 11-06-2006 09:39 AM
Yet another 2.0 to 2.5 sti block ? serious Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 12-22-2003 03:24 PM
2.0 to 2.5 block swap, what's the ideal Compression ratio? 516_WRX_V2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-25-2003 12:44 AM
