Old 04-14-2009, 01:09 AM   #1
manjambles
Member#: 205643
2005 forged goodness
Default 92x aero swap
ok so i asked on the saab92x forum and they didnt know to much bout what i needed so i thought id come to nasioc and see if i could get some helpful guidance.
heres the deal i have a saab 92x 2005 with i believe the 2.0t EJ motor, well it had high mileage and blew something in the motor or the main seals.
so now im in the market for a new motor and i would like to upgrade but i dont know what to upgrade to!
what would be a good drop in motor that wouldnt require any extra wiring, but would plug up to the stock enging harness and give me more than the 2.0.
will a longblock fit?
manjambles is offline   Reply With Quote
Old 04-14-2009, 02:06 AM   #2
manjambles
Member#: 205643
please help meee
Old 04-14-2009, 02:21 AM   #3
darksc00by
Member#: 102140
2016 Herp Derping
Engineer For Hire, yo.
upgrade to my motor!
no really.
only reason I want to sell is because I need cash to pay bills, im going to a 2.0 L
darksc00by is offline   Reply With Quote
Old 04-14-2009, 09:08 AM   #4
Dutchman1101
Member#: 155735
2005 '05 LGT LTD
Satin White Pearl
Seriously, a hybrid is probably your best bet. If they are done well they are very reliable and make VERY decent numbers.
Do some searching on here as someone on 92x.com pointed out. It's a pretty common thing.
Dutchman1101 is offline   Reply With Quote
Old 04-14-2009, 12:23 PM   #5
1sicWRX
Member#: 104631
96 Cobra, TBird SC
88 Mustang 5.0
Yes, but you will need a tune to run the 2.5l... The 2.5l makes pretty identical power numbers in stock form when compared to the 2.0l. It really only shines when you begin modding it, the 2.5 is a torque monster. However, if the car is stock with a 2.5l shortblock you will not notice a tremendous difference in power.
1sicWRX is offline   Reply With Quote
Old 04-14-2009, 02:40 PM   #6
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You can place the following motors in your car:
EJ20
LS1
3 rotor Wankel
VW 16 cyl quad turbo
Since we have no idea of your goals or budget the help you are going to get from us is about as helpful as the advice I've given you.
Old 04-14-2009, 03:47 PM   #7
john_matrix
Member#: 54787
2005 Saab 9-2x
Satin Gray Metallic
I vote quad turbo.
john_matrix is offline   Reply With Quote
Old 04-14-2009, 04:40 PM   #8
efjellanger
Member#: 64152
Midnight Blue
quint turbo for more lag
efjellanger is offline   Reply With Quote
Old 04-14-2009, 05:42 PM   #9
darksc00by
Member#: 102140
2016 Herp Derping
True to some extent.
I had a 16g and supporting mods on my 2.0L, 14 lbs I made around 230 wheel with 215 ft lbs of torque.. same exact setup but with a 2.5L block I made 260whp 290 ft lbs of torque... on the same dyno, same tuner, and same amount of boost.
Old 04-14-2009, 06:02 PM   #10
DrSaabaru
Member#: 183225
2005 Saab 9-2x Aero
EJ20
LS1
3 rotor Wankel
You need one of these:
http://thelaughbutton.com/comedian/Bill+Cosby/Fat+Albert/2332/Fat+Albert's+Car
DrSaabaru is offline   Reply With Quote
Old 04-14-2009, 06:22 PM   #11
1sicWRX
Member#: 104631
96 Cobra, TBird SC
88 Mustang 5.0
It really only shines when you begin modding it (2.5l swap)
See statement above...
Old 04-14-2009, 07:48 PM   #12
D-NaSty
Member#: 156456
2005 92x aero
its called a search button
D-NaSty is offline   Reply With Quote
Old 04-14-2009, 08:19 PM   #13
darksc00by
Member#: 102140
2016 Herp Derping
565cc injectors, stage 2 parts, and a 16g isn't really modding to me.
