Old 04-16-2002, 11:17 PM   #1
Stranger
Member#: 728
2000 2.5RS-T Stage2
Default How to turn of the turbo
I have an ASR turbo - I need to disable it for a little while.
How?
Stranger is offline   Reply With Quote
Old 04-16-2002, 11:25 PM   #2
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
I'm thinking there is no way to "bypass" it. You'll have to probably remove the up pipe, downpipe, and replace it with the factory exhaust manifold. And probably take the turbo and intercooler out as well.
I'm not 100% sure though, seeing as how I'm just learning about turbocharging.
tcs007 is offline   Reply With Quote
Old 04-16-2002, 11:29 PM   #3
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Just go straight from the filter to the throttle body. The turbo will still spin, but not produce boost going into the engine.
Impreza Rider is offline   Reply With Quote
Old 04-16-2002, 11:39 PM   #4
Stranger
Member#: 728
2000 2.5RS-T Stage2
Ok. another question:
if I block the vacum line that goes to westgate (I'm not sure what the thing is called) will that stop turbo from activating?
Old 04-16-2002, 11:58 PM   #5
RallyNavvie
Member#: 7113
2008 Spec B
It's late and I'm not thinking quite clearly but I think if you block the vac line going to the wastegate the turbo will be constantly on meaning MAD overboost at high RPMs. Depending on the type of wastegate you could also just open the thing so all exhaust is bypassed. Otherwise get some silicone ducting and run it directly between the filter and the TB. You'll notice a little loss of performance (less than the NA even) because of the turbo slowing air going into the engine if you open the wastegate. Not a big deal though.
~Garrett
RallyNavvie is offline   Reply With Quote
Old 04-17-2002, 01:36 AM   #6
Avenger
Member#: 1234
If you block off the hose to the waste gate it will try to get the turbo to full boost because the waste gate is not bypassing the exhaust to the turbo, this might over heat the turbo. But I think even if you disconnect.
If you do this, it will be like blocking the waste gate hose. because the line to the waste gate is showing no boost so it directs exhaust to the turbo.
I think the only way is to get the waste gate open by removing the spring and the valve in there or some how apply pressure to that line and make it hold in there.
Avenger is offline   Reply With Quote
Old 04-17-2002, 01:44 AM   #7
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Why would you want to do this?
That is like asking, "how do I make the toilet not flush after using it..."
ImprezaRS dot com is offline   Reply With Quote
Old 04-17-2002, 02:26 AM   #8
Avenger
Member#: 1234
Well, I might have to remove my system every two years for emission testing. The people who does the driving here are crazy.. I'm sure they'll blow up my car with the turbo in, or I might not even pass the test.
Old 04-17-2002, 09:37 AM   #9
Z1 Performance
Member#: 9327
well, you could shut the car off...that disables it!
Short of removing it fromt he system, there is no way to disbale the turbo, unless you put in a super low spring to your wastegate, and run it at the lowest possible boost.
What type of emissions testing do they have in Canada...dyno? road use?
Z1 Performance is offline   Reply With Quote
Old 04-17-2002, 11:05 AM   #10
Avenger
Member#: 1234
In Vancouver we use 4 wheel dyno.
Old 04-17-2002, 03:01 PM   #11
Stranger
Member#: 728
2000 2.5RS-T Stage2
I need to take the turbo off (eventualy) 'cause there is some work that will need to get done on my trany, but with the turbo there they are not allowed to touch it.
but I couldn't take it off my self ('cause the bolt are so hard) so I want to go to have some shop just loosen them up for me.
problem is that there are oil lines running to the turbo, wich I need to block, so idealy I wanted to:
disable it
block oil lines
remove it
Old 04-17-2002, 08:42 PM   #12
STiTuner
Member#: 5778
09 135i
Jet Black
what about if he took his BOV off and had an intake leak would that work? put a breather ilter on over where it used to be and you should be set.
Unless you have a MAF then just run a tube to the front of the turbo w/ no BOV.
Brad
STiTuner is offline   Reply With Quote
Old 04-17-2002, 08:56 PM   #13
Avenger
Member#: 1234
Brad
Again the wastegate will see not enough boost and try to create more boost by diverting exhaust to the turbo.
Old 04-17-2002, 10:22 PM   #14
STiTuner
Member#: 5778
09 135i
Jet Black
is it an external wastegate or an interal actuator?
cause if its an actuator you can un hook the wastegate spring from the little flap that opens up and it will alwasy bypass it.. maybe causing a LITTLE boost but not much.
or if its a external wastegate try just taking the spring out.
Brad
Old 04-17-2002, 10:34 PM   #15
Stranger
Member#: 728
2000 2.5RS-T Stage2
(It's external waste gate)
Ok turbo has been removed:
Do you need to block the vacum lines going to:
waste gate
blow off valve
Also, my cesnors got velded to the exast.
Old 04-17-2002, 10:36 PM   #16
Stranger
Member#: 728
2000 2.5RS-T Stage2
Also:
I have a "split second" timing controler
what should I set it to when the car has to turbo?
should it be all 0s?
Thank you guys!!!
Old 04-17-2002, 11:09 PM   #17
Avenger
Member#: 1234
waste gate
blow off valve
You would need to block off the vacuum line going to the waste gate and the blow off valve or you'll have a air leak and the car would run bad.
Old 04-18-2002, 03:14 AM   #18
Stranger
Member#: 728
2000 2.5RS-T Stage2
Thanx Alv.
I will do that.
damn. taking off the turbo is a pain in the butt.
+ I figured out why I have/had some problems with it.
the up pipe is cracked.
anyways, trany work within next few weeks and back to puting it back together.
BTW anyone knows if you can get your smog inspect. done earlyer then you have to?
it would be so convinient for me.
Old 04-18-2002, 04:35 AM   #19
XT6Wagon
Member#: 524
04 STi
I don't see why you can't get it done at any time. After all its your $$$. I am sure it will only be good for the year after the actual test or whatever interval your emissions testing is at, not one year form the date you had to get it done
XT6Wagon is offline   Reply With Quote
Its almost 2009..How the **** do people still not know how to turn off a computer???? I25 Off-Topic 15 11-25-2008 02:53 PM
does anybody know how to turn off the clicking sound on an 2.5i impreza? rhinh25 Electrical & Lighting 2 08-06-2007 02:19 PM
05 STi Cluster in to 04 STi..How 2 turn off the ABS light/Parkinh light 1rarewrx Electrical & Lighting 3 11-30-2006 02:05 PM
How to turn off the parking lights on 03 rs... Fett52 Electrical & Lighting 1 05-03-2006 04:23 PM
how to turn off stock alarm... or at least the horn. ratboy Car Audio, Video & Security 10 01-12-2003 12:32 PM
