Old 04-14-2009, 12:50 AM   #1
ahhhh
Member#: 207726
Default Motul or Amsoil Gear Oil for the 6mt and STi Diff?
I have read the gear oil faq's, unabomber's threads and just got done searching nasioc and iwsti. Trying to figure out what would be the better route to go.... Please don't post anything about the 5mt and wrx diff, this is for a 2004 STI...
Was thinking between Amsoil or Motul, also see more threads about Motul problems vs hardly any using Amsoil. This is what I was looking at.
Amsoil
Severe gear "rear diff"
http://www.amsoil.com/storefront/svg.aspx?zo=515729
Slip Lock "rear diff"
https://www.amsoil.com/storefront/ada.aspx
Long Life "tranny"
http://www.amsoil.com/storefront/fgr.aspx?zo=515729
Motul
6MT Option A "Motul 75/90 and Motul 90PA"
http://www.fastwrx.com/trsekit.html
Does the Motul 90PA require a additive?
ahhhh is offline   Reply With Quote
Old 04-14-2009, 09:30 AM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You can ask Jesus, Mohammad, and the Dahli Llama and you won't get the right answer as there is no right answer. The Maintenance FAQ states the popular oils, use one of them. You are MAIC, so your best best bet is to use fastwrx.com as they are local and local advice is the best. Call Dan and axe him.
Old 04-14-2009, 02:19 PM   #3
DS1
Vendor
Member#: 111780
The 90PA has the additive in it already. You can use the Motul Gear 300 in the front and the back without any worries.
-Dylan @ DS1
DS1 is offline   Reply With Quote
Old 04-15-2009, 02:43 AM   #4
ahhhh
Member#: 207726
Well I searched some more and still found more horror stories using Motul. Think I will use the Amsoil gear oil. Already using Amsoil 10w-30, larger EA013 Amsoil Synthetic Media Oil Filter. Might as well go all Amsoil in 3K miles which will put all fluid changes on 100K. Of course I might as well get a Amsoil filter and sock for the Aps intake, snag some Amsoil Synthetic ATF for the power steering and change the plugs.
How much of the 4oz bottle of Slip Lock is supposed to be added to the rear?
Old 04-15-2009, 12:42 PM   #5
bluesubie
Member#: 767
04 FXT
Go with the Severe Gear in the front. No idea on the Slip Lock.
-Dennis
Old 04-16-2009, 01:14 AM   #6
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
I've put Severe gear 75w90 or 75w110 in several Subaru rears. I've never used / needed the Slip Lock additive (in a Subaru).
Even in most vehicles that do specify the need for an additive, when using Severe Gear, the additive was not needed. I've only had to add it in one case, which was my brothers truck that tows a heavy trailer every day.
RonJitsu is offline   Reply With Quote
Old 04-16-2009, 01:51 AM   #7
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
if your rear diff is plated, like spec c, I would highly recomend using PA90
Hyper is offline   Reply With Quote
Differential gear oil for the WRX rexman2002 Service & Maintenance 34 06-20-2009 05:49 PM
synthetic or dino gear oil for tranny Sir Punk Newbies & FAQs 8 03-11-2009 07:59 PM
Oil capacity and type for 6mt and rear diff? serious Transmission (AT/MT) & Driveline 2 05-28-2004 08:14 PM
Perrin exhaust systems for the WRX and STi are in!!!! vividracing Vendor 'For Sale' Classifieds 8 09-24-2003 03:01 PM
Who can't wait for the EVO and STi info to disapear from the board? Eric SS Off-Topic 18 01-07-2003 10:02 AM
