Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 04-14-2009, 01:47 PM   #1
uberspeed
Member#: 87871
Default What would you do? 2.5L DOHC to SOHC in '98 RS
Got a '98 2.5RS. Bought it with the assumption that the timing belt snapped. Pulled the timing cover off and found this:
I think a cam or the water pump seized and the pulley couldn't handle the torque and cracked. I'm assuming the heads at a minimum need to be rebuilt.
So I found a SOHC 2.5 from a 2001 2.5RS with low miles for a good price:
I was planning on just swapping the 2 engines but after a little reading it seems that this is not a "subarus are legos" affair.
1. Sell the SOHC, rebuild DOHC?
2. Swap SOHC (what is all involved?)
3. Some frankenstein?
I have no interest in doing a turbo engine in this. I want to do this on a modest budget.
Thanks guys!
uberspeed is offline   Reply With Quote
Old 04-14-2009, 03:17 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
whats a good price? (for the sohc)
start searching for 98 outback heads (way more common) you will only run into cels with the sohc
Old 04-14-2009, 06:19 PM   #3
uberspeed
Member#: 87871
the SOHC cost me $300 with only 72k miles on it. Wish I could use it.
Old 04-15-2009, 10:16 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
it will run but it will be 100% happy ..
Man finds $88 billion in his account. What would you do to keep it? Snoopy Off-Topic 38 04-02-2010 12:22 PM
What would you do or say anything to her? Donzo Off-Topic 55 01-19-2007 11:31 AM
2.5l build. what would you do if you could start over. kinada423 Built Motor Discussion 39 01-19-2007 04:35 AM
Mid-A Photographers - What would you do if this happened to you? Lone Wolf 75 Mid Atlantic Impreza Club -- MAIC 19 09-03-2005 11:04 AM
02-05 WRX owners. If you had to do it all over again what would you do? SinhCredible General Community 29 08-13-2004 06:28 PM
