Old 04-17-2002, 12:19 AM   #1
Nesta722
Member#: 5297
1994 Impreza
Brighton - Glacier White
Angry Help!!!
I have tried everything!!! I have a 94 FWD Impreza 5spd. At partial throttle, I get a rocking/hesitation feeling, it usually only happens when I'm lower in an RPM. Things I have already checked are, spark plugs wires - replaced, PCV Valve - replaced, Fuel Filter - replaced. These were all things that were suggested might be the problems, I've also since changed the air filters, had the mass air flow sensor as well as throttle positioning sensor looked at and those both seem to be in good working order. The time I noticed this first happening was after I had my half axles re-packed with grease, and a new caliper put on. The car has about 127k on it, and had a new clutch put in at 110. I'm stuck, anyone have any ideas?!
Matthew
Nesta722 is offline   Reply With Quote
Old 04-17-2002, 10:24 AM   #2
-=C=-
Member#: 7719
99 F-150 crew cab
with illegals in bed
Send your post to the NA forum...You'll get a quicker and more technical response.
-=C=- is offline   Reply With Quote
