Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 04-14-2009, 11:50 AM   #1
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Default 2006 WRX VF39 Race Map
Started work on a race map for my vf39ed wrx. So far the results are looking great over my pump map. Now I will be working on re plumbing the EWG to get some more boost out of it in the upper range.
I really don't feel like coping everything over from my pump tune thread so here you go:
http://forums.nasioc.com/forums/showthread.php?t=1623281
Mods are:
104 oct
Built motor, with Cosworth 278/274 cams
Helix EWG up-pipe, Tial 38mm EWG, with self made custom extension tube and dump tube
APS Inlet
Perrin V2 Rails
DW 750cc
Walbro 255lph
HKS DP
Greddy Evo 2 CB
SPT Inatke
SSAC FMIC
TGV Deletes
Hallman Pro / GMBCS Hybrid
Here is the big note, this motor was built for a GT35 so please no comments about having the VF39 on there. I am just having fun with it for now until the tranny, new injectors, and turbo are on the car.
Dyno:
310hp/~360tq
Overlay, Pump vs. Race
Video while at DSG
http://www.youtube.com/watch?v=LDoVgq5v4qI
Once I get everything close to done I will be heading to the track, and Matt, the tuner said he would meet me there to finish up tuning.
Questions and comments?
-Rene
Rene2.5RS is offline   Reply With Quote
Old 04-14-2009, 11:58 AM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
I think is awesome I want to see how much the CAMs will help the turbo. You should use C16 and go for 11s, is your car full weight? How much boost are you planning on running? I have to wait until the 05/08 to try to run 11s
Old 04-14-2009, 11:58 AM   #3
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
nice looking set up.....i bet you are excited for the 35r
blowbyu24 is offline   Reply With Quote
Old 04-14-2009, 12:16 PM   #4
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Finally! A vf 39 on a built motor, Im excited. It is a great way to break in the motor and also a way of seeing what that baby turbo can really accomplish.
By the looks of it, im assuming there is no correction in your plot. On 1.0 my car makes exactly 310whp as well!! Curious though, with the cams i figured the graph would hold more to the right?? I fall off to 28X. Maybe you should stop by the Shop in norwalk ct and have Junior take a look at it. Obviously that turbo can only flow so much air, but im willing to bet your timing isnt as aggressive as it can be up top, safely, with such a build (or the cams are just not a good combo with such a small turbo).
STi Mikey is offline   Reply With Quote
Old 04-14-2009, 01:38 PM   #5
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
I have done a lot of my tuning myself but with the race map I have decided to run no knock control so this is why I am having all the major tuning done on a dyno with the use of det cans. My car has always hated the being tuned and this time around using the det cans we were able to hear why, the motor is very noisy and when the ewg cracks open you can clearly hear it through the motor. This and the heads are very noisy. Which is why we have decided on no knock control. My thoughts were to tune for 104 octane fuel and never run less than C16 for the added safety.
At the end of the video I pan the camcorder to the screen if you look closely you will notice that what you are looking at is actually 4 overlaid dyno pulls that are all +/- 3 hp & tq.
Also this is on Rotella T 15w-40 oil. I know I could pick some power up going to a much lighter oil when racing like a 0w-30 but the motor is built for 15-40 and that is all it ever sees including the dead of winter.
juanmedina - I will actually be doing some testing on the weight of the car. I want to go to the track full weight as it rolls now, and then strip most of the interior and go back and see the differences. I will be trailering the car to and from the track now in fear of the tranny. I hopefully will be visiting the track in May at the earliest. Tuning we found that 24-25 psi was a good range. We got it up to 28 psi and the MAFv was lower than 24-25. Right now I am running about 16.5 psi at 7500 rpm, I would like to try and get that up to 18.5-19 and see if there is any improvement.
blowbyu24 - Thanks, I am not trying to think of the 35r much because I am still about a year away from that. When I blew the motor in 07 I figured I only ever wanted to have the motor out once and knew what I wanted with the car and built it accordingly. It is fun now, but I get a lot of flack from people for only having a VF39, I have thought about going to a 20g for now, but I want to have fun at the track with 39
STi Mikey - "Finally! A vf 39 on a built motor" you are not the first to day this. I am interested in seeing what I can get out of it. When you say you fall off to 28X, at what rpm is that. I have not seen many plots of a 39 running out to 7500 rpm. Also yes this is at 1.0 correction.
Old 04-14-2009, 01:44 PM   #6
LateApex31
Member#: 135686
We never run an extra correction factor on our dyno and the atmospheric correction for that day was .966. The boost falls off hard up top due to the soft wastegate spring which allows exhaust manifold pressure to push the WG open.
LateApex31 is offline   Reply With Quote
Old 04-14-2009, 01:46 PM   #7
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
280 @ 7000. I think im in the 260 range at 7300, and have reved it out at the track to right around there on a few 114mph passes. The car doenst seem to fall on its face up top at the track but reving a stock car to7-7500 isnt good so i take turns holding 4th and shifting fifth with absolutely no variance in results. If your bringing her to the track as is, I would highly recomend shifting at 6200 in third and fourth. with the 5 speed you should be comfortably in the 11's
Old 04-14-2009, 01:59 PM   #8
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
In regards to the EWG plumbing see my awesome paint drawing below. I currently run the top port open, and I plan on changing that
Old 04-17-2009, 10:08 AM   #9
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
STi Mikey what track do you visit? I normally head up to Lebanon Valley since I will be trailering it is the closest track for me.
