Old 04-14-2009, 09:46 PM   #1
STiGMATA
Member#: 47564
06 STi
black w/black BBS
Default ross pistons problem =( !!!!
hey everyone.....i bought some ross 100mm pistons part#99886 and i send them out for HPC coating on the top and sides....i get them back today, and i start assembly and i install the first piston and go to rotate the crank to make sure there isn't any binding and i dont even get to do one full rotation and the crank just stops so im wondering whats the deal.. then i rotate it the opposite way piston comes up then back down and same thing it stops so i decide to look at the other pistons and seee that the skirt on the ross pistons is .215 taller than the stockers...so the skirt is hitting the bottom of the bore before the rod reaches the bottom so now i have to call ross and see what they can do, cause now im stuck without a car ....
any ideas from any experienced builders or someone else that has used the ross pistons....thanks
did some quick measurements.....
from the top of the piston to the top of the pin (stock .7555 / ross .746)
from the top of the pin to the bottom of the skirt (stock 1.2575/ ross 1.3985)
pin diameter .905......
STiGMATA is offline   Reply With Quote
Old 04-14-2009, 09:55 PM   #2
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Where is the deck height at right now?
Are you above or below deck with these pistons?
I wonder if the set you got was previously ordered with a custom pin height or something like that.
Rotate to TDC and measure the deck height.
Also measure the pin heights between stock and teh Ross.
Team Scream is offline   Reply With Quote
Old 04-14-2009, 09:55 PM   #3
q_dubz
Member#: 168482
hitting oil squirters?
q_dubz is offline   Reply With Quote
Old 04-14-2009, 10:07 PM   #4
STiGMATA
Member#: 47564
06 STi
black w/black BBS
from the pin to the top of the piston is exactly the same as stock its the actual skirt is .215 longer.....ill take a pic and post it up
Old 04-14-2009, 11:03 PM   #5
STiGMATA
Member#: 47564
06 STi
black w/black BBS
measurments added to first post, and pics soon to come
Old 04-14-2009, 11:06 PM   #6
Team Scream
Member#: 121532
2006 FXT/STi 6MT
Well if that's the case then they may be able to be machined down, assuming the skirts are (will be) as long as they are supposed to be to keep the piston square in the bore at rpm.
oooops just saw that you added measurements.
That Ross is damn ten thou shorter, which means your compression ratio is going to change if you use them.
Not by much but it will change a slight bit.
Old 04-15-2009, 01:39 AM   #7
STiGMATA
Member#: 47564
06 STi
black w/black BBS
yeah i used my starrett calipers and depth mic to get the measurements....plus bump for pics
Old 04-15-2009, 02:06 AM   #8
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Dude, if I am right, you are going to feel like an idiot. But at least an idiot who doesnt have to mod something.
I just put a stock STI piston into a spare block and it pushed 3/4" PAST the access hole.....
So, rotate the crank and make sure the rods that DONT have pistons attached are not catching....
Not saying your are an idiot, just that you make hit yourself in the forehead.
Old 04-15-2009, 02:16 AM   #9
Team Scream
Member#: 121532
2006 FXT/STi 6MT
Hmm....
Old 04-15-2009, 07:08 AM   #10
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
You're probably right
alcoolaid is offline   Reply With Quote
Old 04-15-2009, 07:52 AM   #11
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Agreed
Marnix is offline   Reply With Quote
Old 04-15-2009, 11:32 AM   #12
STiGMATA
Member#: 47564
06 STi
black w/black BBS
nope your wrong ....cause i thought of that yesterday, and decided to drop a ringless piston in the bore without the pin in the rod and the piston is actually all the way down when its lined up with the pin hole.....
Old 04-15-2009, 12:15 PM   #13
STiGMATA
Member#: 47564
06 STi
black w/black BBS
well i just called ross, and i guess its a design flaw, he said they will fix the prob for me.....i guess they designed the piston with too robust a skirt,lol
Old 04-21-2009, 05:41 PM   #14
Team Scream
Member#: 121532
2006 FXT/STi 6MT
Hey that is great news that they will fix it for you...I hope that means they are going to make you a new set properly and not mod the ones you have?
Furthermore, I hope they turn it around for you most ricky ticky.
Old 04-21-2009, 05:48 PM   #15
madmax718
Member#: 172501
heh, its too bad, if only you could get a custom crank and rod combo, it could work!
madmax718 is offline   Reply With Quote
Old 04-21-2009, 08:01 PM   #16
jays05
Member#: 78165
05 STI 35r + e85
Do you get a discount for testing parts for them?
jays05 is offline   Reply With Quote
Old 06-23-2009, 11:47 AM   #17
STiGMATA
Member#: 47564
06 STi
black w/black BBS
ha ha ha , no!!!! just a new free set of correct pistons......
Old 06-23-2009, 04:05 PM   #18
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
I've seen this happen from a number of piston manufacturers. For whatever reason they make the skirts too long and they either hit the base of the block or the rod itself.
As you found out the fix is to have them machine the skirts down.
Thanks,
Phil
Element
Element Tuning is offline   Reply With Quote
Old 06-23-2009, 11:05 PM   #19
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
That kind of integrity doesn't exist in this field.
Old 06-23-2009, 11:17 PM   #20
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Thanks,
Phil
Element
Really?!! From who?
...when did he add the comment on the skirts? my reading fails as I missed the entire part on rotating and then stopping
Old 06-23-2009, 11:46 PM   #21
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Wrist pin holes ?
sense of nature is offline   Reply With Quote
Old 06-29-2009, 11:34 PM   #22
STiGMATA
Member#: 47564
06 STi
black w/black BBS
Originally Posted by sense of nature View Post
Wrist pin holes ?
yeah the holes on the block that you use to slide in the wrist pin to connect the piston to the rod....
Old 06-30-2009, 04:37 PM   #23
Element Tuning
Member#: 54918
673 WHP Element
Originally Posted by Homemade WRX View Post
Really?!! From who?
All have fixed this except Ross I guess
I have had problems with CP, Ross, and Manley pistons hitting. Our CPs at the time, keep in mind this has to be more than 4 years ago and this hasn't been a problem now for years, had to clearanced the bottoms by hand (do what you have to when a race is around the corner). The Ross pistons we had clearanced a little (this had to be 7 years ago), and the Manleys we just sent back. I get tired of fixing %$* for people and honestly when you tell them you usually get the, "we've never had that happen before we've sold many...." . I remember also pulling someone's built motor apart and you could see where the skirt was kissing the block but I don't remember the piston manufacturer. Most now have these issues figured out but when the 2.5 STi block was new this wasn't the case.
Also keep in mind not all rods are the same length but honestly all the above hit so bad it wouldn't have mattered which rod you used
Old 06-30-2009, 09:57 PM   #24
3MI Racing
Member#: 200987
I HATE that line
But alas with doing only custom parts now, that issue has gone down greatly
3MI Racing is offline   Reply With Quote
The piston height on my ROSS pistons are out to lunch! cribbie Built Motor Discussion 31 06-20-2009 05:02 AM
F/S: (MN) NEW Ross Pistons 100mm, EJ257 block, bugisti Engine/Power/Exhaust 33 04-20-2009 03:43 PM
F/S: Ross Pistons ej25 (in MN) bugisti Engine/Power/Exhaust 0 12-26-2008 11:38 PM
ej22 ross pistons tonzo Engine/Power/Exhaust 16 05-14-2008 08:53 PM
Anyone using ROSS pistons ? bugeyes Built Motor Discussion 0 06-26-2006 04:10 AM
