Old 04-15-2009, 09:00 AM   #26
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Originally Posted by AJ711 View Post
Emailed that guy about 10 minutes ago.
Jard is offline   Reply With Quote
Old 04-15-2009, 09:01 AM   #27
dunk
Member#: 15359
Originally Posted by Jard View Post
Day crew bump, need help with this. ^^^
I don't see a reason to spend 500 extra dollars. The lights on the econotrailer are LED, and I never had an issue with them, even after two years. As far as a warranty, there really aren't any wear parts on a trailer other than the bearings, brakes and tires, all of which are inexpensive to replace.
-Duncan
dunk is offline   Reply With Quote
Old 04-15-2009, 09:04 AM   #28
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
AJ711 is offline   Reply With Quote
Old 04-15-2009, 09:05 AM   #29
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
That same trailer is $2,400.00 in Frederick, MD.
http://www.hillsidetrailers.com/item.aspx?i=31
Work them against one another?
Old 04-15-2009, 09:20 AM   #30
KC
Member#: 442
16 SS
00 S2000
You can't go wrong with any of them really. I have a Wright that I'm going to be selling soon that I bought locally that's been solid for the 6 years I've had it. Just like a car, make sure it's had it's regular maintenance done... bearings, brakes, tires and make sure the breakaway battery is still in working order.
--kC
KC is offline   Reply With Quote
Old 04-15-2009, 09:22 AM   #31
dunk
Member#: 15359
--kC
On my enclosed trailer, I installed a breakaway kit that has a battery charging circuit. Saves the hassle of having to worry about pulling the battery and charging it once a year.
-Duncan
Old 04-15-2009, 09:23 AM   #32
KC
Member#: 442
16 SS
00 S2000
-Duncan
Still, it's only an X-year battery.
Old 05-12-2009, 11:51 AM   #33
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
I ended up buying an 18' open trailer from Dively in PA. I brought it home on Saturday.
Thanks to dunk for LOTS of advice sent through PMs and for putting up with all my questions.
Old 02-26-2013, 11:35 PM   #34
Tucci139
Member#: 336953
2005 Impreza 2.5RS
Regal Blue Pearl
Update?
I'm considering buying a trailer for my Impreza - can you give me an update on how the trailer has been and what you would recommend after your experience with the trailer? I was considering a used Featherlite or Aluma, but the prices are so much more than what you considered buying.
Tucci139 is offline   Reply With Quote
Old 02-27-2013, 06:40 AM   #35
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Yeah its been rock solid, no issues at all. The only thing I will say is I wish I got a 16' instead of the 18'. I've never *needed* the extra length and the 18 is harder to maneuver in tight spaces.
Old 02-27-2013, 08:31 AM   #36
Georgethefierce
Member#: 41713
. sprayfinishing
supplies.com
I have a 16' Diverly and it has been perfect for the 3 years I have had it, had to ad some ramps in the middle so the little car fit on it but no issues....can't go wrong really.
Georgethefierce is offline   Reply With Quote
Old 02-27-2013, 08:49 AM   #37
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Hmmm...
Prices appear to have gone way up since I bought mine.
http://www.econotrailer.com/Open.html
I did go and pick mine up, and saved some money there.
Old 02-27-2013, 03:39 PM   #38
Georgethefierce
Member#: 41713
. sprayfinishing
supplies.com
wow, I agree, I picked mine up at a distributor for WAY less than that
Old 02-27-2013, 03:45 PM   #39
Grap
Dicky Nipperist
Member#: 6590
It was perfect for towing the Plymouth.
Grap is offline   Reply With Quote
Old 02-27-2013, 03:53 PM   #40
fliz
Member#: 30342
Put a tire rack and storage box on the front.
Holds 8 tires and 6 "not for fuel" wide-mouth fuel jugs.
fliz is offline   Reply With Quote
Old 02-28-2013, 11:46 PM   #41
Tucci139
Member#: 336953
2005 Impreza 2.5RS
Regal Blue Pearl
Any regrets not going with aluminum? I was thinking of Featherlite, Eby, Cargopro and Aluma. Prices are about $5-6K though, but thought in the long run they maybe better. Also, what do you think about flat vs the split style you bought? I like the idea of working under the car sometimes, but I have a lift to use in the family business so I am a bit spoiled. So, far I am leaning towards getting 16ft version similar to yours and figure I could replace the trailer in several years if needed for the money I save - but thought I would ask what you think.
