Old 04-24-2009, 03:59 PM   #26
Steelworks
Member#: 209557
2009 Forester 2.5x
Originally Posted by LetItSnow View Post
Using a breather creates an opening in the system that makes your air meter incorrect - it properly measures its intake at its location, but not what actually enters the cylinder heads. The amount of difference is questionable, but it's guaranteed.
the air entering the heads is post filter, and MAF. So it is indeed metered air.
Steelworks is offline   Reply With Quote
Old 04-24-2009, 06:44 PM   #27
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
OK, I'll fix this for you:
Using a breather filter creates an opening in the system that makes your air meter reading incorrect - the MAF properly measures the air that passes it, but that's not the volume that actually enters the combustion chambers.
LetItSnow is offline   Reply With Quote
Old 04-25-2009, 12:31 PM   #28
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
your pcv is post combustion .
watchunglava is offline   Reply With Quote
Old 04-28-2009, 06:40 AM   #29
Steelworks
Member#: 209557
2009 Forester 2.5x
Sorry... I totally jumped the gun. Didn't see the part about a breather filter. oops
Old 05-27-2009, 12:40 AM   #30
unclemat
Member#: 114530
2005 LGT 6MT wagon
Originally Posted by dblotii View Post
Another reason not to remove the PCv valve is that if you remove the valve and block the PCV valve connection, you aren't actually ventilating the crankcase with fresh air. Remember that blowby gasses contain water vapor, Hydrocarbons and NOx. The water vapor and NOx degrade the oil much faster if there is no PCV valve (or orifice) to continually purge these substances from the crankcase (whenever your throttle is not wide-open). Your oil will sludge up and oxidize much faster without a PCV valve. Also the HC's in the blowby gasses are fuel that is best burned in the combustion chamber rather than just wasted.
Dave
Thanks for your contributions to this thread. Very informative!!!
What do you think about air/oil separators in general?
In particular there is one product - IXIZ that retains the stock PCV valve (on turbo car), so function under light throttle and intake manifold vacuum will be retained. However under boost the vacuum from intake inlet goes via the separator, so oil is caught there.
Sorry for bit of a thread hijack....
unclemat is offline   Reply With Quote
Old 05-27-2009, 10:19 AM   #31
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
You can just install a catch can...
Old 04-11-2010, 06:44 PM   #32
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Bringing this one back from the dead since it's been nearly a year since it was started. The whole catch can / air-oil separator thing is something I've thought about doing to each of my cars for a while and have never actually gotten around to doing.
So I was looking at how PCV/breather setup is arranged, and it seems a bit different than what was originally posted here. My understanding is that the newer cars (not sure what "newer" actually means) have the PCV valve located on the top of the block, below and to the left of the throttle body (as you're facing the engine from the front of the car). Is that correct?
On my EJ25D, the PCV valve is on the intake manifold. The PCV line runs from the PCV valve to that same spot on the block where I think the newer cars have the PCV valve located. Coming out of the crankcase, though, there's a Y - 1 hose goes to the PCV, and 1 goes to the intake (in the stock configuration it went to the torque box). So, I re-drew williaty's original diagram to show how mine is set up:
I put ???s next to the hose that is "extra" on my setup.
And here's a picture showing the various lines (can't see the Y at the top of the block, though - it's under the IAC, which is under the PCV).
So, I'm pretty good on how the PCV operates. But I'm confused about the purpose of the "extra" hose that runs from the top of the block/crankcase to the intake. At high load, with the PCV shut or nearly shut, the extra hose would provide an extra path (in addition the VC breather hoses) to port the blow-by gases back into the intake piping and then into the combustion chambers, so that makes sense. At low load, though, with the PCV in some sort of open position, it seems like the PCV would be sucking from both the crankcase and the intake, which doesn't make sense.
As far as I know there's no check valve in the Y that comes off the top of the block, but I guess I need to check that just to be sure. And as far as I know I have the various hoses hooked up correctly - I seem to recall with the stock intake, there were 3 connections on the torque box and 1 on the bottom of the intake tube. Later this week I'll probably be hitting the junkyard, and last time I was there they had a number of late 90s Legacys/Outbacks, so I can take a look at those to verify what I remember and verify the hoses are all supposed to route back to the intake tubing.
