Old 04-12-2009, 05:25 PM   #1
Rei_Akira
Scooby Scammer- Do Not Buy From User
Member#: 194555
1997 GC8 coup
green
Default EJ20K suction pipe question
ok, so removed my intake manifold to get it re-powder coated that beautiful red color, and noticed that the suction pipe is torn around the area where it attaches to the turbo.
so the question, i dont think this will cause problems since its an area that should be mated directly to the turbo, but does anyone have suggestions on a new suction pipe i can pick up?
Rei_Akira is offline   Reply With Quote
Old 04-12-2009, 05:55 PM   #2
suberdave
Member#: 101865
88 GL-10 STi
suberdave is offline   Reply With Quote
Old 04-12-2009, 08:32 PM   #3
Rei_Akira
Member#: 194555
1997 GC8 coup
green
i hate buying things from ebay >.<*
id much rather get something from a reputable manufacturer.
Old 04-12-2009, 08:32 PM   #4
Rei_Akira
Member#: 194555
1997 GC8 coup
green
whoa double post madness!
Old 04-12-2009, 11:55 PM   #5
fishheadback
Member#: 68120
1998 RS 2.0 vf23 STi
& MK6 GTI
I know you would rather not ebay, but just incase your VER3-4 there is this one Ive been eyeing. They have black also.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=280292526861
I havent really been able to find anything other than stock except on ebay.
fishheadback is offline   Reply With Quote
Old 04-13-2009, 12:05 AM   #6
scrappydoo
Member#: 23630
97 v4 STi RA
Feather White, 02 WRX MBP
Originally Posted by suberdave View Post
That one will work, but it will be really, really tight. He'll need the one that's skinnier where it comes out from under the mani and bends toward the filter. It's hard to tell if the one fishhead posted is the right one, but when you look from the top you can tell it's a lot skinnier in that section. If you don't get the right one then the reservoir that sits where the hose exits will eventually cut into it.
Rei_Akira, you'll probably have problems because the tear is after the maf.
scrappydoo is offline   Reply With Quote
Old 04-13-2009, 09:32 AM   #7
linsavy
Member#: 11620
1997 GF4-STiV3 clone
I have a WRX stock pipe jammed into there currently. It is not a good fit but works. I have only seen these ebay one's for replacement. Those who tried them say they work Ok, but may not flow any better because the inner diameter is pretty much the same.
linsavy is offline   Reply With Quote
Old 04-13-2009, 10:25 AM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the first link is a ver5-6
i have one from autobahn 88 /zena racing
and its actually a very nice piece
this is the one you want:
blue red black
these guys are really good to deal with .. i have ordered from them 4 times now .. stuff gets here faster than if i ordered it from the east coast
order all the hoses while you are at it ...
Old 04-13-2009, 12:00 PM   #9
Rei_Akira
Member#: 194555
1997 GC8 coup
green
thanks Jaxx, once again you come in to save the day XD
Old 04-18-2009, 04:38 AM   #10
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
those look perfect for the 20k's... i may have to get one someday
elislider is offline   Reply With Quote
Old 11-02-2009, 04:23 PM   #11
stirs25
Member#: 181779
i bought one from autobahn as well for my ej-20k but it's way too tight of a fit. is there any alternative? something that'll work stock from a usa dealership? or any aftermarket piece is fine too.
stirs25 is offline   Reply With Quote
Old 11-02-2009, 06:49 PM   #12
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
what do you mean too tight?
i had to trim mine
Old 11-03-2009, 05:34 AM   #13
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
RUnning with a torn pipe causes the engine to run lean so be careful.
Marnix is offline   Reply With Quote
Old 11-03-2009, 07:55 PM   #14
lovemybaker
Member#: 129480
2006 WRX Wagon
I got the autobahn 88 one for mine, and I am never taking it off because its such a tight fit. Where it runs under the intake plenums and over the fuel rails, there is not very much room at all.
lovemybaker is offline   Reply With Quote
Old 11-04-2009, 12:31 PM   #15
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
I need one but with a 3in inlet...were those from eBay 3in??
Cbgrandtheftauto is offline   Reply With Quote
Old 11-04-2009, 03:13 PM   #16
trxdam
Member#: 93818
1999 Mazda Mx-5
Got jokes?
Not a 3 inch but gobs cheaper and better than those listed above(might be able to squeeze over a 3" or just get a adapter. I have a nice red one on my version iv right now. Samco version 3-4 turbo inlet $75 bucks shipped!!!! Holla!!!!!
trxdam is offline   Reply With Quote
EJ20K Re assembly questions. dr3w Pre-2002 Factory Turbo Powertrain 93 10-24-2009 12:02 PM
EJ20K / 257 Hybrid Questions Chacha Built Motor Discussion 1 09-27-2008 06:20 AM
EJ20K boost solenoid question Lachlan Pre-2002 Factory Turbo Powertrain 4 04-20-2007 11:05 PM
ej20k swap, clutch question bicanek Transmission (AT/MT) & Driveline 0 11-11-2005 02:05 PM
HKS Racing Suction Kit question? 2002WRX_5speed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-06-2004 01:21 PM
