Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Old 04-14-2009, 09:19 AM   #1
FromK20toEJ20
Member#: 175339
02 wrx
WRC blue
Default EJ20G engine harness?
Does anyone know where I can find an uncut engine harness for a EJ20G?
FromK20toEJ20 is offline   Reply With Quote
Old 04-14-2009, 10:17 AM   #2
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Try E bay ?
sense of nature is offline   Reply With Quote
Old 04-14-2009, 01:34 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
How much is one worth? I've probably got one, and if I don't could make one for you.
Old 04-14-2009, 01:43 PM   #4
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
+ 1 I've seen them pop up on eBay.UK from time to time.
beaviscih is offline   Reply With Quote
Old 04-14-2009, 02:28 PM   #5
Aphex28
Member#: 11506
2015 WRX
WRB +TE37-TA
I've got one in my basement.
Aphex28 is offline   Reply With Quote
Old 04-14-2009, 02:35 PM   #6
FromK20toEJ20
Member#: 175339
02 wrx
WRC blue
not sure exactly hy ow much they cost...i know the whole ej20g swap is normaly under a grand so it cant be that much...if anyone has one there trying to get rid of let me know how much its worth to you. Trying to get ahold of one before the end of the week
Old 04-15-2009, 09:32 PM   #7
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Not to hijack, but I might also be interested in one after this guy gets his.
scoobyimprza is offline   Reply With Quote
Old 04-15-2009, 09:48 PM   #8
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
i betcha-a-dollar that his definition of "engine hareness" is not in line with our standard defination
in the subaru world
engine harness is physcall on top of the engine/under the manifold ~2.5ft long (on a ej20g it would have 4 coils/tps/iac/1wire temp/2 wire temp/ps dummy/ac controls/alturnator/cam pickup/crank pickup and 2 multipin plugs that attach to the rest of the harness)
body hareness -everything else behind the dash including the ecu plugs
you need both for a swap
Old 04-16-2009, 11:04 AM   #9
FromK20toEJ20
Member#: 175339
02 wrx
WRC blue
heres my situation...
my buddy wrecked his L with a ej20g. I picked up the whole swap for 500 bucks to swap into my bugeye that spun a bearing. I was told by ESC that I would need fresh uncut engine harness from a ej20g for them to merge the two harnesses together.
Old 04-16-2009, 11:13 AM   #10
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
whoa horsey whoa
DO NOT PUT a EJ20G INTO a GDA
bad bad idea
i suspect a mis-communication has happened between you and ECS
you might be able to swap the G short block in but wiring it into a GDA is just a BAD BAD BAD idea
your tach will be off, you won't pass emissions,you will have a 20 year old engine in your 7 year old car
list the G swap on your local foums and rebuild your short block
edit* just to reiterate this is a bad bad bad idea
Old 04-16-2009, 01:50 PM   #11
supasweetr34skyline
Member#: 113060
2000 Built GC8
Aiming for 10's
Originally Posted by Jaxx View Post
whoa horsey whoa
bad bad idea
agreed. i would build the build the block and sale off the rest. if its the 16g turbo, cut the 90 degree bend off and use it...
supasweetr34skyline is offline   Reply With Quote
Old 04-17-2009, 02:27 AM   #12
00boostedRS
Member#: 115317
1992 Legacy SS
ive got an ignitor if any of you need one
00boostedRS is offline   Reply With Quote
Old 05-22-2012, 01:17 PM   #13
Djchrisco
Member#: 276308
Hey guys! I need an Ej20G harness gonna put the motor in my 2000 RS. hopefully you guys still have them avalible. and how much do they normally go for?
Djchrisco is offline   Reply With Quote
Old 05-22-2012, 02:03 PM   #14
Scooby921
Merci Buckets
Member#: 88606
2015 GMC Sierra
'13 JCW
Send me a PM. A friend of mine has an EJ20G and the front half of a vehicle harness that's been sitting around for several years in a rally car project we never completed. At the very least I can probably talk him into selling the harness. If you want it you can probably get the entire engine for rather cheap too.
Scooby921 is offline   Reply With Quote
WTB: ej20g wiring harness. Shh!ItGoes11's Private 'Wanted' Classifieds 1 11-08-2006 04:26 PM
Mines flashed EJ20G ecu, and ej20G engine harness liberty2000rs Engine/Power/Exhaust 1 10-31-2006 12:54 AM
FS: ej20g wiring harness, ecu, and other parts smahala1286 Private 'For Sale' Classifieds 1 08-30-2006 10:09 PM
EJ20G wiring harness needed. snowman4us Subaru Conversions 1 10-29-2005 04:27 AM
WTB: ej20g w/ harness jamesfacts Tri-State Area Forum 6 09-03-2004 11:43 AM
