Old 04-14-2009, 11:52 AM   #1
turbonick
Member#: 65494
98 wrx sti
blue
Default Pros and Cons on going rotated
I'm building an EJ257 right now. Stock Crank and rods with 100mm CP pistons with V3 heads with stock cams. PE850 injectors and a VF43 turbo. A friend has a GT3076R that he'll give me really cheap. I've seen a non rotated kits but a lot more rotated ones. What are the advantages of going rotated? And are there any disadvantages... besides having to buy all the rotated piping? Can't find much with the search button.
Thanks,
Nick
turbonick is offline   Reply With Quote
Old 04-14-2009, 11:05 PM   #2
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Go rotated and never look back. Its much easier to work on and opens up alot of options down the road.
scby rex is offline   Reply With Quote
Old 04-15-2009, 07:13 AM   #3
c'dalerider
Member#: 92388
04 WRX, 06 STI
wrb x 2,900awhp combo
agreed.you will eventually go to a rotated setup, so just bypass all the wasted $ and time. If i could get back all the wasted time and money farting around on different turbo setups...my head hurts.
Also, consider getting different injectors? Pe's 'leak' (poor idle..etc) IMO.
c'dalerider is offline   Reply With Quote
Old 04-15-2009, 09:12 AM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Don't need to buy, you can MAKE pipes!!!
FuJi K is offline   Reply With Quote
Old 04-15-2009, 01:34 PM   #5
turbonick
Member#: 65494
98 wrx sti
blue
Default Rotated
Thanks! I haven't found anyone on any forum recommend staying with the stock location. I also agree that I can have the piping made up. I would have to go with an external waste gate anyway since its an off the shelf GT30R. I might as well rotate since I'll have to fabricate anyway.
Old 04-15-2009, 01:41 PM   #6
j.r
Member#: 201800
2007 STI
gt30r
I've sold most of my stock location FP green and supporting mods. Got my 30r installed and getting tuned this weekend.
The rotated 30r is arguably the best performing street/track (not autox) setup. And if you want to go bigger all you have to do is buy a 35r
j.r is offline   Reply With Quote
Old 04-15-2009, 01:57 PM   #7
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
i dont think there are any cons to going rotated.. maybe the need for special fitting dp/up/inlets.. but thats all understood when you 'go rotated' right?
AlxSti is offline   Reply With Quote
Old 04-15-2009, 02:19 PM   #8
surfer5567
Member#: 61199
2002 wrx wagon
wrb, s2, blouch 2.5, 6spd
equally interested. ive been searching FOREVER on a atp stock location 30r vs like a perrin roated 30r...ive found that they make around the same power but spool is different on the roatated.
surfer5567 is offline   Reply With Quote
Old 04-15-2009, 05:17 PM   #9
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
No down side but costs. They just kick ass and spool better, usually easier to work on too. Its just $$$ in all ways.
Fongers is offline   Reply With Quote
Old 04-15-2009, 06:46 PM   #10
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
I feel rotated setups have a cleaner look and you can run a nice big intake.
alcoolaid is offline   Reply With Quote
Old 04-15-2009, 07:32 PM   #11
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Which helps spool!
CKxx is offline   Reply With Quote
Old 04-15-2009, 10:25 PM   #12
stu
Member#: 25768
35R bugeye
Slowbaru
everything becoms easier to work on in the engine bay when you go rotated and turbo swaps are easy
stu is offline   Reply With Quote
Old 04-15-2009, 11:10 PM   #13
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
pros- anything and everything
cons- price
even price, when starting from scratch its aboot the same.
godforbid67 is offline   Reply With Quote
Old 04-15-2009, 11:28 PM   #14
sk8rtilldie
Member#: 157070
03 RR EVO *8
WFC #44
THIS IS A BIG PRO
sk8rtilldie is offline   Reply With Quote
Old 04-16-2009, 12:27 AM   #15
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
cons- price
What he said.
If you have not already invested in all of your supporting mods, and you want anything near an 30r sized turbo, the rotated kit is the way to go. It MIGHT even be cheaper if you buy used, and/or have piping fabbed.
aboothman is offline   Reply With Quote
pros and cons on lightend flywheel 1FastREX South East Region Forum 24 08-26-2004 07:41 PM
GFB pulley kits, pros and cons and how to install Imprezanize Normally Aspirated Powertrain 1 04-06-2004 10:39 AM
Pros and Cons of a 4EAT on a WRX? KevinWRX Transmission (AT/MT) & Driveline 53 03-05-2003 01:44 PM
Pros and cons of 17's and 18's Hope2BinWRC Brakes, Steering & Suspension 10 05-07-2002 04:34 PM
('93-'01) Pros and Cons on two cars EnterTheDragon Impreza Forum 19 06-28-2001 11:59 AM
