Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-13-2009, 04:18 PM   #1
Dont Try To Run
Member#: 204809
2006 STI
Default What is this part that is not connected!? Help please
Hey Everyone,
What is this line (electrical?) that is not connected? I realized it today while briefly cleaning my engine bay... gulp.
2006 STI:
APS CAI, Grimm speed 3 port solonoid, custom tuned. Otherwise, all stock. Is it from the stock solonoid?
TJ
Dont Try To Run is offline   Reply With Quote
Old 04-13-2009, 04:19 PM   #2
sedagive
Member#: 186334
Looks like a grounding wire, I wouldn't worry about it.
sedagive is offline   Reply With Quote
Old 04-13-2009, 04:23 PM   #3
Dont Try To Run
Member#: 204809
2006 STI
That was what I was thinking of, I could not think of the name (grounding wire). Just wanted to make sure there was no harm... I was "powerwashing" the engine bay with one of the genie high power washers, but it was nowhere near that close to blow that off... And No CELs on the way back.
Old 04-13-2009, 05:03 PM   #4
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
It's a grounding wire, it came loose with you did your BCS.
It connects through one of the bolts that holds that big black bracket to the fender (the one that holds the BCS)
Old 04-13-2009, 05:11 PM   #5
Dont Try To Run
Member#: 204809
2006 STI
Keith from AWDtuning did my BCS... how important is this grounding wire? Does anyone have a diagram on where it goes so I can reconnect it?
Old 04-13-2009, 05:14 PM   #6
sedagive
Member#: 186334
Grounding wires are just...like.... well.... an escape for electricity, it carries any excess current. It is round so that you can clamp is onto a bolt, and thats what you should do.
Old 04-13-2009, 05:30 PM   #7
jamal
Member#: 71875
98 Legacy GT
my wheels fit
it's normally connected to the bottom bolt on that black bracket.
jamal is offline   Reply With Quote
Old 04-13-2009, 05:39 PM   #8
EROC263
Member#: 96887
I would say connect it back. Try tracing the ground wire to see if you can tell which component it goes to.
EROC263 is offline   Reply With Quote
Old 04-13-2009, 05:47 PM   #9
b0nd18t
Member#: 155876
2007 STI
Blouch Dom3
put it there. nothing else really needs said.
b0nd18t is offline   Reply With Quote
Old 04-13-2009, 05:59 PM   #10
novacivic
Member#: 117980
2005 sti
wr blue
the other end connects to the cylinder head
novacivic is offline   Reply With Quote
Old 04-13-2009, 06:52 PM   #11
07wrx4life
Member#: 171514
07 DOM 3 WRX
352/326 @ 20psi EQ Tuned
Please don't post with useless Info like this.....
To the OP, Just reground the wire to the Bold on the Inside fender. You should be good to go after that.
07wrx4life is offline   Reply With Quote
Old 04-13-2009, 07:04 PM   #12
Dont Try To Run
Member#: 204809
2006 STI
Thank you all, is there anything I need to do specifically to ground the wire to the bolt on the inside fender? i am confused as to how it even popped off
Old 04-13-2009, 07:18 PM   #13
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
It cant just 'pop' off, the bolt threads through it. Looks like that was never bolted down. Just undo bolt and put it through the round part and tighten it back down. Nothing specifically needed...
Steve.804 is offline   Reply With Quote
Old 04-13-2009, 09:42 PM   #14
sedagive
Member#: 186334
Genius, did you miss my other post?
Old 04-13-2009, 09:56 PM   #15
Dont Try To Run
Member#: 204809
2006 STI
Hm, I will try to figure it out tomorrow. Thank you all for the help.
what is this part called? what is it's part number? OUScooby Private 'Wanted' Classifieds 8 04-21-2010 04:08 PM
What is this part? Oil filler tube seal? Hint: it's NOT the o-ring (I have a pic!) Type2 Newbies & FAQs 5 04-25-2009 11:09 AM
what is this part that I broke? speed_ga Legacy Forum 2 09-09-2008 02:00 AM
is this a good deal on volks? help please subaru222 Tire & Wheel 10 03-02-2006 05:19 PM
What is this part and is it broken? Reddstars Brakes, Steering & Suspension 9 03-07-2005 10:14 PM
