Old 04-13-2009, 10:40 PM   #1
vms150
Member#: 172917
2004 WRX
Default 05+ Tanabe DF210 springs on WRX struts
I have been searching for the 05+ Tanabe DF springs for a while. The only ones I can find say wrx/sti. So, I know that STI springs on WRX struts seems to be a no no. My question is, since the DF springs are supposed to be only 10% stiffer than stock springs, would they be okay to run on WRX struts? And has anyone done it? Thanks.
vms150 is offline   Reply With Quote
Old 04-13-2009, 10:44 PM   #2
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
I don't know really, but you'll have little suspension travel with those ultra low springs and you'll be riding the bump stops.
Smoke is offline   Reply With Quote
Old 04-14-2009, 12:06 AM   #3
Nitrous
Member#: 136929
Part number is TDF107
They're perfectly fine! I run these in my '07 2.5i
They've been on the car for ~10k mi, first 500 miles on stock then 3k was on STi take off's and I have no problems.
Spring rates are comparable if not the same then the STi springs, just now with reduced potential suspension travel depending on what wheel/tire/offset you run because you may hit rear fenders with this drop. You may need to roll your rears, fronts will never be a problem.
For the record, in my car I can't stick 1 finger between tire/fender, and I can fit 2 in the front.
Nitrous is offline   Reply With Quote
Old 04-14-2009, 01:47 AM   #4
bcWRX-02
Member#: 181780
2002 WRX Sedan PSM
'01 CBR 600 F4i
STi springs on WRX struts are far less of a problem than running low springs such as the DF's on your WRX struts. You'll be close to, if not riding the bump-stops which will wear your struts much faster.
bcWRX-02 is offline   Reply With Quote
Old 04-14-2009, 12:25 PM   #5
vms150
Member#: 172917
2004 WRX
I never heard that they are to low before this, the few I talked with how had them seemed happy with them. Am I to understand that I will be "riding on bumpstops" as soon as I install these?
Old 04-20-2009, 05:53 PM   #6
STiSix
Member#: 208523
2008 STi
Check out the Racecomp Springs Sets. I just installed a set on my 08 GR. 100% improvement over stock. I beleive they have 2 types for the 06-07's.
STiSix is offline   Reply With Quote
Old 04-20-2009, 05:56 PM   #7
STiSix
Member#: 208523
2008 STi
...yeah they have some for 04 WRX's. RaceComp Engineering Regular Guy "Black" Springs. Great suspension set-up. Check out www.gtworx.com
Tanabe df210 spring '02 WRX scoobin' Suspension/Brakes/Handling 2 11-12-2009 11:05 AM
Tanabe df210 springs for wrx 02-03 conheosua01 Suspension/Brakes/Handling 8 08-29-2009 04:06 PM
05 STi .....what springs on stock struts gslben Brakes, Steering & Suspension 22 04-25-2006 11:58 AM
FS: H&R Springs on WRX Struts Skibum4444 North West Impreza Club Forum -- NWIC 3 06-23-2005 12:00 AM
