Welcome to the North American Subaru Impreza Owners Club Wednesday April 23, 2014
Old 04-13-2009, 10:15 PM   #1
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
Default FueLab: Alternative to Bosch 044, Aeromotive A1000, Walbro, etc
I've been getting alot of people asking me about the FueLab / Hydra setup I'm running, so I decided to make a thread. Hope this is helpful to those who want to give it a try.
So far, the pump is running as advertised. I'm quite surprised at how much quieter it is than the 044. It's not silent by any means, but the noise it makes is more subdued according to my ears, and it's not the annoying whine the 044 makes.
So here's the write up:
I decided to give the FueLab a try. I'm a sucker for testing unproven parts!
It's less noisier than the 044 I was using.
I bought it at http://www.brucesspeed.com/prodigyfuelpump.aspx last December for $357. (Looks like pricing went up by $30 recently ! )
Some info on the FueLab Prodigy pump:
http://www.fuelab.com
FueLab pumps have some interesting features according to the manufacturer's claims: integrated speed controller, brushless motor, lots of flow, can pump just about anything.
The speed controller unfortunately is not PWM (i called their techs - they did say they have an integrated PWM pump in the works - a few months away)
The pump comes with a voltage divider (3 resistors + a cap) already wired in that gives you a "low" and "high" speed. You can switch between the speeds via a relay (toggle switch). The relay can be activated by your standalone ECU, pressure switch, etc. Not as good as a PWM based controller but having the ability to switch to a low speed is interesting and being built into the pump saves $$. The aeromotive controller is $275! The FueLab pump runs about $355.
Here's the instructions sheet the FueLab tech emailed me http://subaru-wrx-sti.com/web/MODS/41401-c.pdf
Pump performance charts - I'm using the 4101
I like the integrated speed controller - I'm using a Hydra output to switch the speed. I'm using boost as a variable - The beauty of the Hydra is that I can use anywhere from 1 to 4 variables (there are more than 20 to choose from) in various AND, OR, XOR logics. I think boost @ 3 psi should be good enough.
The speed switch works well, whenever boost reaches the 3 psi target the Hydra output switches the pump speed via a Bosch relay. Whenever boost drops below 3 psi, the pump speed decreases.
Although this write-up is for a Hydra EMS application, the pump can be controlled by other ECU's, manually by a switch (I wouldn't) , automatically by a pressure switch (I wouldn't either). One can also just run it in high speed or just in low speed (depending on fuel demands of your power goals). Even at low speed the pump seemed to be flowing than the 044 I had as I saw higher static pressure after I replaced the 044 with the FueLab.
I noticed the static fuel pressure was higher than that of the 044 I was using (on Defi fuel pressure gauge) by about 2 psi at the slow speed setting and by about 4 psi at high speed.
Hopefully this pump will last and I won't have to get a new pump any time soon. I couldn't find much info on any forum regarding durability. I found some turbo diesel and Vette guys using it, but not much info.
The pump seems to be well-built and uses a brushless DC motor (see my previous post) which are known to be reliable and arguably better than the standard electric motors. I'll report back if any issues arise with this pump.
that's the 75 micron pre-filter on the left. The wire harness is for pump speed control. The -10AN fittings need to be purchased separately.
Compared to the Bosch 044
Mounted externally between the rear diff cross-member and the fuel tank. Right under the left rear passenger seat.
engineerx is offline   Reply With Quote
Old 04-13-2009, 10:16 PM   #2
engineerx
Member#: 42614
0405 WRX STi/S2000
Wiring:
clicky for very large images
Wiring pump power to enable switching using OEM pump controller:
A Bosch relay is used to turn on FueLab pump.
Just as the OEM in-tank pump, the secondary pump will prime on IGN ON and then it will shut off until engine is cranked.. safe!
Tapped into pump controller harness. Use a multimeter or voltage tester to confirm you have +12vdc on one of this wires and ground on the other
the +12vdc should have power only when IGN ON and the other wire should source ground for a few seconds after IGN ON (this primes pump and then turns it off) - I wired this a few weeks ago and I forgot which is which. The negative signal from the controller (black wire) connects to #86 on the relay. #85 relay terminal has to be connected to a switched IGN ON. I used the +12Vdc source that goes to the controller. As always check for yourself what each wire sources before you connect anything. Use a multimeter or even a cheap bulb tester. Cycle the IGN on and off and see what each source does.
Wiring from pump controller to Bosch relay that supplies power to the pump. Always use a fuse close to the battery for +12vdc source. My battery in in the trunk's spare tire well. Use a good thick gauge wire for both power & ground. Stereo stuff works well.
