Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 04-13-2009, 07:42 AM   #1
1995REX
Member#: 201655
1995 RHD V-Limtd WRX
FOR SALE!!!!
Default Max safe EJ20 Boost
First off I have a 95 RHD WRX, Its a GC8C, I just put in a electronic boost controller and I'm trying to set my boost levels one for daily driving and one for some track duty or light to light work as of now I have it set at .80 BAR or 11.6 PSI on LOW setting and 1.00 BAR or 14.5 PSI on HIGH setting. My mods are a cat back exhaust I belive its a 3 inch, a Fuel Cut Defender, and an air box delete kit. So is this to much boost already and if not what would you all consider the high end of safe. Thanks for your time and help.
1995REX is offline   Reply With Quote
Old 04-13-2009, 08:56 AM   #2
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Try it at 17 and see what you get. Assuming you're in Japan now, run it on the highest grade fuel you can get your mitts on and try 17psi. It SHOULD be okay.*
*The above post I just pulled out of my arse and should not be taken seriously.
i_c_the_light is offline   Reply With Quote
Old 04-13-2009, 09:06 AM   #3
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
isnt 15psi when the injectors start maxing out @ 100%?
JDMFLCL is offline   Reply With Quote
Old 04-13-2009, 09:24 AM   #4
suberdave
Member#: 101865
88 GL-10 STi
if you have stock injectors and ECU, i wouldnt even try anything over 1.0 Bar.
if you have it tuned and have supporting mods i would run as high as 1.2 Bar.
i have my EJ20G set to 1.15 Bar and if conditions are right it may peak at 1.2 Bar.
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 04-13-2009, 10:37 AM   #5
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
suberdave is right on ...
Old 04-13-2009, 06:00 PM   #6
1995REX
Member#: 201655
FOR SALE!!!!
thanks for the help i guess i keep it at 1.0 for the time being
Old 04-13-2009, 11:46 PM   #7
Hareball
Member#: 165025
1995rex, what part of oki are you stationd at? I'm in Futenma.
Hareball is offline   Reply With Quote
Old 04-14-2009, 06:02 AM   #8
1995REX
Member#: 201655
FOR SALE!!!!
I'm living on kadena and work on camp hansen
Old 04-14-2009, 01:34 PM   #9
Hareball
Member#: 165025
Cool. I'll keep an eye out for you, so if you see a 98 white STi coupe with goldies waving don't be shy.
You planning on taking your wrx back home with you? I'm doing a bit of research on what I need to do in order to bring mine back.
Old 04-14-2009, 06:26 PM   #10
1995REX
Member#: 201655
FOR SALE!!!!
from what i read at the nhtsa site we are unable to bring it home i was going to do the cut in half conversion that the vendor on rs25 is selling and build my own but if you know how to do it i would rather just take mine home in one piece
max safe boost on 06 sti tmic wrb2006sti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 11-08-2007 08:36 PM
Stage 2 Max safe boost AVOID92x Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-14-2006 03:00 PM
What is STi stock boost in psi, and what max safe psi before you'd rec' head studs? JRock Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-05-2004 05:56 AM
Max Safe Oil Temp the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 5 08-20-2001 06:42 PM
safe stock EJ20 boost and power? Handling? Darryl General Forum Archive 17 01-27-2001 03:16 PM
