Old 04-13-2009, 10:53 PM   #1
Rei_Akira
Scooby Scammer- Do Not Buy From User
Member#: 194555
1997 GC8 coup
green
Default thinkin bout doin a build
ello, im new to subaru building, and well tuning in general. my old car was an 89 240sx with a SR20.
anyways, onto the questions i have. right now i have a 97 Coup that im planning on dropping a EJ20K motor/drivetrain into. already started on all the wiring on the vehicle. planning on caging and painting the car while its stripped down.
my goal is to have about 375hp to the wheels and capable of 9-10k rpm (its at 7.9k right now), its a semi-daily driver and will also be used at the track so reliability is somewhat of an issue (i have another car i drive as well).
while the motor is on the shop floor i figured i would build the bottom end now, so i would only have the heads to deal with later when im ready to push for the goal.
planning on doing a FMIC and new turbo later on (running the stock VF49 for a while), new injectors, equal legnth headers, up-pipe, possibly partial meth, bigger fuel pump (has the factory V4 STi fp right now, not sure what that maxes out at though)
already has a HKS DP and hi-power exhaust.
mmmm....advice, thoughts?
Rei_Akira is offline   Reply With Quote
Old 04-14-2009, 12:10 AM   #2
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
What size turbo do you plan on running?Why the 9-10 k rev desire ?
I hope you have alot of contacts or very deep pockets /
From my experience , unless your running a diesel truck sized turbo you can make gobbs of power w/ a 7k-8500 k rev limit & it will be alot more reliable & cheaper
Just my .02
G/lL
sense of nature is offline   Reply With Quote
Old 04-14-2009, 12:30 AM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Here is/was my route to 300-375 whp....
2.5 block. PHASE 2 though, but can be NA or STI, doesnt matter. NAs are cheap.
97mm throw crank. NA or turbo, doesnt matter. Get it polished
STI rods. They are cheap used, still cheap new....
ACL or TOGA bearings
Pistons, ANY brand but stock STI (cause you will break STI pistons as you are not a stock ECU and will see knock somewhere/sometime)
BIGGER than you need injectors.
ANY DOHC heads. Even NA if thats all you can get, still make big power out of them.
Dual pressure plate and 6 puck to hold the power as you are cable, not hydro and don't have options....
EM?
FMIC is a given.
Live with the stock RPM limit unless you have deep pockets.
I am currently making about 300/300 @ 15 psi for $3000 in the family 1990 Legacy wagon. Thats cost of parts, no labor.
NA block, $150?
Mahle pistons $450 (although I only paid $28 via a raffle!!!!!)
STI rods and crank $150
Bearings $100
FMIC kit came with stainless piping, couplers and BOV $225
Clutch kit $200
Ebay turbo $<200
Oil feed line $35
550cc injectors (free, modded my stock NA ones)
twin turbo heads $250-400
intake manifold (NA) $50
down pipe back Exhaust $150
Up and down pipe $20 materials
Heat wrap $40
Modded MAF $80 (free to me, I am the one that sells them )
Air filter $50
Greddy Trust MBC $50 (used off ebay)
Gauges $50 (Boost and AFR narrowband)
Misc $150
Perfect Power 6 piggy back $250
Borla Header $250
So at least $3000....
Old 04-14-2009, 03:13 AM   #4
Rei_Akira
Member#: 194555
1997 GC8 coup
green
everyone seems to be running either the 2.5 or the 2.2 blocks, are the EJ20's that hard to make power with?
Old 04-14-2009, 03:22 AM   #5
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Displacement is the easiest way to gain power, spools everything faster.. you get the idea. The 2.0 block is huge everywhere else besides the US, we just got shafted with our 205. Your route will be just fine, Do some re-search and figure out why everyone says stay at near stock rpms or win a lotto...
907Bum is offline   Reply With Quote
Old 04-14-2009, 10:32 AM   #6
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
ditch the 9K revs. That will cost you and extra $4-7K alone. 375 is very doable but stick with a built 2.5 block and use a 20g+ turbo (ideally, go with a dom 3 30/35r). With supporting mods, that will get you there ~$5K if you buy wisely (used parts for turbo/breathing mods).
Fongers is offline   Reply With Quote
Old 04-14-2009, 11:12 AM   #7
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
ditch the ej20K and get an ej205/255/257 etc
the ej20k will limit your tuning options unless you go standalone or you have a newer jdm ej207 which is supported w/ ecu flashing (ie; ecutek, opensource,etc)
i would start with an ej205 swap, put the big turbo on and run it till it blows then step up to a 2.5L
mxpunk is offline   Reply With Quote
thinkin bout losin the authentic sti gt (s202) wing.. k3lh3 NWIC Private Classifieds 31 02-06-2010 08:48 PM
Thinkin bout moving to Socal Paintballguy Southern California Impreza Club Forum -- SCIC 41 02-11-2007 05:14 PM
thinkin bout 20's on the GC couldnthinkaone Texas Impreza Club Forum -- TXIC 39 01-10-2007 09:56 AM
Just one older pic of the Bugeye... thinkin bout changin it up vipernj Member's Car Gallery 41 12-08-2006 10:25 PM
Thinkin bout gettin one of these... NM02WRX General Community 6 10-24-2004 06:30 AM
