Old 04-13-2009, 08:27 AM   #1
Mechie3
Member#: 120152
Default Reuse Pistons
What is required to reuse pistons? I spun a rod a while back and am finally putting my "spare" engine together. If I get new rings and clean off the pistons are they ok? Do I need to remove all of the carbon buildup from the top surface (including that which isn't easily removable?
Mechie3 is offline   Reply With Quote
Old 04-13-2009, 11:15 AM   #2
benw
Member#: 103320
1998 swapped
Forester L
if the rod bearing did not disintegrate to the point where the piston was slapping the head, I would say there is probably no reason not to re-use the pistons. like you said cleaning them completely and getting new rings is the most important part.
benw is offline   Reply With Quote
Old 04-13-2009, 11:24 AM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
The one thing I would be leary about, is the coating on the skirts being worn off. If they go back into the same bores, it shouldn't be an issue.....but if you clean the rest of that coating off the skirts, it may be enough of a change in piston to wall clearance that slap could occur.
I'm in the same boat......I cleaned all the coating off the skirts as it was worn out anyway. Now I'm not sure if I should use them as is, or have them recoated.
Jay
Old 04-13-2009, 11:38 AM   #4
jays05
Member#: 78165
05 STI 35r + e85
We reused 3 pistons from my old built motor in the new build. They had 8k miles on them. Besides cleaning them up and buying new rings, we had the skirts coated @ swaintech.
jays05 is offline   Reply With Quote
Old 04-13-2009, 12:13 PM   #5
Mechie3
Member#: 120152
Pistons never slapped the heads so I'm fine on that level. The coating is worn in some spots on all of the pistons (lighter gray instead of a dark black). I plan to have the cylinder bores honed just to break the glaze. Would that be fine?
I got one new rod to replace the one that had issues and will reuse the other 3 rods I had.
Old 04-13-2009, 02:57 PM   #6
~snowman~
Member#: 207011
I want to re-use these pistons off a 257, but like you guys mentioned, I was thinking about swain tech coating at $20 bucks a pop for skirts, plus I seen some NPR rings at ebay $40 for the cheap, but I'm saying to myself, it'll be like 150 to reuse my pistons, my skirts have some spots on them but feel really fingernail smooth. I shined one up like a champ it looks really good. Someone said on somewhere if youre bothering to crack open the block go all the way.....and things like dont even bother with the oem...but then I hear brydon over there on RS and stock pistons will handle some decent HP regardless, so why so serious?
Engine has like 30k on the block and walls look good, but still would you guys bother to rehone in there before reusing pistons? Maybe it will allow for a better seat of the rings? ^^ I seen one guy said words like "deglazing the walls" or something like that, I wouldnt just throw them back in for a daily driver?
What do guys think about NPR ebay rings? Id almost rather purchase rings at my local subaru for that.
How bout rehoneing block?
How can you "inspect" an aluminum piston like this? red dye stuff? Ill talk to my guys whoever I go with about all this baby stuff as well.
How about rings for stock pistons?
How are you doing today?
Are Manley Platinum 2618's any reviews on those I cant find any?
In the meantime I've seen some wierd ebay bidding activity on sets of used but "new" sometimes sti pistons sold for 76 bucks 150 bucks 200 bucks, wierd.
I want to get some manley platinum 2618 I seen somewhere for like 400 bucks with everything. Skirts, rings, and all that, what im figuring if I spend 100 bucks on reused pistons, coatings, and new rings, and rehone/clean I might as well pay 300 more for pistons and have a great block. Then again, eat the costs of machining properly as well, and eat my budget build up.
~snowman~ is offline   Reply With Quote
Old 04-13-2009, 05:55 PM   #7
Mechie3
Member#: 120152
I'm staying OEM because of autocross classing rules.
Old 04-13-2009, 09:18 PM   #8
chicosubaru
Member#: 203675
theres a couple of concerns. 1: measure the piston and cylinder for wear and becoming oval. a 45,000 mile motor can have enough wear to warrant new pistons and rehoning if driven hard, lots of boost, etc. 2: don't clean the ring lands with old piston rings. the ring lands have strict clearances and thats where they seal. when you scratch them and enlarge them the rings wont seal as well. i use a strong solvent dip and after its all softened use a piece of wood to scrape it. 3: if the pistons and cylinders look good, obviously put the piston back in the same hole it came from.
chicosubaru is offline   Reply With Quote
Old 04-13-2009, 10:28 PM   #9
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
NPR rings are very good. I have used at least 6/8 sets on ej22 motors.
Old 04-13-2009, 11:11 PM   #10
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Call any of the popular engine builders on here and see about getting some stock pistons and rods that have been taken out of a brand new block that someone had upgraded. I did and I managed to get 4 brand new pistons for 50 shipped.
A set of stock rings for 4 pistons will set you back another 125 - 150 depending where you get them.
LiquidForce is offline   Reply With Quote
Old 04-13-2009, 11:19 PM   #11
Mechie3
Member#: 120152
I've seen NPR rings on ebay. I have no idea what cylinders my pistons came out of. I tore down the engine (it lasted 33K) in NY and moved to Indy. It's all there...some where. If I can't get inexpensive OEM pistons I'll see what a machine shop charges to clean them.
FS : STi intake manifold and throttle body jcovey2.5 Engine/Power/Exhaust 173 12-05-2011 09:38 PM
Can you clean & reuse the caliper piston boot and seal, if you can't get the kit? The Modaholic Brakes, Steering & Suspension 10 09-06-2005 04:47 PM
STI 4 piston, Perrin 4 piston, or Wilwood 4 piston nos Brakes, Steering & Suspension 18 12-15-2004 10:45 AM
Piston slap after I changed pistons to Arias forged pistons tomoking Service & Maintenance 9 11-06-2003 08:48 AM
Suspension nuts... Is it ok to reuse the original ones? MrP0nch0 Brakes, Steering & Suspension 4 06-14-2001 09:52 PM
