Old 04-13-2009, 08:50 PM   #1
whatishe
Member#: 65711
2004 WRB WRX Wagon
2.5 Hybrid STI Conversion
Default Shim Underbucket Conversion on EJ207? Cams?
Ok Boys and Girls, here's my question:
I am about to do my EJ207 build. The engine has full forged internals and is mated to machined 205 heads with JDM valves and double springs. So far it looks like this:
  • Jdm Sti V7 2.0
  • Pauter Rods
  • CP Pistons
  • V7 crank
  • Machined WRX heads
  • Sti Jdm valves
  • Double springs
Do I need to do a shim conversion to run a higher redline and cams. Can safely hit 8500rpm on this with the stock WRX cams? Let me know!
whatishe is offline   Reply With Quote
Old 04-13-2009, 10:54 PM   #2
whatishe
Member#: 65711
2004 WRB WRX Wagon
Anyone? I would like to hit 8500 without doing the cams and shims but if I have to do them I will. Eventually, the goal is to hit 400whp, but if I can get 360 without this conversion I will hold off until I do the bigger turbo. Thanks guys!
Old 04-13-2009, 11:26 PM   #3
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
no stay shimless, if you break a shim you will tear up your motor, they come shimless for a reason
seanathanq83 is offline   Reply With Quote
Old 04-13-2009, 11:47 PM   #4
whatishe
Member#: 65711
2004 WRB WRX Wagon
That's good enough for me.
What about more aggressive cams?
Old 04-14-2009, 12:09 AM   #5
charliew
Member#: 125304
There is no way stock cams will do anything after about 6500. Unless your on the bottle.
charliew is offline   Reply With Quote
Old 04-14-2009, 12:33 AM   #6
whatishe
Member#: 65711
2004 WRB WRX Wagon
How do people feel about Brian Crower cams? I've read mixed reviews. Anyone have a set they absolutely love? I know Cosworth, BC, Crower, and a few others make them. I'm looking at BC and Crower, Cosworth is a bit rich for my requirements. Opinions?
Old 04-14-2009, 12:53 AM   #7
seanathanq83
Member#: 173241
they are decent, i like kelfords,
Old 04-14-2009, 01:09 AM   #8
whatishe
Member#: 65711
2004 WRB WRX Wagon
I'll have to read up on kelfords, thanks for the tip.
WTB: Spec C jdm ej207 cams N8WRX Private 'Wanted' Classifieds 0 02-03-2010 01:45 PM
FS/IL sti cam gears ej207 cams 12.9$500rex Engine/Power/Exhaust 6 11-27-2009 10:32 PM
FS ej207 cams 12.9$500rex Engine/Power/Exhaust 14 10-29-2009 03:47 PM
What machining to do on EJ207 heads going on an EJ257? frayz Built Motor Discussion 9 09-04-2008 01:01 PM
who has done shim under conversion? fc735 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-23-2003 11:50 PM
