Old 04-12-2009, 06:09 PM   #1
STI_KLR
Member#: 189660
'02 IAG BUILT 2.5L
Whistles go WOOOP WOOOOP
Default Dropped my Oil Pump
I was attempting to put my new STI oil pump on the new block, but realized the main seal got messed up putting it on.
I took it off and attempted to get the seal out of the oil pump but it slipped out of my hand and I dropped it onto a carpeted floor from about 4' up.
It now makes a slight "click" sound and if you give it a slight shake, you can hear the internals move around. I never checked to see if it moved before I dropped it, so is this a normal sound? Or have I just obliterated my brand new pump? Is there a way to check to see if it's ok?
STI_KLR is offline   Reply With Quote
Old 04-12-2009, 09:22 PM   #2
gto7419
Member#: 44256
2002 WRX Wagon
Open it up and see if everythings ok...
gto7419 is offline   Reply With Quote
Old 04-12-2009, 09:40 PM   #3
STI_KLR
Member#: 189660
'02 IAG BUILT 2.5L
ok. i guess i'll go ahead and do that.
Old 04-12-2009, 10:23 PM   #4
charliew
Member#: 125304
I really doubt dropping the pump on the carpeted floor hurt it. You are probably hearing the rotor shaking around in the housing although I don't remember it being loose enough to rattle. You will need to locktite the screws when you put them back in as a common problem is the back coming loose and the motor loosing pressure when the screws come loose. You should probably put some assembly lube in the pump on reassembly.
charliew is offline   Reply With Quote
Old 04-13-2009, 09:23 PM   #5
chicosubaru
Member#: 203675
unless theres a dent or something the pump is fine. its stout and carpet is soft. the rotor has slight play but shouldnt knock much. i second needing to use loctite on the screws anyway.
chicosubaru is offline   Reply With Quote
Old 04-14-2009, 09:17 AM   #6
dunk
Member#: 15359
You might need an impact screwdriver to get the back cover off. They can be pretty tight.
-Duncan
dunk is offline   Reply With Quote
Old 04-14-2009, 09:23 AM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
-Duncan
I second that highly!!
Grab a hammer and one of these http://www.sears.com/shc/s/p_10153_12605_00947641000P
makes like much easier. I use to use an impact screwdriver but after nearly stripping two screws found the old method to work much easier. They work great for the piston access plates on the back of the shortblock too.
Homemade WRX is online now   Reply With Quote
Old 04-14-2009, 12:22 PM   #8
STI_KLR
Member#: 189660
'02 IAG BUILT 2.5L
-Duncan
I used my buddy's Snap-on drill. My god...I had no idea they were going to be as tight as they were. I was almost balancing on the drill with all my weight because the bit kept wanting to strip the screw out (thankfully, I didn't strip any).
Everything seemed ok - nothing out of the ordinary. I compared it with my oil pump I took off the motor and everything matched up. I used loctite when I put the screws back in and used the drill to achieve this.
*fingers crossed*
Why is my oil pump dripping oil? scoobiekid86 Built Motor Discussion 40 04-22-2010 11:58 PM
Dropped my Oil Pump STI_KLR South East Region Forum 4 04-12-2009 09:40 PM
WTB: fujibond adhesive , my oil pump leaketh 2slofouru Private 'Wanted' Classifieds 12 08-16-2007 02:49 PM
How do I shim my oil pump? IllNastyImpreza Built Motor Discussion 13 03-09-2007 08:48 PM
How do I prime my oil pump? iNfEk Factory 2.0L Turbo Powertrain 7 02-17-2007 01:37 PM
Message Board Statistics All times are GMT -4. The time now is 11:52 PM.
