Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 04-15-2009, 11:25 AM   #1
B-Kerr
Member#: 14841
2002 Impreza WRX
WRB, VF22, Cusco, Unichip
Default Engine coatings... heat retention... thoughts?
Everyone knows heat from the engine/exhaust is lost power... what about low emissivity / low absorptivity coatings, specifically powdercoats for the block and head. They apply at temperatures low enough that they will not distort or the parts or effect stress. Easier to clean. Look better. Seems like a win-win...
I have powder coated some Honda blocks before without any issue using regular coatings - no distortion or ill effect. However, I have been thinking about thermo-class while I am building my 2.5 for my bugeye. I remember that black-nickle oxide has the best a/e ratio; its what the "miracle thaw plate" was made from, but there should be powders/ceramics that do a good job of not absorbing ambient heat and retaining internal heat.
Just thinking... appreciate any thoughts anyone else has.
B-Kerr is offline   Reply With Quote
Old 04-15-2009, 02:58 PM   #2
AlxSti
Member#: 94615
|'06 STi 341/356|
www.AffinitiBrokerage.com
Interesting.. I don't think I've ever seen this done.
AlxSti is offline   Reply With Quote
Old 04-15-2009, 04:02 PM   #3
~snowman~
Member#: 207011
Ceramic combustion chamber?
~snowman~ is offline   Reply With Quote
Old 04-15-2009, 04:23 PM   #4
AlxSti
Member#: 94615
|'06 STi 341/356|
I have a better idea.. Why don't we invent a way to make cold water run around the block to cool it!? But how do we keep the water cold?? Hm...
Old 04-15-2009, 05:17 PM   #5
howfast?
Member#: 102027
BugI Tsx retro lamps
for sale not listed pm me
I just saw this company posted last night, someone in SF is using them for powdercoating. I bet you could call them and see who uses their heat resistant Cerakote in your area, or how you can get some and do it yourself etc...
http://www.powdercoat-it.com/sacrame...t-coating.html
howfast? is offline   Reply With Quote
Old 04-15-2009, 06:06 PM   #6
Krang
Member#: 134272
Chapter/Region: HIIC
2002 WRX Wagon - WRB
ej207 v8 vf37
So lets say we already have a way to do that, what else could we do to keep our block cool? How about a really neato engine coating!
Krang is offline   Reply With Quote
Old 04-16-2009, 12:39 AM   #7
B-Kerr
Member#: 14841
2002 Impreza WRX
Axlsti... I know your being an ass (as is Krang), but I do see your point... anything a person does to control engine temp will be negated by the thermostat and cooling system. Wasn't thinking that way... initially started thinking about exhaust coatings (such as wraps and ceramics to increase exhaust velocity), and moved more toward the engine. Yes it is a "neato engine coating", it does make an engine look nice an easier to clean, but you are right, it is useless for temp control except on non-water cooled parts like intake and exhaust.
Anyway...
HOWFAST: that is a neat set-up they have, but it looks as if it is a liquid process, so it would be next to impossible to duplicate by the do-it-yourselfer. There are ceramic based powders out there though.
SNOWMAN: ceramic combustion chamber would kick a$$! It could be done, but you would have to have a bare head. That is interesting...
Old 04-16-2009, 01:50 AM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Actually, coating the inside of engines to retain heat is a not totally unusual. It does improve efficiency slightly. However, the engine design theory book I just finished did address this directly. It turns out that loss into the metal of the engine is a trivial fraction of the total inefficiency of the engine. Even presuming you could block 100% of the heat from making it into the metal of the engine, the max theoretical possible gains are tiny.
Old 04-16-2009, 07:54 AM   #9
~snowman~
Member#: 207011
ya, i have this crazy thoughts about heatsinks, sounds like snake oil i know. Ya, everything these days is getting smaller, faster, quicker, pushing limits of max effeciency as is, and in effect runs hotter. We are changing as humans with our demand for power. Its true an old 386 computer barely took any power/watts to run, but alot of our technology is friigin old man for real. Take a plasma vs lcd, for instance how much juice a plasma eats for an hour for your viewing pleasure, or computer cpus, i know they are phasing out plasmas and garbage but enough about that stupid energy tree hugger crap. i was thinking about a heastsink for the intake somehow or oil filter strap on haha or heat sink valve covers but with the high temps of an engine bay, the knockoff amplifier sinks probly would be unapropriate and possibly innefecient, but ive never seen it done before, probly cause it doesnt work.
I want to buy one of those laser ir temp probes someday, just aim this thing, and it tells you the temp of what you are aiming at.