Any thoughts on that extra hose?
Patrick Olsen is online now   Reply With Quote
Old 04-11-2010, 08:57 PM   #33
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Well, one thing I noticed, the PCV will be open, always. It doesn't shut at high load. The pressure in the crank case will always be higher than the pressure in the intake tract so long as the engine is open. Does that change your thinking any?
Old 04-11-2010, 11:27 PM   #34
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Well, not really. When the PCV valve is closed (hypothetically) the flow paths all make sense. When it's open, I don't understand what the hose from the crankcase to the intake is doing, since it would seem that is allowing air to bypass the throttle plate by way of the Y that connects the crankcase hose and the PCV hose together.
Old 04-14-2010, 09:31 PM   #35
recnelis
Member#: 92778
2000 Impreza 2.5RS
Pat,
At least for the older cars, this is how the PCV system is supposed to work according these posted diagrams.
http://www.rs25.com/forums/f5/t10327...ml#post1648612
In short, that 'extra' port brings in fresh air at part throttle and acts as an additional vent at full throttle.
recnelis is offline   Reply With Quote
Old 05-11-2011, 08:29 PM   #36
evilWagon
Member#: 128739
07 2.5i SE Wagon
I'm not one for bumping an old thread, but this one I found particularly usefull. Also given that I've seen some more recent informative posts from Williaty on this topic, perhaps he wouldn't mind updating it with his current understanding?
evilWagon is offline   Reply With Quote
Old 05-11-2011, 09:28 PM   #37
GEE-OTTO
Member#: 201277
2009 Legacy GT
I disagree, only b/c someone has to
GEE-OTTO is offline   Reply With Quote
Old 05-11-2011, 09:44 PM   #38
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I've been informative? Dammit, I was trying to avoid that.
What is it you'd like to know?
Old 05-12-2011, 06:10 PM   #39
evilWagon
Member#: 128739
07 2.5i SE Wagon
I was wondering if you had any further understanding of the Pcv valve and it's usefullness beyond what was posted in the thread? Also I found this from a link when searching for info on catch cans and their usefulness on N/A cars. This was after I read your posts about the problems with the grimmspeed a/o separator (and any for that matter) on naturally aspirated cars. The strange thing I've found is that other horizontally opposed NA engines all come with some sort of aos. The boxter/911 does as do aircraft engines (or they vent to open air).
Old 05-12-2011, 06:39 PM   #40
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The PCV valve just seems to function as a flow rate limiter, not as an actual check valve.
Yes, boxer engines, regardless of who makes them, seem to have blow-by issues and need AOSes. Correct, the AOSes designed for turbo Subarus won't work properly on NA Subarus. To my knowledge, no one makes an AOS that works properly with an NA.
Old 05-12-2011, 08:23 PM   #41
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Well that should mean that ALL of us should be forced induction, right....
Anyway, good info.
~Josh~
Old 05-13-2011, 10:24 AM   #42
LetItSnow
Member#: 38222
'10 &'12 Foresters
If the PCV valve baffles you, how about the AOS?
The only thing I can compare them to is raking the leaves in your lawn.
Stock - Bring the leaves into your house and burn them.
AOS - Collect up all the leaves, then scatter them back over your lawn.
Catch can - Bag up the leaves and the town collects them at the street.
There's a lot of crap that comes through these hoses that I bet a lot of people aren't even aware of. It's more than oil and air - a lot of it is water.
Sure, the upshot of an AOS is that you don't get heaps of oil in your intake/intercooler/etc., but the cost is that you don't evacuate the water and assorted contaminants that are in the crankcase that you would with the stock setup.
Old 05-13-2011, 03:53 PM   #43
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
AOS is more like an automated robot that gathers the leaves up and puts them in the mulch pile for you.
With the AOS, you return the same amount of crap that you would through the PCV system. The PCV system returns to the intake tract in our cars. So you're just dumping that contamination you're worried about right back into the engine anyway.