It's always best to use the appropriate wire gauge:
here's a useful guide
Wire gauge / diameter / current capacity
#4 = 5.19mm/.204" (70 amps)
#6 = 4.12mm/.162" (55 amps)
#8 = 3.26mm/.129" (40 amps)
#10 = 2.59mm/.102" (30 amps)
#12 = 2.05mm/.081" (20 amps)
#14 = 1.63mm/.064" (15 amps)
#16 = 1.29mm/.051" (10 amps)
#18 = 1.02mm/.040" (~8 amps)
#20 = 0.81mm/.032" (~4 amps)
Hydra EMS wiring:
I used PWM8 output from the Hydra pin A1. It sources +12vdc to the pump's speed controller switch via a Bosch relay. If you need wiring info on Bosch relays go here ->
http://www.bcae1.com/relays.htm
Pump's speed control switched wired into Bosch relay to switch speed from the Hydra EMS output
Old 04-13-2009, 10:17 PM   #3
engineerx
Member#: 42614
0405 WRX STi/S2000
Hydra EMS pinout assignment, output and user logic settings
Refer to pages 211-216 of the Hydra user's manual for further details
Old 04-13-2009, 10:36 PM   #4
engineerx
Member#: 42614
0405 WRX STi/S2000
this is an earlier pic of my fuel lines / pump set up from this thread http://forums.nasioc.com/forums/show....php?t=1382976
and here http://forums.nasioc.com/forums/show...2&postcount=17
More pics of the fuel line routing http://forums.nasioc.com/forums/show...2&postcount=17
Old 04-13-2009, 11:58 PM   #5
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
All I can add is that the pump is super quiet. I honestly couldn't hear it and i was sitting right over it lol. Quieter than my whinebro for sure. Hi Roland
Karlton
pignoseSTI is offline   Reply With Quote
Old 04-14-2009, 12:58 AM   #6
engineerx
Member#: 42614
0405 WRX STi/S2000
Karlton
Hey Karlton !
yeah.... I got my KW V3's serviced - had a chipmunk inside the strut I think... no more annoying chirping sound from the right rear... and now with the quieter pump I'm living it up !
Old 09-03-2009, 01:10 PM   #7
06rexwagon
Member#: 114730
2006 WRX Limited Wag
9.9@142
Originally Posted by engineerx View Post
Wiring:
Thanks for these pics. They made it a lot easier to install my 044 last week.
06rexwagon is offline   Reply With Quote
Old 09-03-2009, 08:11 PM   #8
vulpina
Member#: 131903
GC8 PPG EJ25 GT3082
dark blue 95H
excuse me , are those black fuel line safe enough to use in engine bay ?
vulpina is offline   Reply With Quote
Old 09-04-2009, 12:07 PM   #9
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
I went with a fuelab 42401-1 Fuel pump. It's good for 210 GPH at 43 psi and 175 GPH at 100 psi according to my flow sheet. Anyways, I went to start my car (After running the fuel pump for a few seconds to prime the lines and bleed the air from the system) and the fuelab pump ran for about 20 seconds total and then pulsed on for 1 second and off for 1 second and it would not output any pressure. When it did work I had 80 PSI of fuel pressure and my car ran beautifully for 10 seconds).
Fuelab received my pump back in their shop for work. I got a call from them yesterday telling me it appears a couple of resistors on the new PWM control board failed. They replaced the pump with a brand new one and are shipping it back to me today. They have awesome service and turn around time. Fuelab FTW!
Surgetank, Pre Filter and Post Filter without pump (cause pump is at fuelab)
Dual Fuel pressure regulators (One regulator for each set of injectors)
Couple of engine bay pictures
Fuel Feed and Return Lines
wrx_driver_2002 is offline   Reply With Quote
Old 09-04-2009, 12:11 PM   #10
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Link to my gallery if anyone wants to view the rest of the pics
http://gallery.me.com/michael.talbot#100020
Old 09-04-2009, 01:53 PM   #11
engineerx
Member#: 42614
0405 WRX STi/S2000
Very nice FueLab setup you got there.
They finally released the PWM pumps. Back when I got mine I talked to the FueLab engineers, who were very helpful, and they told me the PWM pumps were a few months away and theyd be out sometime around May. Nice to see they actually released the pumps already instead of taking months.
I have to say, the dual speed setup works extremely well and it is super simple to setup. Im quite happy with the pumps performance so far. The PWM version adds yet more options.
Ill be looking forward to your posts once you get the pump back into your car. So far, it looks like this pump will be good for me for quite some time.
Old 11-05-2010, 03:05 AM   #12
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
How's this setup doing?
methaddict is offline   Reply With Quote
Old 02-04-2011, 05:44 AM   #13
jibberjive
Member#: 197304
2nd, how's it been?
jibberjive is offline   Reply With Quote
wiring up walbro 255/bosch 044 to run 100% ? Rod702 Built Motor Discussion 56 08-03-2011 09:48 AM
Bosch 044 with walbro 255 feeding- problems TDagen Factory 2.5L Turbo Powertrain 24 09-20-2009 04:24 PM
FS: Bosch 044 pump, magnafuel external pump, 044 pump holders, weldon pump controller jigga Engine/Power/Exhaust 8 10-19-2007 11:31 AM
Aeromotive A1000-6 FPR fittings... ZLODEY Engine Management & Tuning 2 04-26-2007 03:28 PM
Aeromotive A1000-6 FPR fittings... ZLODEY Factory 2.0L Turbo Powertrain 1 04-25-2007 10:19 AM