Old 03-01-2013, 12:04 AM   #42
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
I wish I got a 20' trailer instead of an 18. Def wouldnt get a 16'.
For the cost, I dont think Aluminum is worth it. Its 2-4x the cost, same weight. Doubt itll last 2-4x longer. Id rather throw away a steel trailer after 10 years.
After borrowing many trailers with full decks and split decks, and wood vs metal decks, I bought a full wood deck. Its much more versitile as to what I can haul. And if I want to have an open center, I can just remove the boards in the center.
Old 03-01-2013, 01:13 AM   #43
Tucci139
Member#: 336953
2005 Impreza 2.5RS
Regal Blue Pearl
Interesting about removing boards when you need to - didn't think of that. As far as lasting ten years - I'm an old fart so I hope I am still doing this in 10 years I was thinking more for resale and just quality while I use it. But, I guess if one of my kids takes the setup it maybe good to have a durable trailer.
Thanks for the advice - you all are making it a tough decision for sure.
Old 03-01-2013, 01:16 AM   #44
Tucci139
Member#: 336953
2005 Impreza 2.5RS
Regal Blue Pearl
looked at weights on the 18ft Bri-mar wood trailers - wow - almost 900 lbs heavier. Not sure the extra weight is a good idea. My tow vehicle is a 1/2 ton pickup so I need to be lower on weight if possible.
Old 03-01-2013, 01:35 AM   #45
Davidss
Member#: 27446
If you know how to weld you should consider building a trailer. It's easy and fun. I built one a year ago and did a whole thread documenting the process:
http://honda-tech.com/showthread.php?t=3020002
Davidss is offline   Reply With Quote
Old 03-01-2013, 02:25 AM   #46
Tucci139
Member#: 336953
2005 Impreza 2.5RS
Regal Blue Pearl
Very impressive - if your not an engineer, you have a future as one. I do have access to welding equipment and I know how to weld aluminum and steel - but frankly I am not that good at it. It takes practice and time, which unfortunately I am short of. (Ex. recently - it took me two months to build a wood shed which should have taken only one day.)
Be a great project though and hope others see it and give it a try. Nice job!
Old 03-01-2013, 06:39 AM   #47
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
My Caliber wood trailer is 1300# unloaded. I pull it with a Tacoma
Old 03-01-2013, 08:01 AM   #48
Georgethefierce
Member#: 41713
. sprayfinishing
supplies.com
also, keep in mind that aluminum is hard to repair and has Kahn said, the steel trailers aren't as heavy as you'd think (mine also comes in at #1300 full steel/spli deck) there are people that NEED an aluminum trailer, if you don't it's not worth the added expense (IMHO of course)
Old 03-01-2013, 08:10 AM   #49
fliz
Member#: 30342
I'm in the flat midwest, so the minor weight difference doesn't matter at all. If you were towing in mountains it might be worth it.
I like the split style mainly for the ease of washing the car off after rallies. It's a lot easier to get a power washer under the car with the split trailer.
I've never needed/tried to work on the car, there's too much framework to make that easy.
Mine is actually home-built. My only issues so far have been the original had poor tie-down points (one broke off and almost lost the car), and there is only an inch of suspension travel before the axle bottoms out on the frame.
Old 03-01-2013, 08:26 AM   #50
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
That hondatech dude put his axles too far forward..
EDIT: Disregard. Super short trailer for a CRX.
Double edit: You can see how having too short of a trailer means he's having a hard time strapping the car down.
18' Open Car Trailer Tcal MWSOC Private Classifieds 21 01-04-2008 10:04 AM
18' Open Car Trailer (used only 3 times) Tcal MWSOC Private Classifieds 7 06-13-2007 07:44 AM
Open car trailers? WorstNameEver Mid Atlantic Impreza Club -- MAIC 28 03-20-2007 09:41 PM
FS: NYC area, 1992 F350 Quad Cab, + Open Car Trailer ScubyMedic Private Vehicle 'For Sale' Classifieds 7 02-17-2007 08:09 PM
Trailex - Aluminum Open Car Trailer - The Best Beldrueger Private 'For Sale' Classifieds 1 03-05-2004 10:47 AM