-Rene
Old 04-17-2009, 12:04 PM   #10
06njsti
Member#: 150986
06 #001 LSB STi
wow thats awesome for a vf39, i really want to go bigger this summer but love how fast my vf spools
06njsti is offline   Reply With Quote
Old 06-25-2009, 08:51 AM   #11
sexyyrex
Member#: 128022
2015 Mustang GT
ahh rene, your car is far too quiet! haha how have you been? hows the car comming along? any chance to track it this year yet?
sexyyrex is offline   Reply With Quote
Old 06-25-2009, 11:20 AM   #12
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Yesh peak tq at 4k? That blows unless you have a funkylicous dyno. When do you see full boost on the street?
Swine is offline   Reply With Quote
Old 06-25-2009, 11:56 AM   #13
juanmedina
Member#: 133146
My VF39 with stock engine and E85 used to hit peak torque at 4200 RPM. This car is tune for top end not for a short burst of power at 3500 RPM
Old 06-25-2009, 12:30 PM   #14
DuCash
Member#: 198714
04' JDM STi EJ207
437whp/357wtrq Dom3 24psi
Rene, shouldn't you be making more trq than that for a 2.5L, also i don't think your powerband should fall off so much up top for someone using cams?
DuCash is offline   Reply With Quote
Old 06-25-2009, 12:31 PM   #15
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
cams will generally push the power to the right of the powerband. I know the Dynamics Dynos read pretty low so that looks like some pretty impressive numbers. I can't wait to see some trap speeds.
That's at 4400rpms though. That's a ton of torque for such a small turbo that late in the rpm.
Steve.804 is offline   Reply With Quote
Old 06-25-2009, 01:44 PM   #16
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
awesome man im doing the same thing while waiting for mt 35r....
BlackJavaPearl04 is offline   Reply With Quote
Old 06-25-2009, 02:06 PM   #17
CatfaceType-R
Member#: 81102
something is wrong if you are losing power that early with cams...
CatfaceType-R is offline   Reply With Quote
Old 06-25-2009, 02:37 PM   #18
DuCash
Member#: 198714
04' JDM STi EJ207
I'm not knocking the set-up, just that i made the same amount of trq with my JDM 2.0L Sti with the VF37 turbo, and that's on 90oct + meth
Cams should boost your top-end power....or is it that the turbo has run out of breath???
Old 06-25-2009, 02:45 PM   #19
juanmedina
Member#: 133146
numbers....
Old 06-25-2009, 02:57 PM   #20
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
based on your dyno plots its not even worth wasting the money on race gas......you only picked up 5-10whp in the drag racing powerband.
Old 06-25-2009, 03:50 PM   #21
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
+1 for a boost graph. Perhaps you're trying to hold too much boost and killing the efficiency.
Merp is offline   Reply With Quote
Old 06-25-2009, 03:55 PM   #22
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
While i would normally agree with you, my +10whp/wtq race gas map picked up over 2mph than my pump gas map.
Car is an 05 STI with a catless TBE, pos short ram...pump and a race map from Topspeed.
Trapped 107.5mph on pump and trapped 109.7mph on race. Same track, similar temps but different nights. Conditions were similar(cool, clear, 30-50% humidity...unsure of the calc d/a though).
Soooo just fyi...
Old 06-25-2009, 04:03 PM   #23
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
My sti held over 300wtq for 2500rpm(on ts's dyno obviously). His with alot more go fast parts holds it for 1500 rpms. Something is amise me thinks.
Just looking at his numbers, the only thing i have to look at currently, n o t impressed. But if these numbers get him a 110+ trap, i will be.
Old 06-25-2009, 04:35 PM   #24
juanmedina
Member#: 133146
Again numbers , if you look at my old road dyno I only hit a max 330wtq at 4140RPM on E85 22.7psi and I trapped 94mph in the 1/8th with a VF39
At what track did you run? This thread is old anyways
I agree 10hp = 1 tenth which is a lot to me!
Old 06-25-2009, 09:09 PM   #25
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Again numbers ,
Just looking at his numbers, ***********the only thing i have to look at currently***********
On road dyno software...i know.
Montgomery motorsports park.
Agreed, hell my +10hp race gas tune got me 0.25 sec and 2.2mph. Well worth the extra $50 it cost for the map...people spend way more then $50 on useless other crap that doesnt give them anything.
06 wrx VF39 cobb map work with 07 VF43 Turbo? Nasty25 AccessPort 3 12-02-2009 04:53 PM
06 WRX-VF39-Airboy map-logs-some questions Team Scream Open Source Reflashes 0 01-26-2009 07:06 PM
06 wrx VF39 cobb map work with 07 VF43 Turbo? Nasty25 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 12-30-2008 06:50 AM
2006 WRX VF39, OTS Cobb Map Matt_H Proven Power Bragging 15 05-21-2007 06:05 PM
