Old 04-13-2009, 10:15 PM   #1
cthor
Member#: 202584
04 Impreza STi
Default DBW and cruise control...
How does this work? I have my07 swap almost complete into my00rs and am a bit confused on this dbw system. is everything already programmed into the system or is their something i have to do? any help would be great..thanks in advance..
cthor is offline   Reply With Quote
Old 04-14-2009, 02:00 AM   #2
KillerRabbit
Member#: 184772
2004 WRX
World Rally Blue
What do you mean? DBW or Drive By Wire is basically electronic throttle. If your asking how to make it work, i dont know what your problem is. So explain first, then we can tell you.
If you need immediate help then maybe you can call Corey at ECS(east coast swappers)
He hooked me up with a DBW adapter for my 04 STI swap.
KillerRabbit is offline   Reply With Quote
Old 04-14-2009, 08:12 AM   #3
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
As long as you have the wiring harness, immobilizer, and ecu you should be good to go. It's already set up.
If you're switching to a 2007 wheel you'll need the column and clockspring to easily make the CC function. There are other ways to do it this is probably the easiest.
Like rabbit referred to you'll need the dbw pedal and an adapter as well.
mccanixx is online now   Reply With Quote
Old 04-14-2009, 09:51 AM   #4
cthor
Member#: 202584
04 Impreza STi
The pedal adapter I just made myself. Wasnt too hard. I am still in the process of finishing. All the mechanical parts of the swap is done. Wiring has been merged and just needs to be reinstalled. I am just a bit confused with the cruise control feature. The wiring was done by Iwire and I dont know if I can just start the car and drive it and the cc feature will work or do I have to switch over to a new column...
Old 04-14-2009, 10:06 AM   #5
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
I guess in that case I'd call the people that did the merge and ask them.
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
Break-in Period and Cruise Control nightdesigns Legacy Forum 1 04-17-2004 04:24 AM
airbag and cruise control problem subimp6u08 Electrical & Lighting 2 01-23-2004 09:39 PM
2.5RS leather steering wheel with airbag and cruise control Pete Holt Private 'For Sale' Classifieds 10 09-06-2003 10:06 AM
Unichip - part throttle and cruise control conclusions DanMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-28-2001 09:15 PM