Old 04-16-2009, 10:06 AM   #10
quazimoto
Member#: 70395
/\ This with these http://www.caswellplating.com/aids/techline/ie.html#ie
I have used the CBC1 on motorcyles and other small engines but not a car yet.Techline makes great products.
quazimoto is offline   Reply With Quote
Old 04-16-2009, 11:11 AM   #11
B-Kerr
Member#: 14841
2002 Impreza WRX
SNOW: They already have clamp on heatsinks for oil filters. I really don't understand why they don't cast fins onto aftermarket intakes for turbo cars. The more surface area, the more heat dissipated.
DUM: Did the Techline make a noticeable difference?
Old 04-17-2009, 08:33 PM   #12
bsymac
Member#: 155720
02 Impreza RS
Other than aesthetics there is no point on coating the outside surface of block. They are cooled by fluid radiator system, therefore retaining the heat is pointless. If you want to cool the combustion chamber you can do other things like meth injection. Money and your energy will be better spent with more advantageous modifications.
bsymac is offline   Reply With Quote
Old 04-18-2009, 02:17 AM   #13
B-Kerr
Member#: 14841
2002 Impreza WRX
We've already determined the cooling system kills the idea. I wasn't trying to cool the combustion chamber, I was looking at conservation of power by eliminating radiant heat. Heat expelled is power lost. But as stated above, the internal combustion engine and awd trans is so inefficient, the power loss to heat is negligible. Also, this all started when I was spending my energy on a more advantageous modification... a 2.5 block! Just figured while I was at it I would brain storm and see what I could do.
Old 04-18-2009, 07:22 AM   #14
quazimoto
Member#: 70395
Saw these........http://www.arcinter.co.jp/english/ar...fin/index.html
B-Kerr: I did a bunch of other modifications to the engines as well so it was kinda hard to tell.But the principle makes sense.More heat,more bang,more efficient combustion.
Old 04-18-2009, 08:13 AM   #15
~snowman~
Member#: 207011
Originally Posted by dumdum View Post
Wow, Thanks nice find, just when you might think you might be original, its been done, haha.
I have been thinking of something else too, I seen before races they cool the manifold with ice sometimes,
well I was thinking of some kind of contraption, that would use dry ice intake thingamajigger on your intake. Like the incoming air would be at a nice temp to ignite and mix? But, Im sure someone thought of that too, and its just pure dry ice lameness with another nub with a bunk theory.
Or, to use some kind of freon line from the A/C / condenser unit and wrap the intercooler, like that one dude was saying in the Meth forum, that sounds badass. lol haha, okay going to space now, commence countdown major tom.
But maybe we have to consider out engine materials, mainly aluminum. Wich may distort and swell at quick, variations of temp from cool to hot and cycling and changing, argh.
I think the world is your oyster when it comes to coatings, although gandering this article a while ago, was saying how ridiculous coatings were thought and regarded of in the auto field, witchcraft, to nowadays, you can coat almost anything in the engine bay with the right wallet and its proven to the point of sometimes OEM using it, specifically coated piston skirts and all that....
Old 04-18-2009, 03:36 PM   #16
quazimoto
Member#: 70395
The CO2 intake and intercooler sprayers
http://www.designengineering.com/pro...asp?m=sc&cid=1
Ford's "Supercooler" system
http://www.fordforums.com/f474/svt-s...plained-33176/
http://www.mustang50magazine.com/tec...ing/index.html
Old 04-20-2009, 08:04 AM   #17
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
^^ that supercooler is a awesome idea, i want it!
who wants to be a guinea pig???
bigolrig is offline   Reply With Quote
Old 04-20-2009, 10:08 AM   #18
B-Kerr
Member#: 14841
2002 Impreza WRX
I believe many of the off-the-shelf coatings at the parts store are snake oil. OEM has made some mistakes too... like Ford/Jaguar and their Teflon coated cylinder walls. Teflon is great until the temperature is too high, or you have a low oil situation and the rings peel the stuff off! I have seen XJs with less than 50k on them that have dropped engines due to the Teflon and Jag will not stand behind them! No warranty whatsoever on a 2-3 yo $60k car!
Engine coating process earns award for engineers AVANTI R5 Non-Subaru News & Rumors 9 07-10-2009 03:53 PM
FS: Invidia DP ceramic coated + heat wrapped teamxmehow NESIC Private Classifieds 16 05-16-2009 07:25 PM
OE manifold heat retention?? Team Scream Built Motor Discussion 1 12-04-2008 08:06 AM
Another: Ceramic coat / Heat wrap thread Speedemon Newbies & FAQs 1 11-20-2008 04:18 AM
Heat retention pre- vs.post-turbo 2Stroke Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 06-25-2004 02:13 PM