I considered the car stock with an exhaust, a frankenmotor, and a tune
Old 04-14-2009, 08:46 PM   #14
manjambles
Member#: 205643
ok sry for not replying earlier but what im looking for is...
an upgrade from my 2.0, but can drop and plug in relatively easy I.E. engine harness plug up to the dash harness with the matching ecu for the motor.
price isnt much of an issue at this point, im looking for something under $3000.
my ultimate question is how different is the engine harness and dash harness from the STI to the WRX. and if i can go that route which version sti motor can i use?
Old 04-15-2009, 10:56 AM   #15
manjambles
Member#: 205643
bump for help
Old 04-15-2009, 11:03 AM   #16
Rudywrx04
Member#: 134273
04 VF 48 P&P
289 WHP 275 WTQ
EJ20
LS1
3 rotor Wankel
But can he do a HEMI?
Rudywrx04 is offline   Reply With Quote
Old 04-15-2009, 11:13 AM   #17
WReXd
Member#: 114101
93 Impreza L Swap
I think the simplest solution would be an ej207 (that's the jdm sti motor) or jdm ej205 motor (v7 or v8). The swap is really easy, and there is very little wiring to do. An ej207 would probably cost you a bit more than your 3k budget, though. However, the swap would be much easier to deal with than an ej257 or ej255, and would perform better than the typical ej257 shortblock/stock heads hybrid (imo).
WReXd is offline   Reply With Quote
Old 04-15-2009, 05:40 PM   #18
manjambles
Member#: 205643
ok so i found a 07 sti motor with 18k on the clock, comes with all wiring and ecu.
would this be a good candidate for this swap
Old 04-15-2009, 05:52 PM   #19
AbACUZ
Member#: 101898
1905 NINETWO EX AIRO
Prodriv.Hotchkis.Stromng.
yes. it would be, and as you can see the 92x crew was more helpfull and nicer about it than the peeps here ...
anyways go 4 it !
AbACUZ is offline   Reply With Quote
Old 04-15-2009, 10:41 PM   #20
manjambles
Member#: 205643
will i need an sti tranny or can i bolt up my 5 speed
Old 04-16-2009, 12:13 AM   #21
manjambles
Member#: 205643
where did it go
Old 04-16-2009, 12:52 AM   #22
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Read all the swap options before making a decision. Some places do great work and others do bs. To do it diy could take weeks or longer.
Trans. yes you can use the 5mt if you rewire some stuff. Yet the 6mt would be stronger.
Common choices...
short block swap ej257 or ej207 with wrx heads with no avcs. (hybrid)
long block sti engine using 2.0 wrx intake. (hybrid long block)
or the full swap of the ej207 or the ej257
You have a lot of reading to do.
Old 04-16-2009, 01:10 AM   #23
manjambles
Member#: 205643
this is the one im planning on doing.
the packge im going for comes with full wiring and fuel pump the only thing i need to get is the turbo.
which is a good canidate?
Old 04-16-2009, 01:29 AM   #24
WReXd
Member#: 114101
93 Impreza L Swap
What? That doesn't make any sense. You need to do more research. Search "drive by wire."
A turbo is the least of your problems.
Old 04-16-2009, 06:57 AM   #25
darksc00by
Member#: 102140
2016 Herp Derping
I don't like the idea of doing a AVCS motor swap on a car without AVCS unless you wire up the AVCS, you will never get the full potential of the motor, that is why I opted to build the 2.5 with 2.0 heads.
92x Aero 05 blown motor; swap options saabarubie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-18-2010 12:03 AM
FS in MO--05 Saab 92x Aero crazysteve Private Vehicle 'For Sale' Classifieds 3 12-29-2005 10:54 PM
Mint Condition 92x aero wheels gmodc7 Private 'For Sale' Classifieds 11 10-24-2005 05:18 PM
For Sale --- Saab 92x Aero 16" Enkei Rims with Re92's dobert Private 'For Sale' Classifieds 12 10-24-2005 01:02 PM
2005 Saab 92x Aero, 2,200 miles in MO 1modh Private Vehicle 'For Sale' Classifieds 13 09-12-2005 09:33 PM