Old 05-13-2011, 04:09 PM   #44
evilWagon
Member#: 128739
07 2.5i SE Wagon
I'm leaning towards a catch can, likely a Saikou Michi one.
That being said, I know Williaty you were looking into an AOS for NA but I read in a thread that you no longer needed it because you now has rings the fit properly, did you get a new motor or rebored? Also it looked like it had been some time since you've done it and you seem to drive your car hard, has the blowby oil past pcv valve issue returned? And if so did you do anything to resolve it?
Here's Porsches inexpensive N/A solution to it: http://www.autopartswarehouse.com/de...=ganfeed&gan=1
But apparently they fail... might be more reliable than the PCV valve itself though. They say they last 60K miles.
Old 05-13-2011, 05:11 PM   #45
LetItSnow
Member#: 38222
'10 &'12 Foresters
Re: AOS
Anybody who wants to dump this junk (the contents of my two catch cans, albeit supercharged) back into their crankcase over and over is more than welcome to, but I sure wouldn't.
Old 05-13-2011, 10:10 PM   #46
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
That's a whole lot of water and a little bit of oil residue.
The water will mostly blow through the AOS and pass through the engine and out the tail pipe just like in the stock system. The oil residue will be coalesced and returned to the oil system rather than coating the inside of your intake tract. There's nothing harmful there that your engine can't deal with without any problem.
Old 05-13-2011, 10:50 PM   #47
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
Interesting topic. I know when I transplanted the SRI from my old 99 lgt to my 06 2.5 (now in hybrid form), there was a definite distribution of oil/carbon/moisture streaking toward the intake manifold from both of the valve cover bungs in the aluminum intake tube from the 40k miles I put on the lgt before the swap. My guess would be that at whatever conditions that provide a negative pressure situation, it helps to act as a "junk re-circ" to the intake. I guess it would be designed as an emissions recycler of sorts for the hot, wet, slightly fuel rich debris that finds it's way back throughout the system from the valve covers back into the engine. Just a guess though... I wish I would have cleaned all of the stuff out before I installed it on my 2.5i so I could have a comparative look at what was re-circed from this engine to see differences between the 2 engines. Interested to see more input on this topic. I remember hearing that this "junk" is better off being vented/filtered that recirculated, but venting to atmosphere will also act as a vacuum leak to the system ending up in a lean (or more specifically "less rich") mixture entering the cylinders working against the MAF sensor's job. Again I may be completely off on this, but this is what I imagine is going on. Maybe in-line filters between the valve cover vents and the intake tube would be ideal?
Rudgers73 is offline   Reply With Quote
Old 05-13-2011, 11:50 PM   #48
GrundleJuice
Member#: 165749
What about venting the valve covers to atm with a breather filter
Old 05-14-2011, 10:27 AM   #49
evilWagon
Member#: 128739
07 2.5i SE Wagon
In most cases the valve cover vents are drawing air int the crank case. As mentioned halfway through this thread that's all metered air so allowing fresh atmospheric air in through the valve covers and eventually into the intake plenum would cause the engine to run lean to varying degrees. And in the case where the air is flowing out the valve cover vents you'd foul your filter. It seems like oil catch cans are the answer though they have to be emptied manually. All that being said you can still be loosing oil from the crankcase past the rings on the piston and directly into the combustion chamber. What I'm a little bit confused on is how Porsche solves this problem on a similar engine with an inexpensive ao separator?
Old 05-14-2011, 11:08 AM   #50
GrundleJuice
Member#: 165749
how does the air from inside the valve cover get to the intake plenum with the lines to the intake removed?
Why do some cars have barcode stickers on their back windows? (not Kartboy) brucelee Off-Topic 39 07-08-2007 12:51 AM
Why do FWD cars have the driveshaft tunnel? chkltcow Off-Topic 14 05-28-2007 05:28 PM
Why do concept cars always have HUGE dubby-dubs on them? Stroke Off-Topic 3 01-10-2004 07:08 PM
why do race cars have tape over headlights? chyisan General Community 10 05-18-2002 04:39 AM
Why do fwd cars have wheelie bars?!? garface General Forum Archive 13 02-19-2001 07:22 AM
