Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 04-13-2009, 08:26 PM   #1
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Default open loop?
Isn't the engine supposed =to switch to open loop under full throttle? Playing with my scangauge I noticed that it always remained under closed loop with either normal cruising or WOT - switched to open loop when decelerating in gear though.
Old 04-13-2009, 09:03 PM   #2
Skidd
Member#: 1853
GC6 Supercharged
STM
Your engine can sometimes decided not to go OL if the ECU has deemed that its' not running well enough for OL. I can't say exactly what the ECU is watching for that decides this though. Plus, OpenLoop on decel is normal, as your ECU cuts off 100% of the fuel going in on decel for economy reasons.
Skidd is offline   Reply With Quote
Old 04-13-2009, 09:09 PM   #3
Bluefoton
Member#: 141373
2008 2.5i-hatch -
^ thanks. i wonder though if it's normal for WOT. In parallel, my gas mileage dropped a lot (ie ~5mpg consistent decrease @ same speed, distance, freeway etc with respect to last years). Given I have a new air filter, fuel fitler, and plugs,I'm wondering about the o2 sensor now.
Old 04-13-2009, 11:21 PM   #4
GrundleJuice
Member#: 165749
There is a delay for the switch to OL.. so it wont go to OL just because the TPS says its WOT. It has to meet a few other parameter values to make the switch to OL. Also, staying in CL should only help your gas miliage (at the cost of power)... as long as the AFR's the ECU is reading are correct.
Old 04-14-2009, 01:12 AM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
It's likely the CL->OL Transition Delay you're seeing. Go WOT at idle while watching the CL/OL status. Eventually, 3/4 of the way to redline, you should see it transition to OL. Get on the gas at a high enough RPM and you'll never have time to get it to transition.
Old 04-14-2009, 10:05 AM   #6
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Thanks. Checked this morning on a highway. Flooring it on the 5th gear at 2500 rpm results in open-loop after a 10-11 seconds delay.
Old 04-14-2009, 07:58 PM   #7
GrundleJuice
Member#: 165749
It's good to know that the delay isnt exactly a function of time. Time (clock cycles or something like that, inside the ECU) plays a part but its how much time passes WHILE all the conditions to switch to OL are being met. So in 5th gear the delay at WOT might be longer than in 4th gear. there are a few things that have to be satisfied for the ECU to finally make the switch.
Close Loop Boost vs. Open Loop Boost chuglobal Engine Management & Tuning 35 10-27-2004 04:07 PM
open loop vs. closed loop Mancini Normally Aspirated with bolt-on Forced Induction Powertrain 24 09-26-2003 12:55 AM
Open Loop vs Closed Loop UTEC boost map. Example? mav1c Engine Management & Tuning 3 02-01-2003 11:58 PM
open loop VS closed loop iloveturbos Newbies & FAQs 4 11-12-2002 08:33 PM
My thoughts for closed-loop to open-loop with link. Chav Normally Aspirated with bolt-on Forced Induction Powertrain 0 06-28-2002 03:10 PM
