Old 04-13-2009, 11:41 PM   #1
mc2
Member#: 59992
1997 Legacy L EJ22
Default P1507 and P0505 after cleaning IAC...
So I had to take my IAC off when i was pulling my tranny to get access to the service hole.
I took the liberty to clean it off with q-tips and rubbing alcohol while it was off.
Now when i start the car up the idle is at around 1200 when warm and the suddenly the CEL came on and idle dropped to about 800-900 but it was a very rought idle. The two codes that came up are: P0505 and P1507. Apparently both related to IAC.
I didn't change the gasket, but on the older EJ22s its not a rubber gasket, but instead some type of composite material.
I also sprayed throttle body cleaner all around the IAC and vacuum hoses in that area, I couldn't detect any changes in idle. I don't believe that I have a vacuum leak.
Any ideas? is it possible that i screwed up the IAC trying to make it better by cleaning it... Car was running fine prior to tranny pull and reinstallation.
mc2 is offline   Reply With Quote
Old 04-13-2009, 11:42 PM   #2
Baja820
Member#: 196860
CELs .... hate em.....
That is all
Baja820 is online now   Reply With Quote
High Idle. Cleaned IAC, throttle body etc. Blase Normally Aspirated Powertrain 1 11-15-2008 11:46 AM
P0113 and P0102 after MAF clean speedin Factory 2.0L Turbo Powertrain 4 05-28-2008 10:05 PM
Replaced MAF, cleaned IAC, still idle problems? Aaron'z 2.5RS Service & Maintenance 15 08-21-2007 06:17 PM
cleaned iac and still idles high and funky dukeduster Built Motor Discussion 4 05-29-2007 10:13 AM
idle issues, EJ25D, P1507, and more ArtechnikA Normally Aspirated Powertrain 1 09-22-2005 03:40 PM
Message Board Statistics All times are GMT -4. The time now is 10:14 AM.
