Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 12-20-2007, 03:38 PM   #1601
KC
Member#: 442
13 Crosstrek XV
00 S2000
I dont want to run in SP, because then I would have to buy diffs for the car, among other things, which I dont want to do. I
SP is for prepared STREET CARS. ST is for street cars with COMMON BOLT-ON and APPEARANCE Modifications.
You're going to be hard pressed to find someone that will agree with you that a larger radiator is a common street modification that fits the ST mold. Heck, just this past year, they took back the A/C delete rule for this very reason.
Ok, let's ask you this then... how would you write a rule in ST that allows aftermarket radiators, and have it fit the projected ST mold?
Remember, you have to have verbage in there that doesn't allow one to run one with less capacity or weight, because sure as **** I'd find the smallest radiator that I could run safely dropping 10-30+ lbs off the nose. It's only 2-3 min runs....
--kC
KC is offline   Reply With Quote
Old 12-20-2007, 03:53 PM   #1602
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
The new Fastrack has proposed language like that for SP:
http://www.scca.com/contentpage.aspx?content=78
.15.10.I
Engine cooling radiators may be replaced with alternate parts subject to the following restrictions:
1) Radiator core dimensions (width, height, thickness) must be no smaller than the standard part.
2) Radiator must mount to OE radiator mounts.
3) Fluid capacity of radiator must be no less than fluid capacity of the standard part.
Alternate radiators may serve no other purpose (e.g. to allow a cold air intake passage)..
As long as there was no way to get a performance advantage out of it for Solo I wouldn't mind, but that's the rub. Ask Tom what he would do
john
Old 12-20-2007, 03:57 PM   #1603
KC
Member#: 442
13 Crosstrek XV
00 S2000
Great! It looks like SP is where you would go just because of that added wording.
I just cannot see this being allowed in ST because it's not a common street mod. But that's just me.
--kC
Old 12-20-2007, 04:00 PM   #1604
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
--kC
Well I guess something like this: Stock radiators may be replaced with an after market unit, but must be done so with one of OE Style Design. The radiator may weigh more than the stock unit, but not less; if the after market radiator does weigh less than the OE unit, weight ballast must be added (i need to do some research to see how that could be done, and where).
Just threw that together quickly, but would work I think
Crash477 is offline   Reply With Quote
Old 12-20-2007, 04:01 PM   #1605
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
john
I like what he said!
Old 12-20-2007, 06:57 PM   #1606
lackofhp
Member#: 149001
09 Caliber
ex 07 WRX
I need someone to point and say "You belong in this class here ___"
Car 07 WRX
-TBE w/cats
-reflash/tune that has upped the stock boost
-KB SS with bushings
-F/R sways
-RCE Yellows w/STi Struts
-ALK
-Will have 225 tires as well
I ran ESP with just the TBE, EM and SS. Now that the rest is being added where do I go? I really thought I was still in ESP, but now I am told I should be in SM (where I will get toasted).
Thanks
Shawn
lackofhp is offline   Reply With Quote
Old 12-20-2007, 07:01 PM   #1607
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
SM I believe, because of the ALK, and higher than stock boost.
Old 12-20-2007, 07:20 PM   #1608
BIGSKYWRX
Member#: 7958
09 GH B+
boost is free in SP, but the ALK knocks you up at least to SM (I think some would argue Prepared )
Old 12-20-2007, 08:41 PM   #1609
Web Foot STi
Member#: 39086
2004 STi
If you consider the ALK a subframe mount then your in SM. If it is a suspension mounting point then you are in Prepared. However, IF you consider an ALK an offset bushing then you are in SP. The ALK is such a simple mod for our cars and major cutting and welding for others...
Web Foot STi is offline   Reply With Quote
Old 12-20-2007, 08:47 PM   #1610
Web Foot STi
Member#: 39086
2004 STi
Originally Posted by dstan View Post
The Stock people on the most part do not Track their cars,
what advantage is a larger Radiator and oil cooler in Autocross?? in fact it adds weight.
Wanna bet?
I would love run 2 piece rotors as the DS-2500 pads are not quite enough at the track. Instead I have to swap out to DS-3000 pads for the high speed stuff. I can't even easily run inexpensive Power Slot rotors in AS. Ouch $$$
Old 12-21-2007, 01:01 AM   #1611
Boxologist
Member#: 21118
whiteline ALK puts u in Prepared unless SEB came out with something recently.
Boxologist is offline   Reply With Quote
Old 12-21-2007, 11:14 AM   #1612
digitalseance
Member#: 104400
169k mile race car
you don't have to buy diffs to run in *SP. Sure they'll help, and a great deal, but WIDE tires and an insane spring rate is what is going to help you over the diffs. You can run the insane spring rates in ST but you can really take advantage of them in SP because of the race rubber.
Diffs are on my list, but the fact that the front diff install is almost as expensive as the diff itself, I'm holding off until probably 09 before dropping $4k on two diffs and the install. I'm focusing on wider wheels and tires followed by a race gas tune, both of which would be beneficial for TAs.
digitalseance is offline   Reply With Quote
Old 01-25-2008, 08:55 PM   #1613
curbait
Member#: 122249
may be I didn't try searching hard enough but I didn't find what class you would be in if you removed the front U shaped subframe and didn't replace it with anything.
curbait is offline   Reply With Quote
Old 01-25-2008, 09:10 PM   #1614
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
I would guess a prepared or modified class
Old 01-25-2008, 09:18 PM   #1615
curbait
Member#: 122249
so a 02 WRX might be in ESP?
Old 01-25-2008, 09:30 PM   #1616
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
Well yes, but I think with the subframe removed that would be in prepared, not street prepared. Like FP, or XP something like that.
Old 01-25-2008, 09:56 PM   #1617
digitalseance
Member#: 104400
169k mile race car
+1
I'm yet to figure out the difference in XP vs FP since the wrx and sti are both in fp and induction is unlimited as are motor swaps, iirc.
Old 01-26-2008, 04:47 AM   #1618
curbait
Member#: 122249
Ok thanks!
Old 02-19-2008, 11:57 AM   #1619
qcslvr30
Member#: 42041
2006 WRX STI
aspen white
Hey guys, What are your thoughts about the Perrin inlet hose? I requires that you tee the pcv valve into the existing vent lines that run from the head accross the front of the intercooler. Is that modifying the pcv valve? It still is connected to the same system of lines, just not in the exact stock location.
The other option is teeing the pcv into the vent line that runs from the intercooler to the inlet hose. Does that effectively retain it's function along the flow path?
What do you think, legal for STU or not?
James
Your thoughts?
qcslvr30 is offline   Reply With Quote
Old 02-19-2008, 01:34 PM   #1620
68Cadillac
Member#: 95901
I agree the ALK subframe mount replacement part put you in SM. But... Superpro offers an offset bushing that IS legal for even Street Touring classes.
68Cadillac is offline   Reply With Quote
Old 02-19-2008, 02:48 PM   #1621
Fred
Member#: 3560
06 STi, 02 STi
06 FXT, 94 rally car
So does Whiteline. It's called the KCA-375 bushing.
Fred is offline   Reply With Quote
Old 02-19-2008, 04:04 PM   #1622
68Cadillac
Member#: 95901
SuperPro makes Whiteline's poly-bushings. They're just make them yellow instead of blue. Superpro costs about half.
Old 02-19-2008, 04:30 PM   #1623
stoooo
Member#: 62289
When I bought mine, the Whiteline was marginally cheaper. Shop around. And yes, this is essentially the ST* legal ALK. Seems silly to me that we have to do it this way instead of just bolting an actual ALK into place. These are so much more labour intensive. But, I suppose, the part itself is cheaper, so it may just be a wash in the end.
Stuart.
stoooo is offline   Reply With Quote
Old 02-19-2008, 07:32 PM   #1624
BIGSKYWRX
Member#: 7958
09 GH B+
the bushing is nice as it offers an additional .5 degrees of caster and a firmer bushing, but no change to the factory anti lift/dive like the ALK
Old 02-19-2008, 07:47 PM   #1625
Web Foot STi
Member#: 39086
2004 STi
Stuart.
Silly to us in the Subaru camp that have an easy bolt on suspension pivot that can be relocated to an advantage. Not so silly to a LOT of other cars that SCCA has to write the rules for. They have to cut, weld, and do other PIA things to relocate a pivot other than an offset bushing. So, we all get the same allowance.
Be thankful that Subaru used a large diameter bushing that can accommodate a lot of offset...
Rules & Regs For Using This Forum **READ This First** Ferg NWIC Private Classifieds 0 01-13-2006 04:44 PM
New Local Forum Classified Rules *If you want to buy/sell something, read this first redobs New England Impreza Club Forum -- NESIC 0 11-16-2005 10:17 AM
WTB: K&N or equivalent flat filter PLEASE READ THIS FIRST kaisersouse Private 'Wanted' Classifieds 2 06-13-2005 04:47 PM
Thinking about an APS catback for your STI? Read this first. WRXIN Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 02-24-2004 09:36 PM
Looking for M2 Performance exhaust? Read this first! DailyDriver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-11-2003 09:16 PM
